2019-12-22 20:29 上傳
單片機(jī)源程序如下:
- #include<reg52.h>
- #include<intrins.h>
- #include<absacc.h> //頭文件
- #define uc unsigned char
- #define ui unsigned int
- sbit in_go = P1^3;
- sbit in_back = P1^2;//手動(dòng)前進(jìn)后退按鍵
- sbit out_go = P3^0;
- sbit out_back = P3^5;//電機(jī)控制輸出
- sbit limit_go = P3^4;
- sbit limit_back = P3^6;//前進(jìn)后退限位開(kāi)關(guān)
- sbit led_go = P1^4;
- sbit led_back = P1^5;//前進(jìn)后退限位指示燈
- sbit light = P1^0;//光線傳感器
- sbit change = P1^1;//手動(dòng)自動(dòng)切換按鍵(默認(rèn)自動(dòng))
- sbit led_zhishi = P1^7;
- sbit buzz = P1^6;
- sbit W1=P2^2;
- sbit W2=P2^1;
- //定義DHT11數(shù)據(jù)口
- sbit DATA = P2^0;
- uc U8FLAG,U8temp,U8comdata,U8RH_data_H_temp,U8RH_data_L_temp,U8T_data_H_temp,U8T_data_L_temp,U8checkdata_temp;
- uc U8RH_data_H,U8RH_data_L,U8T_data_H,U8T_data_L,U8checkdata;
- uc Mode,humidity;
- bit bdata FlagStartRH,hot,cold,humid,dry;
- bit bdata flag1,flag2,change_flag,flag_shan,flag_shan1,flag_shan2,flag_HH;
- uc m,n,shan;
- uc code table[11]={ //共陰極字型碼
- 0x3f, //--0
- 0x06, //--1
- 0x5b, //--2
- 0x4f, //--3
- 0x66, //--4
- 0x6d, //--5
- 0x7d, //--6
- 0x07, //--7
- 0x7f, //--8
- 0x6f, //--9
- 0x00 //--NULL
- //定時(shí)器0初始化
- void Timer0_Init()
- ET0 = 1; //允許定時(shí)器0中斷
- TMOD = 1; //定時(shí)器工作方式選擇
- TL0 = 0xb0;
- TH0 = 0x3c; //定時(shí)器賦予初值
- TR0 = 1; //啟動(dòng)定時(shí)器
- EA=1;
- void Delay1(ui j)
- uc i;
- for(;j>0;j--)
- for(i=0;i<27;i++);
- void Delay_10us(void)
- uc i;
- i--;
- i--;
- i--;
- i--;
- i--;
- i--;
- void COM(void)
- uc i;
- for(i=0;i<8;i++)
- U8FLAG=2;
- while((!DATA)&&U8FLAG++);
- Delay_10us();
- Delay_10us();
- Delay_10us();
- U8temp=0;
- if(DATA)U8temp=1;
- U8FLAG=2;
- while((DATA)&&U8FLAG++);
- //超時(shí)則跳出for循環(huán)
- if(U8FLAG==1)break;
- //判斷數(shù)據(jù)位是0還是1
- // 如果高電平高過(guò)預(yù)定0高電平值則數(shù)據(jù)位為 1
- U8comdata<<=1;
- U8comdata|=U8temp; //0
- }//rof
- //-----溫濕度讀取子程序 ------------
- //----以下變量均為全局變量--------
- //----溫度高8位== U8T_data_H------
- //----溫度低8位== U8T_data_L------
- //----濕度高8位== U8RH_data_H-----
- //----濕度低8位== U8RH_data_L-----
- //----校驗(yàn) 8位 == U8checkdata-----
- //----調(diào)用相關(guān)子程序如下----------
- //---- Delay();, Delay_10us();,COM();
- uc RH(void)
- //主機(jī)拉低18ms
- DATA=0;
- Delay1(180); //原來(lái)為5
- DATA=1;
- //總線由上拉電阻拉高 主機(jī)延時(shí)20us
- Delay_10us();
- Delay_10us();
- Delay_10us();
- Delay_10us();
- //主機(jī)設(shè)為輸入 判斷從機(jī)響應(yīng)信號(hào)
- DATA=1;
- //判斷從機(jī)是否有低電平響應(yīng)信號(hào) 如不響應(yīng)則跳出,響應(yīng)則向下運(yùn)行
- if(!DATA) //T !
- U8FLAG=2;
- //判斷從機(jī)是否發(fā)出 80us 的低電平響應(yīng)信號(hào)是否結(jié)束
- U8FLAG=2;
- //判斷從機(jī)是否發(fā)出 80us 的高電平,如發(fā)出則進(jìn)入數(shù)據(jù)接收狀態(tài)
- //數(shù)據(jù)接收狀態(tài)
- COM();
- U8RH_data_H_temp=U8comdata;
- COM();
- U8RH_data_L_temp=U8comdata;
- COM();
- U8T_data_H_temp=U8comdata;
- COM();
- U8T_data_L_temp=U8comdata;
- COM();
- U8checkdata_temp=U8comdata;
- DATA=1;
- //數(shù)據(jù)校驗(yàn)
- U8temp=(U8T_data_H_temp+U8T_data_L_temp+U8RH_data_H_temp+U8RH_data_L_temp);
- if(U8temp==U8checkdata_temp)
- U8RH_data_H=U8RH_data_H_temp;
- U8RH_data_L=U8RH_data_L_temp;
- U8T_data_H=U8T_data_H_temp;
- U8T_data_L=U8T_data_L_temp;
- U8checkdata=U8checkdata_temp;
- return 1;
- else //傳感器不響應(yīng)
- return 0;
- void delay(ui x)//延時(shí)函數(shù)
- ui i,j;
- for(i=0;i<x;i++)
- for(j=0;j<110;j++);
- void display()
- P0=table[humidity/10];
- W1=0;
- delay(1); //延時(shí)
- W1=1; //關(guān)顯示
- P0=table[humidity%10];
- W2=0;
- W2=1; //關(guān)顯示
- void work()//工作函數(shù)
- if(change==0)//判斷切換是否按下
- buzz=0;
- delay(50);
- if(change==0)
- change_flag=~change_flag;//手動(dòng),自動(dòng)切換
- led_zhishi=change_flag;
- if(change_flag==1)
- out_go=1;
- out_back=1;
- led_go=1;
- led_back=1;
- buzz=1;
- while(!change);//釋放
- buzz=1;
- if(change_flag==0)//自動(dòng)模式
- if(light==0||flag_HH==1)//夜間(無(wú)光)時(shí)拉回衣架 flag_HH==1濕度高
- delay(20);
- if((limit_go==0)&&(flag_shan==0))
- out_go=1;
- out_back=1;
- led_go=1;
- for(shan=0;shan<6;shan++)
- led_go=~led_go;
- buzz=led_go;
- delay(500);
- flag_shan=1;
- else if(limit_go==1)
- out_go=1;
- out_back=0;
- led_back=1;
- led_go=0;
- flag_shan=0;
- else if(light==1&&flag_HH==0)//白天(有光)時(shí)伸出衣架
- delay(20);
- if(light==1&&flag_HH==0)
- if((limit_back==0)&&(flag_shan==0))
- out_go=1;
- out_back=1;
- led_back=1;
- led_back=~led_back;
- buzz=led_back;
- delay(500);
- flag_shan=1;
- else if(limit_back==1)
- out_go=0;
- out_back=1;
- led_back=0;
- led_go=1;
- flag_shan=0;
- else if(change_flag==1)//手動(dòng)模式
- if((in_go==0)&&(limit_go==1))//關(guān)閉是否按下
- buzz=0;
- delay(5);
- buzz=1;
- out_go=1;
- out_back=~out_back;//按一下伸出,再按一下,停止
- buzz=1;
- led_back=1;
- led_go=out_back;
- flag_shan1=0;
- while(!in_go);//釋放
- buzz=1;
- else if((in_back==0)&&(limit_back==1))//打開(kāi)是否按下
- buzz=0;
- delay(5);
- if((in_back==0)&&(limit_back==1))
- buzz=1;
- out_back=1;
- out_go=~out_go;//按一下收回,再按一下,停止
- buzz=1;
- led_go=1;
- led_back=out_go;
- flag_shan2=0;
- while(!in_back);//按鍵釋放
- buzz=1;
- if((limit_go==0)&&(flag_shan1==0))
- delay(5);
- out_back=1;
- led_go=1;
- led_go=~led_go;
- buzz=led_go;
- delay(500);
- flag_shan1=1;
- if((limit_back==0)&&(flag_shan2==0))
- delay(5);
- out_go=1;
- led_back=1;
- buzz=led_back;
- delay(500);
- flag_shan2=1;
- void main()//主函數(shù)
- uc testnum;
- light=0;
- buzz=1;
- led_zhishi=0;
- Timer0_Init();
- while(1)//進(jìn)入死循環(huán)
- work();//調(diào)用工作函數(shù)
- display();
- if (FlagStartRH == 1) //溫濕度轉(zhuǎn)換標(biāo)志檢查
- testnum = RH();
- FlagStartRH = 0;
- humidity = U8RH_data_H; //讀出濕度,只取整數(shù)部分
- if(humidity>=80)
- flag_HH=1;
- else
- flag_HH=0;
- TR0 = 1;
- display();
- //定時(shí)器0中斷
- void Timer0_ISR (void) interrupt 1 using 0
- ui RHCounter;
- TL0 = 0xb0;
- //每5秒鐘啟動(dòng)一次溫濕度轉(zhuǎn)換
- RHCounter ++;
- if (RHCounter >= 20)
- FlagStartRH = 1;
- RHCounter = 0;
- TR0=0;
晾衣架.rar
(235.43 KB, 下載次數(shù): 41)
2019-12-21 18:04 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
