查看: 2613|回復: 0
單片機時鐘程序GTX TX-1C
ID:662643 發表于 2019-12-26 20:33 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
希望對你們有用#include<reg51.h>
sbit dula=P2^6;
sbit wela=P2^7;
sbit beep=P2^3;
unsigned char j,k,a1,a0,b1,b0,c1,c0,s,f,m,key=10,temp,qq;
uchar shi20,shi10,fen20,fen10,miao20,miao10,new,ok=1,wei;
unsigned int pp;
unsigned char code table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,
                        0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
void delay(unsigned char i)
  for(j=i;j>0;j--)
    for(k=125;k>0;k--);
void display(uchar shi2,uchar shi1,uchar fen2,uchar fen1,uchar miao2,uchar miao1)
   dula=0;
   P0=table[shi2];
   dula=1;
   dula=0;
   wela=0;
   P0=0xfe;
   wela=1;
   wela=0;
   delay(5);
   P0=table[shi1]|0x80;
   dula=1;
   dula=0;
   P0=0xfd;
   wela=1;
   wela=0;
   delay(5);
   P0=table[fen2];
   dula=1;
   dula=0;
   P0=0xfb;
   wela=1;
   wela=0;
   delay(5);
   P0=table[fen1]|0x80;
   dula=1;
   dula=0;
   P0=0xf7;
   wela=1;
   wela=0;
   delay(5);
   P0=table[miao2];
   dula=1;
   dula=0;
   P0=0xef;
   wela=1;
   wela=0;
   delay(5);
   P0=table[miao1];
   dula=1;
   dula=0;
   P0=0xdf;
   wela=1;
   wela=0;
   delay(5);
void keyscan0()
    P3=0xfb;
    temp=P3;
    temp=temp&0xf0;
    if(temp!=0xf0)
      delay(10);
      if(temp!=0xf0)
        temp=P3;
        switch(temp)
          case 0xbb:
               ok=0;
               break;
          case 0x7b:
               ok=1;
               break;
void keyscan()
    P3=0xfe;
    temp=P3;
    temp=temp&0xf0;
    if(temp!=0xf0)
      delay(10);
      if(temp!=0xf0)
        temp=P3;
        switch(temp)
          case 0xee:
               key=0;
                           wei++;
               break;
          case 0xde:
               key=1;
                           wei++;
               break;
          case 0xbe:
               key=2;
                           wei++;
               break;
          case 0x7e:
               key=3;
                           wei++;
               break;
         while(temp!=0xf0)
           temp=P3;
           temp=temp&0xf0;
           beep=0;
         beep=1;
    P3=0xfd;
    temp=P3;
    temp=temp&0xf0;
    if(temp!=0xf0)
      delay(10);
      if(temp!=0xf0)
        temp=P3;
        switch(temp)
          case 0xed:
               key=4;
                           wei++;
               break;
          case 0xdd:
               key=5;
                           wei++;
               break;
          case 0xbd:
               key=6;
                           wei++;
               break;
          case 0x7d:
               key=7;
                           wei++;
               break;
         while(temp!=0xf0)
           temp=P3;
           temp=temp&0xf0;
           beep=0;
         beep=1;
    P3=0xfb;
    temp=P3;
    temp=temp&0xf0;
    if(temp!=0xf0)
      delay(10);
      if(temp!=0xf0)
        temp=P3;
        switch(temp)
          case 0xeb:
               key=8;
                           wei++;
               break;
          case 0xdb:
               key=9;
                           wei++;
               break;
        while(temp!=0xf0)
           temp=P3;
           temp=temp&0xf0;
           beep=0;
         beep=1;
        TMOD=0x01;
        TH0=(65536-46080)/256;// óéóú¾§ÕñÎa11.0592,1êËù¼Ç′Îêyó|Îa46080£¬¼Æê±Æ÷ÿ¸ô50000΢Ãë·¢Æeò»′ÎÖD¶Ï¡£
        TL0=(65536-46080)%256;//46080μÄà′àú£¬Îa50000*11.0592/12
        ET0=1;
        EA=1;
        {        keyscan0();
                if(ok==1)
                {        TR0=1;
                        wei=0;
                if(pp==20)
                {        pp=0;
                        m++;
                        if(m==60)
                                m=0;
                                f++;
                                if(f==60)
                                        f=0;
                                        s++;
                                        if(s==24)  //Îa24hò»¸öÑ-»·£¬èôòa12h£¬Ö»DèÔú′˸ÄÎa12¼′¿é¡£
                                                s=0;
                a0=s%10;
                a1=s/10;
                b0=f%10;
                b1=f/10;
                c0=m%10;
                c1=m/10;
                display(a1,a0,b1,b0,c1,c0);
        {        TR0=0;
                keyscan();
                if(key!=10)
                switch(wei)
                        case 1: if(key<3)                //D¡ê±×î¸ßλÎa2
                                        a1=key;
                                        wei--;
                                        break;
                        case 2: if(a1==1|a1==0)
                                        a0=key;
                                        if(key<5)
                                        a0=key;                   //μ±D¡ê±×î¸ßλÎa2ê±£¬μíλ×î¸ßÎa4
                                        break;
                        case 3: if(key<7)                //·ÖÖó×î¸ßλÎa6
                                        b1=key;
                                        wei--;
                                        break;
                        case 4: b0=key; break;
                        case 5: if(key<7)                //Ãë×î¸ßλÎa6
                                        c1=key;
                                        wei--;
                                        break;
                        case 6: c0=key; break;
                key=10;
                        m=c1*10+c0;
                        f=b1*10+b0;
                        s=a1*10+a0;
void time0() interrupt 1
{        TH0=(65536-46080)/256;
        pp++;
