查看: 1707|回復(fù): 0
直流電機(jī)PWM調(diào)速原理圖 改錯(cuò) 求幫助
ID:674943 發(fā)表于 2019-12-28 18:36 | 只看該作者 回帖獎(jiǎng)勵(lì) |正序?yàn)g覽 |閱讀模式
ORG 0000H
      AJMP START
      ORG 0003H
      LJMP EINT0
      ORG 000BH
      LJMP ITT0
      ORG 0030H
START:MOV SP,#60H
      MOV R0,#00H
      MOV R1,#00H
      CLR P1.5
      CLR P1.6
      CLR P1.7
      MOV TMOD,#01H
      MOV TL0,#0ffH
      MOV TH0,#0ffH
      SETB EA
      SETB EX0
      SETB ET0
      CLR IT0
      SETB TR0
      MOV DPTR,#TAB
      MOV 40h,#0
      MOV 41h,#0
   LED:SETB P1.1
      CLR P1.2
      MOV A,40H
      MOVC A,@A+DPTR
      MOV P0,A
      LCALL TTS
      CLR P1.1
      SETB P1.2
      MOV A,41H
      MOVC A,@A+DPTR
      MOV P0,A
      LCALL TTS
      CLR P1.2
      LJMP LED
      ORG 2000H
      ITT0:CPL P1.5
      JNB P1.5,Z1
      MOV A,#0FFH
      SUBB A,R0
      MOV TH0,A
      SETB TR0
      RETI
Z1:MOV TH0,R0
      SETB TR0
      RETI
  EINT0:CLR EX0
      MOV A,#0FFH
      MOV P2,A
      MOV A,P2
      JNB ACC.0,JIA
      JNB ACC.1,JIAN
      JNB ACC.2,ZZ
      JNB ACC.3,FF
      JNB ACC.4,TZ
      AJMP QQ
      AJMP QQ
      JIA:CJNE R0,#0FFH, BB
BB:MOV A,R0
      ADD A,#5
      MOV R0,A
      AJMP QQ
    JIAN:CJNE R0,#00,MM
      AJMP QQ
MM:MOV A,R0
      SUBB A,#5
      MOV R0,A
      AJMP QQ
QQ:MOV A,R0
      MOV B,#5
      DIV AB
      MOV B,#10
      DIV AB
      MOV 40H,A
      MOV 41H,B
      SETB EX0
      LCALL TTS
      LCALL TTS
      LCALL TTS
      LCALL TTS
      RETI
      ZZ:SETB P1.6
      CLR  P1.7
      LCALL TTS
      LCALL TTS
      LCALL TTS
      SETB EX0
      RETI
FF:CLR P1.6
      SETB P1.7
      LCALL TTS
      LCALL TTS
      LCALL TTS
      SETB EX0
      RETI
TZ:CLR P1.6
      CLR P1.7
      LCALL TTS
      LCALL TTS
      LCALL TTS
      SETB EX0
      RETI
TTS:MOV R3,#0E0H
TT1S:MOV R4,#30H
TT0S:DJNZ R4,TT0S
      DJNZ R3,TT1S
      RET
TAB:DB 40H,79H,24H,30H,19H
     DB 12H,02H,78H,00H,10H
      END
電機(jī).zip
28.75 KB, 下載次數(shù): 4, 下載積分: 黑幣 -5
