sbit SCL = P3^0;
sbit SDA = P3^1;
確認(rèn)芯片為PCF8547T iic地址就不用改了(PCF8547好像也一樣,8547A不太一樣)
單片機(jī)源程序如下:
- #include <intrins.h>
- sbit SCL = P3^0;
- sbit SDA = P3^1;
- bit ack;
- /*sbit RS=P2^0;
- sbit Rw=P2^1;
- sbit E =P2^2; */
- sbit deng =P1^0;
- unsigned char LCD_data;
- unsigned char code digit[ ]={"0123456789"}; //定義字符數(shù)組顯示數(shù)字
- /*bt0=date&0x01;
- bt1=date&0x02;
- bt2=date&0x04;
- bt3=date&0x08;
- bt4=date&0x10;
- bt5=date&0x20;
- bt6=date&0x40;
- bt7=date&0x80; */
- //*****************延時(shí)************************
- void delay_nus(unsigned int n) //N us延時(shí)函數(shù)
- unsigned int i=0;
- for (i=0;i<n;i++)
- _nop_();
- void delay_nms(unsigned int n) //N ms延時(shí)函數(shù)
- unsigned int i,j;
- for (i=0;i<n;i++)
- for (j=0;j<1140;j++);
- void nop4()
- _nop_(); //等待一個(gè)機(jī)器周期
- //***************************************88
- void Start()
- SDA=1;
- _nop_();
- SCL=1;
- nop4();
- SDA=0;
- nop4();
- SCL=0;
- _nop_();
- _nop_();
- void Stop()
- SDA=0;
- _nop_();
- SCL=0;
- nop4();//>4us后SCL跳變
- SCL=1;
- nop4();
- SDA=1;
- _nop_();
- _nop_();
- void Write_A_Byte(unsigned char c)
- unsigned char BitCnt;
- for(BitCnt=0;BitCnt<8;BitCnt++) //要傳送的數(shù)據(jù)長(zhǎng)度為8位
- if((c<<BitCnt)&0x80) SDA=1; //判斷發(fā)送位
- else SDA=0;
- _nop_();
- SCL=1; //置時(shí)鐘線為高,通知被控器開(kāi)始接收數(shù)據(jù)位
- nop4();
- _nop_();
- SCL=0;
- _nop_();
- _nop_();
- SDA=1; //8位發(fā)送完后釋放數(shù)據(jù)線,準(zhǔn)備接收應(yīng)答位
- _nop_();
- _nop_();
- SCL=1;
- _nop_();
- _nop_();
- _nop_();
- if(SDA==1)ack=0;
- else ack=1; //判斷是否接收到應(yīng)答信號(hào)
- SCL=0;
- _nop_();
- _nop_();
- bit Write_Random_Address_Byte(unsigned char add,unsigned char dat)
- Start(); //啟動(dòng)總線
- Write_A_Byte(add); //發(fā)送器件地址
- if(ack==0)return(0);
- Write_A_Byte(dat); //發(fā)送數(shù)據(jù)
- Stop(); //結(jié)束總線
- return(1);
- //********************液晶屏使能*********************
- void Enable_LCD_write()
- LCD_data|=(1<<(3-1));//E=1;
- Write_Random_Address_Byte(0x4e,LCD_data);
- delay_nus(2);
- LCD_data&=~(1<<(3-1));//E=0;
- //*************寫命令****************************
- void LCD_write_command(unsigned char command)
- delay_nus(16);
- LCD_data&=~(1<<(1-1));//RS=0;
- LCD_data&=~(1<<(2-1));//RW=0;
- LCD_data&=0x0f; //清高四位
- LCD_data|=command & 0xf0; //寫高四位
- Enable_LCD_write();
- command=command<<4; //低四位移到高四位
- LCD_data|=command&0xf0; //寫低四位
- //*************寫數(shù)據(jù)****************************
- void LCD_write_data(unsigned char value)
- delay_nus(16);
- LCD_data|=(1<<(1-1));//RS=1;
- LCD_data&=0X0f; //清高四位
- LCD_data|=value&0xf0; //寫高四位
- value=value<<4; //低四位移到高四位
- LCD_data|=value&0xf0; //寫低四位
- //**********************設(shè)置顯示位置*********************************
- void set_position(unsigned char x,unsigned char y)
- unsigned char position;
- if (y == 0)
- position = 0x80 + x;
- else
- position = 0xc0 + x;
- LCD_write_command(position);
- //**********************顯示字符串*****************************
- void display_string(unsigned char x,unsigned char y,unsigned char *s)
- set_position(y-1,x-1);
- while (*s)
- LCD_write_data(*s);
- s++;
- //********************顯示數(shù)字*******************************xs
- void display_num(unsigned char x,unsigned char y,unsigned int num)
- unsigned char i,j,k,m,n;
- i=num/10000;
- j=num/1000%10;
- k=num/100%10;
- m=num/10%10;
- n=num%10;
- LCD_write_data(digit[i]); //將萬(wàn)位數(shù)字的字符常量寫入LCD
- LCD_write_data(digit[j]); //將千位數(shù)字的字符常量寫入LCD
- LCD_write_data(digit[k]);
- LCD_write_data(digit[m]);
- LCD_write_data('.');
- LCD_write_data(digit[n]);
- //*************液晶初始化****************************
- void LCD_init(void)
- LCD_write_command(0x28);
- delay_nus(40);
- delay_nus(40);
- delay_nus(40);
- LCD_write_command(0x28); //4位顯示!!!!!!!!!!!!!!!!!!
- LCD_write_command(0x0c); //顯示開(kāi)
- LCD_write_command(0x01); //清屏
- delay_nms(2);
- //********************按鍵*********************
- void button()
- bit button1;
- if (deng==0){button1=~button1;}
- if(button1==0)
- LCD_data|=(1<<(4-1));//E=1;
- if(button1==1)
- LCD_data&=~(1<<(4-1));//E=0;
1602測(cè)試.zip
(33.13 KB, 下載次數(shù): 36)
2019-12-28 14:13 上傳
點(diǎn)擊文件名下載附件
評(píng)分
查看全部評(píng)分
