實測可用
- #include "led.h"
- #include "delay.h"
- #include "key.h"
- #include "sys.h"
- #include "stdint.h"
- #include "usart.h"
- #include "mlx90614.h"
- #include "GUI.h"
- #include "Lcd_Driver.h"
- #include "TFT_demo.h"
- //STM32F103核心板例程
- //庫函數版本例程
- int main(void)
- u8 lcd_id[12]; //存放LCD ID字符串
- delay_init(); //延時函數初始化
- NVIC_Configuration(); //設置NVIC中斷分組2:2位搶占優先級,2位響應優先級
- uart_init(9600); //串口初始化為9600
- LED_Init(); //LED端口初始化
- BEEP_Init();
- Lcd_Init(); //1.44寸液晶屏--初始化配置
- Lcd_Clear(GRAY0);//清屏
- Gui_DrawFont_GBK16(0,16,RED,GRAY0," STM32 TFT 1.44 ");
- Gui_DrawFont_GBK16(0,48,BLUE,GRAY0," 嵌入式開發網 ");
- Gui_DrawFont_GBK16(0,64,BLUE,GRAY0,"mcudevcom ");
- SMBus_Init();
- float temp;
- int a;
- while(1)
- temp = SMBus_ReadTemp();
- printf("溫度 = %5.2f℃\r\n",temp);
- sprintf((char*)lcd_id,"%5.2f",temp);
- Gui_DrawFont_GBK16(0,10,BLUE,GRAY0,"Temperature:");
- DisplayButtonUp(30,28,85,52); //x1,y1,x2,y2
- Gui_DrawFont_GBK16(40,32,RED,GRAY0,lcd_id);//體溫顯示到TFT
- delay_ms(1000);
- a=(int)temp;
- if(a<=30|a>=42)//啟動蜂鳴器報警
- GPIO_SetBits(GPIOC,GPIO_Pin_14);
- else GPIO_ResetBits(GPIOC,GPIO_Pin_14);
- delay_ms(1000);
復制代碼- #include "mlx90614.h"
- #define ACK 0
- #define NACK 1
- #define SA 0x00 //從機地址,單個MLX90614時地址為0x00,多個時地址默認為0x5a
- #define RAM_ACCESS 0x00 //RAM access command
- #define EEPROM_ACCESS 0x20 //EEPROM access command
- #define RAM_TOBJ1 0x07 //To1 address in the eeprom
- #define SMBUS_PORT GPIOB
- #define SMBUS_SCK GPIO_Pin_6
- #define SMBUS_SDA GPIO_Pin_7
- #define RCC_APB2Periph_SMBUS_PORT RCC_APB2Periph_GPIOB
- #define SMBUS_SCK_H() SMBUS_PORT->BSRR = SMBUS_SCK
- #define SMBUS_SCK_L() SMBUS_PORT->BRR = SMBUS_SCK
- #define SMBUS_SDA_H() SMBUS_PORT->BSRR = SMBUS_SDA
- #define SMBUS_SDA_L() SMBUS_PORT->BRR = SMBUS_SDA
- #define SMBUS_SDA_PIN() SMBUS_PORT->IDR & SMBUS_SDA //讀取引腳電平
- * 函數名: SMBus_StartBit
- * 功能 : 產生起始位
- * Input : None
- * Output : None
- * Return : None
- void SMBus_StartBit(void)
- SMBUS_SDA_H(); // Set SDA line
- SMBus_Delay(5); // Wait a few microseconds
- SMBUS_SCK_H(); // Set SCL line
- SMBus_Delay(5); // Generate bus free time between Stop
- SMBUS_SDA_L(); // Clear SDA line
- SMBus_Delay(5); // Hold time after (Repeated) Start
- // Condition. After this period, the first clock is generated.
- //(Thd:sta=4.0us min)
- SMBUS_SCK_L(); // Clear SCL line
- * 函數名: SMBus_StopBit
- * 功能: Generate STOP condition on SMBus
- * Input : None
- * Output : None
- * Return : None
- void SMBus_StopBit(void)
- SMBus_Delay(5); // Stop condition setup time(Tsu:sto=4.0us min)
- * 函數名: SMBus_SendByte
- * 功能: Send a byte on SMBus
- * Input : Tx_buffer
- * Output : None
- * Return : None
- u8 SMBus_SendByte(u8 Tx_buffer)
- u8 Bit_counter;
- u8 Ack_bit;
- u8 bit_out;
- for(Bit_counter=8; Bit_counter; Bit_counter--)
- if (Tx_buffer&0x80)
- bit_out=1; // If the current bit of Tx_buffer is 1 set bit_out
- else
- bit_out=0; // else clear bit_out
- SMBus_SendBit(bit_out); // Send the current bit on SDA
- Tx_buffer<<=1; // Get next bit for checking
- Ack_bit=SMBus_ReceiveBit(); // Get acknowledgment bit
- return Ack_bit;
- * 函數名: SMBus_SendBit
- * 功能: Send a bit on SMBus 82.5kHz
- * Input : bit_out
- * Output : None
- * Return : None
- void SMBus_SendBit(u8 bit_out)
- if(bit_out==0)
- SMBUS_SDA_L();
- else
- SMBUS_SDA_H();
- SMBus_Delay(2); // Tsu:dat = 250ns minimum
- SMBus_Delay(6); // High Level of Clock Pulse
- SMBus_Delay(3); // Low Level of Clock Pulse
- // SMBUS_SDA_H(); // Master release SDA line ,
- return;
- * Function Name : SMBus_ReceiveBit
- * Description : Receive a bit on SMBus
- * Input : None
- * Output : None
- * Return : Ack_bit
- u8 SMBus_ReceiveBit(void)
- u8 Ack_bit;
- SMBUS_SDA_H(); //引腳靠外部電阻上拉,當作輸入
- SMBus_Delay(2); // High Level of Clock Pulse
- SMBus_Delay(5); // High Level of Clock Pulse
- if (SMBUS_SDA_PIN())
- Ack_bit=1;
- else
- Ack_bit=0;
- return Ack_bit;
- * 函數名: SMBus_ReceiveByte
- * 功能: Receive a byte on SMBus
- * Input : ack_nack
- * Output : None
- * Return : RX_buffer
- u8 SMBus_ReceiveByte(u8 ack_nack)
- u8 RX_buffer;
- u8 Bit_Counter;
- for(Bit_Counter=8; Bit_Counter; Bit_Counter--)
- if(SMBus_ReceiveBit()) // Get a bit from the SDA line
- RX_buffer <<= 1; // If the bit is HIGH save 1 in RX_buffer
- RX_buffer |=0x01;
- else
- RX_buffer <<= 1; // If the bit is LOW save 0 in RX_buffer
- RX_buffer &=0xfe;
- SMBus_SendBit(ack_nack); // Sends acknowledgment bit
- return RX_buffer;
- * 函數名: SMBus_Delay
- * 功能: 延時 一次循環約1us
- * Input : time
- * Output : None
- * Return : None
- void SMBus_Delay(u16 time)
- u16 i, j;
- for (i=0; i<4; i++)
- for (j=0; j<time; j++);
- * 函數名: SMBus_Init
- * 功能: SMBus初始化
- * Input : None
- * Output : None
- * Return : None
- void SMBus_Init()
- GPIO_InitTypeDef GPIO_InitStructure;
- /* Enable SMBUS_PORT clocks */
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_SMBUS_PORT, ENABLE);
- /*配置SMBUS_SCK、SMBUS_SDA為集電極開漏輸出*/
- GPIO_InitStructure.GPIO_Pin = SMBUS_SCK | SMBUS_SDA;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_OD;
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
- GPIO_Init(SMBUS_PORT, &GPIO_InitStructure);
- SMBUS_SCK_H();
- SMBUS_SDA_H();
- * 函數名: SMBus_ReadMemory
- * 功能: READ DATA FROM RAM/EEPROM
- * Input : slaveAddress, command
- * Return : Data
- u16 SMBus_ReadMemory(u8 slaveAddress, u8 command)
- u16 data; // Data storage (DataH:DataL)
- u8 Pec; // PEC byte storage
- u8 DataL=0; // Low data byte storage
- u8 DataH=0; // High data byte storage
- u8 arr[6]; // Buffer for the sent bytes
- u8 PecReg; // Calculated PEC byte storage
- u8 ErrorCounter; // Defines the number of the attempts for communication with MLX90614
- ErrorCounter=0x00; // Initialising of ErrorCounter
- slaveAddress <<= 1; //2-7位表示從機地址
- do
- repeat:
- SMBus_StopBit(); //If slave send NACK stop comunication
- --ErrorCounter; //Pre-decrement ErrorCounter
- if(!ErrorCounter) //ErrorCounter=0?
- break; //Yes,go out from do-while{}
- SMBus_StartBit(); //Start condition
- if(SMBus_SendByte(slaveAddress))//Send SlaveAddress 最低位Wr=0表示接下來寫命令
- goto repeat; //Repeat comunication again
- if(SMBus_SendByte(command)) //Send command
- SMBus_StartBit(); //Repeated Start condition
- if(SMBus_SendByte(slaveAddress+1)) //Send SlaveAddress 最低位Rd=1表示接下來讀數據
- DataL = SMBus_ReceiveByte(ACK); //Read low data,master must send ACK
- DataH = SMBus_ReceiveByte(ACK); //Read high data,master must send ACK
- Pec = SMBus_ReceiveByte(NACK); //Read PEC byte, master must send NACK
- SMBus_StopBit(); //Stop condition
- arr[5] = slaveAddress; //
- arr[4] = command; //
- arr[3] = slaveAddress+1; //Load array arr
- arr[2] = DataL; //
- arr[1] = DataH; //
- arr[0] = 0; //
- PecReg=PEC_Calculation(arr);//Calculate CRC
- while(PecReg != Pec); //If received and calculated CRC are equal go out from do-while{}
- data = (DataH<<8) | DataL; //data=DataH:DataL
- return data;
- * 函數名: PEC_calculation
- * 功能 : 數據校驗
- * Input : pec[]
- * Output : None
- * Return : pec[0]-this byte contains calculated crc value
- u8 PEC_Calculation(u8 pec[])
- u8 crc[6];
- u8 BitPosition=47;
- u8 shift;
- u8 i;
- u8 j;
- u8 temp;
- do
- /*Load pattern value 0x000000000107*/
- crc[5]=0;
- crc[4]=0;
- crc[3]=0;
- crc[2]=0;
- crc[1]=0x01;
- crc[0]=0x07;
- /*Set maximum bit position at 47 ( six bytes byte5...byte0,MSbit=47)*/
- BitPosition=47;
- /*Set shift position at 0*/
- shift=0;
- /*Find first "1" in the transmited message beginning from the MSByte byte5*/
- i=5;
- j=0;
- while((pec[i]&(0x80>>j))==0 && i>0)
- BitPosition--;
- if(j<7)
- j++;
- else
- j=0x00;
- i--;
- }/*End of while */
- /*Get shift value for pattern value*/
- shift=BitPosition-8;
- /*Shift pattern value */
- while(shift)
- for(i=5; i<0xFF; i--)
- if((crc[i-1]&0x80) && (i>0))
- temp=1;
- else
- temp=0;
- crc[i]<<=1;
- crc[i]+=temp;
- }/*End of for*/
- shift--;
- }/*End of while*/
- /*Exclusive OR between pec and crc*/
- for(i=0; i<=5; i++)
- pec[i] ^=crc[i];
- }/*End of for*/
- while(BitPosition>8); /*End of do-while*/
- return pec[0];
- * 函數名: SMBus_ReadTemp
- * 功能: 計算并返回溫度值
- * Return : SMBus_ReadMemory(0x00, 0x07)*0.02-273.15
- float SMBus_ReadTemp(void)
- return SMBus_ReadMemory(SA, RAM_ACCESS|RAM_TOBJ1)*0.02-273.15;
- /*********************************END OF FILE*********************************/
MLX90614.7z
(258.93 KB, 下載次數: 242)
2019-12-21 01:46 上傳
整個工程文件 下載積分: 黑幣 -5
