只需一步,快速開(kāi)始
查看: 2196|回復(fù): 0
基于51單片機(jī)1602lcd屏的萬(wàn)年歷設(shè)計(jì)
ID:684165 發(fā)表于 2020-1-9 15:19 | 顯示全部樓層 |閱讀模式
#ifndef _LCD_H_
#define _LCD_H_
#include <reg51.h>
#include <intrins.h>
sbit RS = P2^6;
sbit RW = P2^5;
sbit EN = P2^7;
#define RS_CLR  RS = 0
#define RS_SET  RS = 1
#define RW_CLR  RW = 0
#define RW_SET  RW = 1
#define EN_CLR  EN = 0
#define EN_SET  EN = 1
#define dataport  P0
extern void DelayUs2x(uchar t);
extern void DelayMs(uchar t);
extern void LCD_Write_COM(uchar com);                                //???
extern void LCD_Write_Data(uchar Data);
extern void LCD_Clear();
extern void LCD_Write_String(uchar x, uchar y, uchar* s);
extern void LCD_Write_Char(uchar x, uchar y, uchar c);
extern void LCD_Init();
#endif
/*****lcd.c********/
#include "lcd.h"
        while(--t);
        while(t--)
                DelayUs2x(245);
                DelayUs2x(245);
/* bit LCD_Check_busy(void)
        dataport = 0xff;
        RS_CLR;
        RW_SET;
        EN_CLR;
        _nop_();
        EN_SET;
        return (bit)(dataport&0x80);
        DelayMs(5);
        RS_CLR;
        RW_CLR;
        EN_SET;
        dataport = com;
        _nop_();
        EN_CLR;
        DelayMs(5);
        RS_SET;
        RW_CLR;
        EN_SET;
        dataport = Data;
        _nop_();
        EN_CLR;
void LCD_Clear()
        LCD_Write_COM(0x01);
        DelayMs(5);
//????,x????,y????
        if(y == 0)
                LCD_Write_COM(0x80+x);
                LCD_Write_COM(0xC0+x);
        while(*s)
                LCD_Write_Data(*s);
                s++;
//????,x????,y????
        if(y == 0)
        LCD_Write_Data(c);
void LCD_Init()                                                 //LCD??????
        EN_CLR;
        LCD_Write_COM(0x38);                          //??????
        DelayMs(5);
        DelayMs(5);
        DelayMs(5);
        DelayMs(5);
        LCD_Write_COM(0x0c);                          //????????,????
        LCD_Write_COM(0x06);                          //???????
        LCD_Write_COM(0x01);                          //??
        LCD_Write_COM(0x80);                          //????????
/*****main.c*******/
#include "lcd.h"
uchar hour = 21, min = 43, sec = 0, count, date = 28, monse = 4;
unsigned int year = 2017;
void init_T0()
        EA = 1;
        ET0 = 1;
        TMOD = 0X01;
        TH0 = 0X3C;
        TL0 = 0XB0;
        TR0 = 1;
        init_T0();
        LCD_Init();
        LCD_Clear();
                LCD_Write_String(0, 0, "Date:");
                LCD_Write_Char(5, 0, year/1000+48);
                LCD_Write_Char(6, 0, year%1000/100+48);
                LCD_Write_Char(7, 0, year%100/10+48);
                LCD_Write_Char(8, 0, year%10+48);
                LCD_Write_Char(9, 0, '-');
                LCD_Write_Char(10, 0, monse/10+48);
                LCD_Write_Char(11, 0, monse%10+48);
                LCD_Write_Char(12, 0, '-');
                LCD_Write_Char(13, 0, date/10+48);
                LCD_Write_Char(14, 0, date%10+48);
                LCD_Write_String(0, 1, "Time:");
                LCD_Write_Char(5, 1, hour/10+48);
                LCD_Write_Char(6, 1, hour%10+48);
                LCD_Write_Char(7, 1, '-');
                LCD_Write_Char(8, 1, min/10+48);
                LCD_Write_Char(9, 1, min%10+48);
                LCD_Write_Char(0xa, 1, '-');
                LCD_Write_Char(0xb, 1, sec/10+48);
                LCD_Write_Char(0xc, 1, sec%10+48);
void inter()        interrupt 1
        TH0 = 0X3C;
        TL0 = 0XB0;
        count++;
        if(count >= 20)
                count = 0;
                sec++;
        if(sec >= 60)
                sec = 0;
                min++;
        if(min >= 60)
                min = 0;
                hour++;
        if(hour >= 24)
                hour = 0;
                date++;
        if(date > 31)
                date = 0;
                monse++;
        if(monse > 13)
                monse = 0;
                year++;
