- #include <reg52.h>
- #define key P2
- #define LCD1602_DB P0
- sbit LCD1602_RS = P1^0;
- sbit LCD1602_RW = P1^1;
- sbit ADDR2 = P1^2;
- sbit ADDR3 = P1^3;//
- sbit ENLED = P1^4;//p1.4和p1.3是138使能端
- static unsigned char D=0;
- static unsigned char G=50;
- sbitbuzz=P1^6;
- bit flag1s = 0; //1s定時(shí)標(biāo)志
- unsigned char T0RH = 0; //T0重載值的高字節(jié)
- unsigned char T0RL = 0; //T0重載值的低字節(jié)
- extern void delay_ms(unsigned int ms);
- extern void DelayX10us(unsigned char t);
- void ConfigTimer0(unsigned int ms);
- unsigned char IntToString(unsigned char*str, int dat);
- extern bit Start18B20();
- extern bit Get18B20Temp(int *temp);
- extern void InitLcd1602();
- extern void LcdShowStr(unsigned char x,unsigned char y, unsigned char *str);
- unsigned char code table0[]="D=";
- unsigned char code table1[]="G=";
- unsigned char code table2[]="TEMPIS:";
- unsigned char codetable3[]="DS18B20 ERR0R!";
- unsigned char codetable4[]="PLEASE CHECK!";
- unsigned char code table5[]="'C";
- unsigned char code table7[]="Wlecometo you!!";
- unsigned char code table8[]=" I am YYY_Temp!";
- void main()
- bit res;
- int temp; //讀取到的當(dāng)前溫度值
- int intT, decT; //溫度值的整數(shù)和小數(shù)部分
- unsigned char len;
- unsigned char str[12];
- InitLcd1602();
- LcdShowStr(0, 0, table7);
- LcdShowStr(0, 1, table8);//5初始化顯示5s
- delay_ms(5000);
- EX0=1;
- IT0=1;
- EA = 1; //開(kāi)總中斷
- ConfigTimer0(10); //T0定時(shí)10ms
- Start18B20(); //啟動(dòng)DS18B20
- delay_ms(5000);
- while (1)
- if (flag1s) //每5秒更新一次溫度
- flag1s = 0;
- res = Get18B20Temp(&temp); //讀取當(dāng)前溫度
- if (res) //讀取成功時(shí),刷新當(dāng)前溫度顯示
- intT = temp >> 4; //分離出溫度值整數(shù)部分
- decT = temp & 0xF; //分離出溫度值小數(shù)部分
- len = IntToString(str, intT);//整數(shù)部分轉(zhuǎn)換為字符串
- str[len++] = '.'; //添加小數(shù)點(diǎn)
- decT = (decT*10) / 16; //二進(jìn)制的小數(shù)部分轉(zhuǎn)換為1位十進(jìn)制位
- str[len++] = decT + '0'; //十進(jìn)制小數(shù)位再轉(zhuǎn)換為ASCII字符
- while (len < 6) //用空格補(bǔ)齊到6個(gè)字符長(zhǎng)度
- str[len++] = ' ';
- str[len] = '\0'; //添加字符串結(jié)束符
- LcdShowStr(8, 1, str); //顯示到液晶屏
- len= IntToString(str, D); //整數(shù)部分轉(zhuǎn)換為字符串
- str[len++] = ' ';
- LcdShowStr(2, 0, str);
- len = IntToString(str, G); //整數(shù)部分轉(zhuǎn)換為字符串
- str[len++] = ' ';
- LcdShowStr(10, 0, str);
- LcdShowStr(0,0, table0);
- LcdShowStr(8,0, table1);
- LcdShowStr(0,1, table2);
- LcdShowStr(13,1, table5);
- else //讀取失敗時(shí),提示錯(cuò)誤信息
- LcdShowStr(0, 0, table3);
- LcdShowStr(0, 1, table4);
- Start18B20(); //重新啟動(dòng)下一次轉(zhuǎn)換
- //鍵盤(pán)設(shè)置上下限,0.3s掃描一次鍵值,同時(shí)更新一次上下限的顯示
- key=0xf7;
- if(key!=0xf7)
- delay_ms(10);
- switch(key)
- case0xe7:
- D++;
- if(D==G)D=0;
- while(len < 6) //用空格補(bǔ)齊到6個(gè)字符長(zhǎng)度
- str[len++]= ' ';
- str[len]= '\0'; //添加字符串結(jié)束符
- LcdShowStr(2,0, str);
- break;
- case0xd7:
- G--;
- if(G==D)G=50;
- len= IntToString(str, G); //整數(shù)部分轉(zhuǎn)換為字符串
- str[len++]= ' ';
- LcdShowStr(10,0, str);
- break;
- Start18B20();
- delay_ms(300);//等待0.3s開(kāi)始下一次掃描鍵值
- //光和聲音警報(bào)部分
- if(D>temp*0.0625||G<temp*0.0625)//超值報(bào)警
- ENLED= 0;
- ADDR3= 1;
- ADDR2= 1;
- LCD1602_RW= 1;
- LCD1602_RS= 0;
- LCD1602_DB=0xf0;
- buzz=1;
- DelayX10us(17);
- buzz=0;
- DelayX10us(17);
- ENLED= 1;//138使能關(guān)閉
- if(D==(temp*0.0625)||G==(temp*0.0625))//等值報(bào)警
- ENLED= 0;
- ADDR3= 1;
- ADDR2= 1;
- LCD1602_RW = 1;
- LCD1602_RS= 0;
- LCD1602_DB=0xf8;
- buzz=1;
- DelayX10us(100);
- buzz=0;
- DelayX10us(100);
- if((D<temp*0.0625&&(1.1*D)>temp*0.0625)||(G>temp*0.0625&&(0.9*G)<temp*0.0625))//接近報(bào)警
- ENLED= 0;
- ADDR3= 1;
- ADDR2= 1;
- LCD1602_RW= 1;
- LCD1602_RS= 0;
- LCD1602_DB=0xfc;
- buzz=1;
- DelayX10us(2500);
- buzz=0;
- DelayX10us(2500);
- /* 整型數(shù)轉(zhuǎn)換為字符串,str-字符串指針,dat-待轉(zhuǎn)換數(shù),返回值-字符串長(zhǎng)度*/
- signed char i = 0;
- unsigned char len = 0;
- unsigned char buf[6];
- if (dat < 0) //如果為負(fù)數(shù),首先取絕對(duì)值,并在指針上添加負(fù)號(hào)
- dat = -dat;
- *str++ = '-';
- len++;
- else
- *str++= ' ';
- len++;
- do { //先轉(zhuǎn)換為低位在前的十進(jìn)制數(shù)組
- buf[i++] = dat % 10;
- dat /= 10;
- }while (dat > 0);
- len += i; //i最后的值就是有效字符的個(gè)數(shù)
- while (i-- > 0) //將數(shù)組值轉(zhuǎn)換為ASCII碼反向拷貝到接收指針上
- *str++ = buf[i] + '0';
- *str = '\0'; //添加字符串結(jié)束符
- return len; //返回字符串長(zhǎng)度
- /* 配置并啟動(dòng)T0,ms-T0定時(shí)時(shí)間 */
- unsigned long tmp; //臨時(shí)變量
- tmp = 11059200 / 12; //定時(shí)器計(jì)數(shù)頻率
- tmp = (tmp * ms) / 1000; //計(jì)算所需的計(jì)數(shù)值
- tmp = 65536 - tmp; //計(jì)算定時(shí)器重載值
- tmp = tmp + 12; //補(bǔ)償中斷響應(yīng)延時(shí)造成的誤差
- T0RH = (unsigned char)(tmp>>8); //定時(shí)器重載值拆分為高低字節(jié)
- T0RL = (unsigned char)tmp;
- TMOD &= 0xF0; //清零T0的控制位
- TMOD |= 0x01; //配置T0為模式1
- TH0 = T0RH; //加載T0重載值
- TL0 = T0RL;
- ET0 = 1; //使能T0中斷
- TR0 = 1; //啟動(dòng)T0
- /* T0中斷服務(wù)函數(shù),完成1秒定時(shí) */
- void InterruptTimer0() interrupt 1
- static unsigned int tmr1s = 0;
- TH0 = T0RH; //重新加載重載值
- TL0 = T0RL;
- tmr1s++;
- if (tmr1s >= 500) //定時(shí)5s
- tmr1s = 0;
- flag1s = 1;
復(fù)制代碼 |
