| REFDES | COMP_DEVICE_TYPE | COMP_VALUE | SYM_NAME |
| FB1 | INDUCTOR TORROID_L0603_120OHM@1 | 120ohm@100MHz | L0603 |
| H4 | HOLE_HOLE_CPCI_HOLE | HOLE | HOLE_CPCI |
| J1 | CPCI_CONNECTOR_J1_1_CPCI_J1_CPC | CPCI_CONNECTOR_J1 | CPCI_J1 |
| J4 | FPGA_JTAG_JTAG-X_FPGA_JTAG | FPGA_JTAG | JTAG-X |
| J5 | GE_RJ45_GE_RJ45_GE_RJ45 | GE_RJ45 | GE_RJ45 |
| J6 | CONN SOCKET 3_JUMP3_CONN SOCKET | CONN SOCKET 3 | JUMP3 |
| J7 | BNC_0_SMB_SMA | SMA | SMB |
| J8 | BNC_SMB_SMA | SMA | SMB |
| J9 | BNC_SMB_SMA | SMA | SMB |
| J11 | 1410187-RP0_113_1410187-3 | 1410187-3 | 113 |
| L1 | L680_CDRH6D38NP_5R_2.2UH 5000MA | 2.2uH 5000mA | CDRH6D38NP_5R |
| L2 | L680_CDRH6D38NP_5R_2.2UH 5000MA | 2.2uH 5000mA | CDRH6D38NP_5R |
| L3 | L680_CDRH6D38NP_5R_2.2UF 5000MA | 2.2uF 5000mA | CDRH6D38NP_5R |
| L4 | L680_CDRH6D38NP_5R_2.2UH 5000MA | 2.2uH 5000mA | CDRH6D38NP_5R |
| L5 | INDUCTOR FERRITE_L_SMD_1210_CIZ | CIZHU | L_SMD_1210 |
| L6 | L680_LVS303010_2.2UH | 2.2uH | LVS303010 |
| L7 | INDUCTOR_0603_31.26NH | 31.26nh | 603 |
| L8 | INDUCTOR_0603_44.36NH | 44.36nh | 603 |
| L9 | INDUCTOR_0603_42.75NH | 42.75nh | 603 |
| L10 | INDUCTOR FERRITE_L0603_CIZHU | CIZHU | L0603 |
| L11 | L680_L0603_120OHM@100MHZ | 120OHM@100MHz | L0603 |
| LED1 | LED_D_LED_0805_LED | LED | D_LED_0805 |
| LED2 | LED_D_LED_0805_LED | LED | D_LED_0805 |
| R126 | RPACK4_0_P_SMD_8_F_10K | 10k | P_SMD_8_F |
| R127 | RESISTOR_R0603_100K | 100k | R0603 |
| SW3 | SW_SB_SW | SW | SB |
| U1 | TLV62130RGT_TLV62130RGT_TLV6213 | TLV62130RGT | TLV62130RGT |
| U2 | TLV62130RGT_TLV62130RGT_TLV6213 | TLV62130RGT | TLV62130RGT |
| U3 | 93CS46_DIP8_93CS56 | 93CS56 | DIP8 |
| U4 | TLV62130RGT_TLV62130RGT_TLV6213 | TLV62130RGT | TLV62130RGT |
| U5 | PLX9054_0_PQFP176_PLX9054 | PLX9054 | PQFP176 |
| U6 | TLV62130RGT_TLV62130RGT_TLV6213 | TLV62130RGT | TLV62130RGT |
| U8 | MT41K128M16JT_BGA_96P_31_524X29 | MT41K128M16JT | BGA_96P_31_524X295_C14 |
| U9 | SPX3819M5-3-3_SOT-23-5_SPX381_1 | SPX3819M5-1-8 | SOT-23-5 |
| U10 | XC7Z030-1FBG676I_FBG676_(S1+S2+ | XC7Z030-1FBG676I | FBG676 |
| U11 | MT29F32G08AECBBH1_VBGA100_MT29F | MT29F32G08AECBBH1 | VBGA100 |
| U12 | SPX3819M5-3-3_SOT-23-5_SPX3819M | SPX3819M5-3-0 | SOT-23-5 |
| U13 | MT41K128M16JT_BGA_96P_31_524X29 | MT41K128M16JT | BGA_96P_31_524X295_C14 |
| U14 | TPS51200DRCR_0_DRC0010J_TPS5120 | TPS51200DRCR | DRC0010J |
| U15 | TPS7A7002_SO8_PAD_TPS7A7002 | TPS7A7002 | SO8_PAD |
| U16 | TPS7A7002_SO8_PAD_TPS7A7002 | TPS7A7002 | SO8_PAD |
| U17 | AD9434_LFCSP_VQ56_AD9434 | AD9434 | LFCSP_VQ56 |
| U18 | AD9736_1_BC160_AD9736 | AD9736 | BC160 |
| U19 | W25Q256FV_0_MLP8_W25Q256FV | W25Q256FV | MLP8 |
| U20 | TPS7A7002_SO8_PAD_TPS7A7002 | TPS7A7002 | SO8_PAD |
| U21 | ETC1-1-1_ETC5_ETC1-1-1 | ETC1-1-1 | ETC5 |
| U22 | TXS0102DCU_TSSOP8_TXS0102DCU | TXS0102DCU | TSSOP8 |
| U23 | RTL8211E_RTL8211_QFN48_8169SB | 8169SB | RTL8211_QFN48 |
| U24 | T1-1T_U_SOP_6_ADT1-1WT | ADT1-1WT | U_SOP_6 |
| U25 | CA3140_SOIC8_CA3140 | CA3140 | SOIC8 |
| U26 | T1-1T_0_ADT21T_ADT2-1T-1P | ADT2-1T-1P | ADT21T |
| U27 | MAX3232_TSSOP16_MAX3232 | max3232 | TSSOP16 |
| U28 | ETC1-1-1_ETC5_ETC1-1-1 | ETC1-1-1 | ETC5 |
| U29 | TCM811TERCTR_TCM811TERCTR_TCM81 | TCM811TERCTR | TCM811TERCTR |
| U31 | TPS7A7002_SO8_PAD_TPS7A7002 | TPS7A7002 | SO8_PAD |
| U32 | TPS7A7002_SO8_PAD_TPS7A7002 | TPS7A7002 | SO8_PAD |
| X1 | OSC_OSC5X7_50MHZ | 50MHz | OSC5X7 |
| X2 | OSC_OSC5X7_33.33MHZ | 33.33MHz | OSC5X7 |
| Y1 | CRYSTAL_CRYSTAL_25MHZ | 25MHz | CRYSTAL |
| Y4 | DSC1103AI5_DSC1103AI5_DSC1103AI | DSC1103AI5 | DSC1103AI5 |
