波形發(fā)生器(6種)源程序+仿真電路
2019-12-20 14:24 上傳
單片機(jī)源程序如下:
- #include<reg51.h>
- #include<absacc.h>
- #define uchar unsigned char
- #define uint unsigned int
- #define DAC0832 XBYTE[0xfffe]
- sbit k0=P1^0; //產(chǎn)生方波
- sbit k1=P1^1; //產(chǎn)生鋸齒波
- sbit k2=P1^2; //產(chǎn)生三角波
- sbit k3=P1^3; //產(chǎn)生階梯波
- sbit k4=P1^4; //產(chǎn)生正弦波
- sbit k5=P1^5;//產(chǎn)生梯形波
- uchar mm=0,x=0,y=0;
- uchar flag=0;//不同值對(duì)應(yīng)不同波形
- uchar code SETTAB[256]={0x80,0x82,0x85,0x88,0x8b,0x8e,0x91,0x94,0x97,0x9a,0x9d,
- 0xa0,0xa3,0xa6,0xa9,0xac,0xaf,0xb2,0xb6,0xb9,0xbc,0xbf,0xc2,0xc5,0xc7,0xca,0xcc,0xcf,
- 0xd1,0xd4,0xd6,0xd8,0xda,0xdd,0xdf,0xe1,0xe3,0xe5,0xe7,0xe9,0xea,0xec,
- 0xee,0xef,0xf1,0xf2,0xf4,0xf5,0xf6,0xf7,0xf8,0xf9,0xfa,0xfb,0xfc,0xfd,
- 0xfd,0xfe,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,
- 0xfe,0xfd,0xfd,0xfc,0xfb,0xfa,0xf9,0xf8,0xf7,0xf6,0xf5,0xf4,0xf2,0xf1,
- 0xef,0xee,0xec,0xea,0xe9,0xe7,0xe5,0xe3,0xe1,0xde,0xdd,0xda,0xd8,0xd6,
- 0xd4,0xd1,0xcf,0xcc,0xca,0xc7,0xc5,0xc2,0xbf,0xbc,0xba,0xb7,0xb4,0xb1,
- 0xae,0xab,0xa8,0xa5,0xa2,0x9f,0x9c,0x99,0x96,0x93,0x90,0x8d,0x89,0x86,
- 0x83,0x80,0x80,0x7c,0x79,0x76,0x72,0x6f,0x6c,0x69,0x66,0x63,0x60,0x5d,
- 0x5a,0x57,0x55,0x51,0x4e,0x4c,0x48,0x45,0x43,0x40,0x3d,0x3a,0x38,0x35,
- 0x33,0x30,0x2e,0x2b,0x29,0x27,0x25,0x22,0x20,0x1e,0x1c,0x1a,0x18,0x16,
- 0x15,0x13,0x11,0x10,0x0e,0x0d,0x0b,0x0a,0x09,0x08,0x07,0x06,0x05,0x04,
- 0x03,0x02,0x02,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x01,0x02,0x02,0x03,0x04,0x05,0x06,0x07,0x08,0x09,0x0a,0x0b,
- 0x0d,0x0e,0x10,0x11,0x13,0x15,0x16,0x18,0x1a,0x1c,0x1e,0x20,0x22,0x25,
- 0x27,0x29,0x2b,0x2e,0x30,0x33,0x35,0x38,0x3a,0x3d,0x40,0x43,0x45,0x48,
- 0x4c,0x4e,0x51,0x55,0x57,0x5a,0x5d,0x60,0x63,0x66,0x69,0x6c,0x6f,0x72,
- 0x76,0x79,0x7c,0x80};
- void delay(uint ms)
- {uchar i;
- while(ms--)for(i=0;i<120;i++);}
- void sin() //正弦波發(fā)生函數(shù)
- {DAC0832=SETTAB[y];
- x++;y++;}
- void fangbo( ) //方波發(fā)生函數(shù)
- { DAC0832=y;
- x++;
- if(flag==0)
- {y=0xff;
- if(x==128){flag=1;y=0x00;}}//方波+
- else {y=0x00;
- if(x==0){flag=0;y=0xff;}}}//方波-
- void sanjiaobo( ) //三角波發(fā)生函數(shù)
- { DAC0832=y;
- x++;
- if(flag==0)
- {y+=2;
- if(x==128){flag=1;y-=2;}}//三角波+
- else {y-=2;
- if(x==0){flag=0;y=0;}}}//三角波-
- void juchibo() //鋸齒波發(fā)生函數(shù)
- {DAC0832=y; y++;}
- void jietibo()//階梯波發(fā)生函數(shù)
- {DAC0832=y;
- y+=25;}
- void tixing( ) //梯形波發(fā)生函數(shù)
- {uint i;
- DAC0832=y;
- if(flag==0){y+=2;x++;if(x==128){flag=1;y-=2;}}
- else {y-=2;x--;if(x==0){for(i=0;i<5000;i++)y=0x00;flag=0;}}}
- void read_key()
- {if(k0==0){delay(10);if(k0==0){mm=1;while(k0==0);}}
- else if(k1==0){delay(10);if(k1==0){mm=2;while(k1==0);}}
- else if(k2==0){delay(10);if(k2==0){mm=3;while(k2==0);}}
- else if(k3==0){delay(10);if(k3==0){mm=4;while(k3==0);}}
- else if(k4==0){delay(10);if(k4==0){mm=5;while(k4==0);}}
- else if(k5==0){delay(10);if(k5==0){mm=6;while(k5==0);}}}
- void main()
- {TMOD=0x02;
- TH0=TL0=156;
- TR0=1;ET0=1;EA=1;
- mm=0;
- for(;;)read_key();}
- void timer0() interrupt 1 using 2
- {{switch(mm)
- {case 1:fangbo();break;
- case 2:juchibo();break;
- case 3:sanjiaobo();break;
- case 4:jietibo();break;
- case 5:sin();break;
- case 6:tixing();break;}} }
波形發(fā)生器(6種).zip
(52.42 KB, 下載次數(shù): 116)
2019-12-20 14:21 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
