查看: 1436|回復: 1
怎么把溫度測溫報警和時鐘模塊的代碼整合到一起
ID:682184 發(fā)表于 2020-1-6 15:05 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
求解答
源代碼:
#include <reg52.h>
sbit DS=P2^2;           //define interface
uint temp;             // variable of temperature
uchar flag1;            // sign of the result positive or negative
sbit wela1=P2^4;  //?????????????????
sbit wela2=P2^5;
sbit wela3=P2^6;  //?????????????????
sbit wela4=P2^7;  //λ???????????????
sbit beep=P2^3;
unsigned char code table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,
                        0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
unsigned char code table1[]={0xbf,0x86,0xdb,0xcf,0xe6,0xed,0xfd,
                        0x87,0xff,0xef};
void delay(uint count)      //delay
  uint i;
  while(count)
    i=200;
    while(i>0)
    i--;
    count--;
void dsreset(void)       //send reset and initialization command
  uint i;
  DS=0;
  i=103;
  while(i>0)i--;
  DS=1;
  i=4;
  while(i>0)i--;
bit tmpreadbit(void)       //read a bit
   uint i;
   bit dat;
   DS=0;i++;          //i++ for delay
   DS=1;i++;i++;
   dat=DS;
   i=8;while(i>0)i--;
   return (dat);
uchar tmpread(void)   //read a byte date
  uchar i,j,dat;
  dat=0;
  for(i=1;i<=8;i++)
    j=tmpreadbit();
    dat=(j<<7)|(dat>>1);   //?????????????λ??????棬???????????????DAT??
  return(dat);
void tmpwritebyte(uchar dat)   //write a byte to ds18b20
  uint i;
  uchar j;
  bit testb;
  for(j=1;j<=8;j++)
    testb=dat&0x01;
    dat=dat>>1;
    if(testb)     //write 1
      DS=0;
      i++;i++;
      DS=1;
      i=8;while(i>0)i--;
      DS=0;       //write 0
      i=8;while(i>0)i--;
      DS=1;
      i++;i++;
void tmpchange(void)  //DS18B20 begin change
  dsreset();
  delay(1);
  tmpwritebyte(0xcc);  // address all drivers on bus
  tmpwritebyte(0x44);  //  initiates a single temperature conversion
uint tmp()               //get the temperature
  float tt;
  uchar a,b;
  dsreset();
  delay(1);
  tmpwritebyte(0xcc);
  tmpwritebyte(0xbe);
  a=tmpread();
  b=tmpread();
  temp=b;
  temp<<=8;             //two byte  compose a int variable
  temp=temp|a;
  tt=temp*0.0625;
  temp=tt*10+0.5;
  return temp;
void display(uint temp)   //???????
   uchar A1,A2,A2t,A3;
   A1=temp/100;
   A2t=temp%100;
   A2=A2t/10;
   A3=A2t%10;
   wela4=0;
   P0=table[A1];  //?????λ
   //wela1=0;
  // wela1=1;
   wela1=1;
   delay(2);
   wela1=0;
   //wela1=0;
   //P0=0xfe;
   //wela=1;
   //wela=0;
   delay(1);
   P0=table1[A2];  //????λ
   //wela2=0;
   wela2=1;
   delay(2);
   wela2=0;
   //wela=0;
   //P0=0xfd;
   //wela=1;
   //wela=0;
   delay(1);
   P0=table[A3];  //?????λ
   //wela3=0;
   wela3=1;
   delay(2);
   wela3=0;
   //wela=0;
   //P0=0xfb;
  // wela=1;
   //wela=0;
   delay(1);
uchar a;
  do
    tmpchange();
for(a=10;a>0;a--)
    display(tmp());
if(temp>=310)  //????????31????????????????????????????????????????????????
   P1=0x00;
   beep=0;
   beep=1;
   P1=0xff;
  } while(1);
源代碼:
#include <reg52.h>
#define D P0
#define W P2
sbit IO=P1^1;
sbit SCLK=P1^0;
sbit RST=P1^2;
sbit s1=P3^5;
sbit s2=P3^6;
sbit s3=P3^7;
sbit led=P2^3;
uchar s, knum=0,snum,fnum;
bit flag;
/***********д???????************/
#define write_shi  0x84
#define write_fen  0x82
#define write_miao 0x80
#define read_shi  0x85
#define read_fen  0x83
#define read_miao 0x81
bit miao_flag;
char miao_num;
char Dmiao;
char shi,fen,miao;
uchar d[]={0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,0x90};
void delay(uint z)
uint x,y;
for(x=z;x>0;x--)
  for(y=110;y>0;y--);
void t0_init()
  TMOD=0X01;
  TH0=(65536-50000)/256;
  TL0=(65536-50000)%256;
  EA=1;
  ET0=1;
  TR0=1;
uchar read_1302(uchar add)
uchar i,date;
RST=0;
for(i=0;i<8;i++)
  RST=1;
  SCLK=0;
  IO=add&0x01;
  add>>=1;
  SCLK=1;
for(i=0;i<8;i++)
  if(IO)
   date=date|0x80;
   date=date|0x00;
  SCLK=1;
  date>>=1;
  SCLK=0;
RST=0;
date=date/16*10+date%16;
IO=0;
return date;
void write_1302(uchar add,uchar dat)
uchar i;
RST=0;
SCLK=0;
for(i=0;i<8;i++)
  RST=1;
  SCLK=0;
  IO=add&0x01;
  add>>=1;
  SCLK=1;
for(i=0;i<8;i++)
  RST=1;
  SCLK=0;
  IO=dat&0x01;
  dat>>=1;
  SCLK=1;
RST=0;
void init_1302()
  flag=read_1302(0x81);
  if(flag&0x80)
write_1302(0x8e,0x00);
write_1302(write_miao,0x56);
write_1302(write_fen,0x49);
write_1302(write_shi,0x14);
write_1302(0x90,0xa5);
write_1302(0x8e,0x80);
void display(uchar shi,uchar fen)
if(knum==0)
  snum=30;
  fnum=30;
if(knum==1)
  fnum++;
  snum=30;
if(knum==2)
  snum++;
  fnum=30;
if(snum>=30)
  W=0x7F;
  s=d[shi/10];
  if(s==0xc0)
                 W=0xff;
                 D=0xff;
                D=s;
  delay(5);
  D=0Xff;
  if(miao_flag)
      miao_flag=0;
   W=0xBF;
   D=d[shi%10];
   delay(5);
   D=0Xff;
  W=0Xff;
   W=0xBF;
   D=d[shi%10];
   delay(5);
   D=0Xff;
  W=0Xff;
     if(snum==60)
   snum=0;
if(fnum>=30)
  W=0xDF;
  D=d[fen/10];
  delay(5);
  D=0Xff;
  W=0Xff;
  W=0xEF;
  D=d[fen%10];
  delay(5);
  D=0Xff;
  W=0Xff;
  if(fnum==60)
   fnum=0;
  D=0Xff;
  W=0Xff;
void read_sf()
miao=read_1302(read_miao);
/*if(miao!=Dmiao)
  Dmiao=miao;
  TR0=1;
  miao_flag=1;
fen=read_1302(read_fen);
shi=read_1302(read_shi);
display(shi,fen);
void keyscan()
if(s3==0)
  delay(10);
  if(s3==0)
   while(!s3)
    display(shi,fen);
   knum++;
   if(knum==1)
     write_1302(write_miao,0x80);
   if(knum==3)
    knum=0;
    write_1302(write_miao,0x00);
if(knum==1)
  if(s1==0)
   delay(10);
   if(s1==0)
    while(!s1)
     display(shi,fen);
    fen++;
    if(fen==60)
     fen=0;
    write_1302(write_fen,fen/10*16+fen%10);
//    read_sf();
  if(s2==0)
   delay(10);
   if(s2==0)
    while(!s2)
     display(shi,fen);
    fen--;
    if(fen==-1)
     fen=59;
    read_sf();
if(knum==2)
  if(s1==0)
   delay(10);
   if(s1==0)
    while(!s1)
     display(shi,fen);
    shi++;
    if(shi==24)
     shi=0;
    write_1302(write_shi,shi/10*16+shi%10);
    read_sf();
  if(s2==0)
   delay(10);
   if(s2==0)
    while(!s2)
       display(shi,fen);
    shi--;
    if(shi==-1)
     shi=23;
    read_sf();
init_1302();
t0_init();
{ if(miao_num<10)
     led=0;
      if(miao_num>=10)
      led=1;
  read_sf();
  keyscan();
void t0_timer() interrupt 1
TMOD=0X01;
miao_num++;
if(miao_num>=25)
  miao_num=0;
  miao_flag=1;
ID:700149 發(fā)表于 2020-4-27 12:44 來自觸屏版 | 只看該作者
博主有答案了嗎,蹲蹲
