- #include <reg52.h>
- #include <string.h>
- #define uint unsigned int
- #define uchar unsigned char
- sbit RS=P2^0;
- sbit RW=P2^1;
- sbit EN=P2^2;
- sbit SPK=P2^7;
- uchar code KeyPad_Chars[12][6]={"1 ","2ABC","3DEF","4GHI","5JKL","6MNO","7PQRS","8TUV","9WXYZ","*","0+","#"};//初始化鍵盤字庫
- uchar code Line1[]=" LJL'S Cellphone";//固定字符串
- uchar code Line2[]="Your Key: ";
- uchar KeyNo=-1; //鍵位0~11
- uchar Inner_Idx=0; //同鍵位內部切換
- uchar tSpan=0; //同鍵位連續按鍵時間間隔
- /**********************毫秒延時************************************/
- void DelayMS(uint ms)
- uchar i;
- while(ms--)
- for(i=0;i<110;i++);
- /************************忙檢測***********************************/
- uchar Busy_Waiting()
- uchar lcd_status;
- RS=0;
- RW=1;
- EN=1;
- DelayMS(1);
- lcd_status=P0;
- EN=0;
- return lcd_status;
- /************************寫數據***********************************/
- void Write_LCD_DATA(uchar dat)
- while((Busy_Waiting()&&0x80)==0x80);
- RS=1;RW=0;EN=0;P0=dat;EN=1;DelayMS(1);EN=0;
- /************************寫指令********************************/
- void Write_LCD_Command(uchar cmd)
- while((Busy_Waiting()&0x80)==0x80);
- RS=0;
- RW=0;
- EN=0;
- P0=cmd;EN=1;DelayMS(1);EN=0;
- /*****************初始化***********************************/
- void Init_LCD()
- Write_LCD_Command(0x38);
- DelayMS(1);
- Write_LCD_Command(0x01);
- DelayMS(1);
- Write_LCD_Command(0x06);
- DelayMS(1);
- Write_LCD_Command(0x0c);
- DelayMS(1);
- /**********************鍵盤掃描************************************/
- void Keys_Scan()
- P1=0x0f; //高四位置0
- DelayMS(1);
- switch(P1) //判斷列
- case 0x0e: KeyNo=0;break;
- case 0x0d: KeyNo=1;break;
- case 0x0b: KeyNo=2;
- P1=0xf0; //第四位置0
- DelayMS(1);
- switch(P1) //根據行數加KN
- case 0xe0: KeyNo+=0;break;
- case 0xd0: KeyNo+=3;break;
- case 0xb0: KeyNo+=6;break;
- case 0x70: KeyNo+=9;
- /**********************蜂鳴器**************************************/
- void Beep()
- SPK=1;
- DelayMS(400);
- SPK=0;
- /**********************主程序**************************************/
- void main()
- uchar i,Pre_KeyNo=-1;
- IE=0x82;
- TMOD=0x01;
- TH0=-50000/256;
- TL0=-50000%256;
- P0=P2=0xff;
- SPK=0;
- DelayMS(10);
- Init_LCD(); //初始化
- Set_LCD_POS(0); //顯示第一行
- for(i=0;i<16;i++)
- Write_LCD_DATA(Line1[i]);
- Set_LCD_POS(0x40); //顯示第二行
- for(i=0;i<16;i++)
- Write_LCD_DATA(Line2[i]);
- while(1)
- P1=0xf0;
- if(P1!=0xf0)Keys_Scan();//按鍵檢測
- else continue;
- if(Pre_KeyNo!=KeyNo) //新按鍵判斷
- Pre_KeyNo=KeyNo;
- tSpan=0; //間隔請0
- Inner_Idx=0; //按鍵內部切換清0
- TR0=1; //啟動定時器
- else //如為同一按鍵
- if(tSpan<=40)
- Inner_Idx=(Inner_Idx+1)%strlen(KeyPad_Chars[KeyNo]); //顯示下一個
- else
- Inner_Idx=0;
- tSpan=0;
- Set_LCD_POS(0x4b);
- Write_LCD_DATA(KeyPad_Chars[KeyNo][Inner_Idx]); //顯示按鍵
- Beep();
- DelayMS(100);
