查看: 1439|回復(fù): 0
單片機矩陣鍵盤程序
ID:659654 發(fā)表于 2019-12-12 09:16 | 顯示全部樓層 |閱讀模式
#include<reg51.h>
#define KEYPORT P2
sbit line0=KEYPORT^0;
sbit line1=KEYPORT^1;
sbit line2=KEYPORT^2;
sbit line3=KEYPORT^3;
led[]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};
bit iskeyinput()
KEYPORT=0x0f;
if((KEYPORT&0x0f)==0x0f)
return 0;
return 1;
uchar key_identify()
uchar linecode=0,rowcode=0;
uchar i;
uchar scancode=0xef;
for(i=0;i<4;i++)
KEYPORT=scancode;
rowcode++;
scancode=scancode<<1|1;}
if(line0==0)linecode=0;
if(line1==0)linecode=4;
if(line2==0)linecode=8;
if(line3==0)linecode=12;
break;
return linecode+rowcode;
void wait_key_release()
KEYPORT=0x0f;
break;
void display(uchar n)
if(n<8)
P0=led[n];
P1=0xff;
P0=0xff;
P1=led[n-8];
int main(void)
uchar keycode;
unsigned int i;
while(!iskeyinput());
for(i=0;i<500;i++);
if(iskeyinput())
keycode=key_identify();
wait_key_release();
display(keycode);
參與人數(shù) 1黑幣 +50 收起 理由
