查看: 9232|回復: 21
51單片機電子琴制作 附Proteus仿真圖+程序+視頻等資料
ID:436996 發表于 2019-12-7 11:07 | 顯示全部樓層 |閱讀模式
一款簡單的單片機DIY小制作
視頻教程:
制作出來的實物圖如下:
  1. #include <reg51.h>
  2. #include <absacc.h>
  3. #include <stdio.h>
  4. #include <math.h>                 //頭文件
  5. #define uchar unsigned char
  6. #define uint unsigned int          //宏定義
  7. uchar STH0;                                  //定時器變量
  8. uchar STL0;                                  //定時器變量
  9. bit FY=0;                                         //模式變量,為0時彈奏模式,為1時播放模式
  10. uchar Song_Index=0,Tone_Index=0;//單首歌曲音符數
  11. uchar k, key;                                         //k:按鍵數值變量。key:按鍵的鍵值(也就是有按鍵按下時的P0口狀態)
  12. sbit SPK=P3^7 ;                                 //定義喇叭的接口
  13. sbit LED1=P3^5;
  14. sbit LED2=P3^4;                                 //定義兩個LED的接口
  15. uchar code DSY_CODE[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,//數碼管顯示的數組(1 2 3 4 5 6 7 8 9)
  16.                                                 0x88,0x83,0xc6,0xa1,0x86,0x8e,0x89,0xa3,0x8c,0xc8};        //(A B C D E F H O P N)
  17. unsigned char code num1[]=                        "   Music:       ";
  18. uchar code Song[][100]=         //內置音樂數組,song【歌曲序號】【音符順序】
  19. {
  20.         //        1        2        3        4        5        6        7
  21.         //        8        9        10        11        12        13        14
  22.         //        15        16        17        18        19        20        21
  23.         {12,10,9,9,10,8,9,10,
  24.         12,10,9,9,5,10,11,10,
  25.         10,10,14,10,9,8,7,8,
  26.         9,10,13,6,8,10,9,6,
  27.         8,7,5,6,12,10,9,9,
  28.         9,10,8,9,10,12,10,9,
  29.         9,9,5,10,11,10,10,10,
  30.         14,10,9,8,7,8,9,10,
  31.         13,6,8,10,9,6,8,7,
  32.         5,6,-1},                                 //煙花易冷
  33.         {13,12,10,12,15,13,
  34.         12,13,10,12,13,12,10,8,6,12,
  35.         10,9,9,10,12,12,13,10,9,
  36.         8,12,10,9,8,6,8,5,-1},//世上只有媽媽好
  37.         {10,10,11,10,9,8,9,12,9,9,
  38.         8,8,9,8,7,6,7,10,7,7,
  39.         6,9,10,9,8,6,5,9,10,9,
  40.         8,6,6,9,10,9,8,6,7,8,-1}, //當你孤單你會想起誰
  41.
  42.         {5,3,5,8,6,8,
  43.         5,5,1,2,3,2,1,2,5,
  44.         3,5,8,7,6,8,5,5,2,
  45.         3,4,0,1,6,8,8,7,6,
  46.         7,8,6,7,8,6,6,5,3,
  47.         1,2,5,3,5,8,7,6,8,
  48.         5,5,2,3,4,0,1,-1},                 //送別
  49.         {5,6,8,6,6,5,6,5,3,5,
  50.         5,6,8,6,6,5,6,5,6,1,
  51.         1,2,3,2,2,2,1,2,1,6,
  52.         3,2,5,6,8,6,6,5,6,5,
  53.         6,1,1,2,3,4,4,5,6,6,
  54.         5,6,8,6,8,6,5,5,1,6,
  55.         5,5,6,8,3,2,3,1,-1},           //最浪漫的事
  56.         {5,9,10,9,10,12,13,12,8,9,
  57.         10,13,12,10,12,12,13,15,13,12,
  58.         10,12,10,8,9,10,8,6,10,9,
  59.         12,9,10,9,10,12,13,12,8,9,
  60.         10,13,12,12,13,15,13,
  61.         12,10,12,10,8,6,10,9,8,6,
  62.         8,9,9,8,-1},                                //發如雪
  63.
  64.         {5,8,9,10,9,10,11,12,12,12,
  65.         11,10,9,5,8,9,10,11,12,12,
  66.         12,13,12,9,10,8,8,6,9,9,
  67.         10,10,8,12,8,12,8,7,8,8,6,
  68.         9,9,10,10,12,12,
  69.         12,13,12,9,10,8,
  70.         5,8,9,10,9,10,11,12,12,12,
  71.         11,10,9,5,8,9,10,9,10,11,
  72.         12,12,12,9,10,8,8,6,9,9,
  73.         10,10,8,12,8,12,12,7,8,-1},        //簡單愛
  74.         {8,9,10,8,8,9,10,8,10,11,12,10,11,12,
  75.         12,13,12,11,10,8,12,13,12,11,10,8,8,5,8,8,5,8,-1},        //兩只老虎
  76.
  77.         {5,5,6,5,8,7,
  78.         5,5,6,5,9,8,
  79.         5,5,12,10,8,7,6,
  80.         11,11,10,8,9,8,-1},                        //生日快樂
  81.         {6,8,9,10,12,10,8,9,6,8,9,10,
  82.         12,12,13,9,10,10,12,13,
  83.         12,13,15,14,13,12,13,10,8,9,10,12,8,6,
  84.         8,9,10,13,12,10,13,13,
  85.         12,11,10,9,10,12,6,8,9,8,9,
  86.         10,12,13,15,14,13,12,10,13,-1},        //讓我們蕩起雙槳
  87.         {8,8,12,12,13,13,12,
  88.         11,11,10,10,9,9,8,
  89.         12,12,11,11,10,10,9,
  90.         12,12,11,11,10,10,9,
  91.         8,8,12,12,13,13,12,
  92.         11,11,10,10,9,9,8,-1},                        //小星星
  93.         {12,10,12,10,12,10,8,9,11,10,9,12,
  94.         12,10,12,10,12,10,8,9,11,10,9,8,
  95.         9,9,11,11,10,8,12,9,11,10,9,12,
  96.         12,10,12,10,12,10,8,9,11,10,9,8,-1}, //粉刷匠
  97.         {8,9,10,11,12,12,12,11,10,
  98.         11,11,11,10,9,8,10,12,
  99.         8,9,10,11,12,12,12,11,10,
  100.         11,11,11,10,9,8,10,8,
  101.         13,13,13,12,11,12,12,12,11,10,
  102.         11,11,11,10,9,8,10,12,
  103.         13,13,13,12,11,12,12,12,11,10,
  104.         11,11,11,10,9,8,10,8,-1},                        //洋娃娃和小熊跳舞
  105.         {12,10,12,13,15,16,17,16,15,13,12,15,
  106.         17,16,15,12,17,16,15,12,
  107.         10,12,13,15,16,17,15,13,15,16,
  108.         13,13,14,13,13,17,15,14,15,13,
  109.         12,10,12,13,15,16,17,16,15,13,12,15,
  110.         17,17,17,17,15,16,16,16,16,12,
  111.         12,10,12,13,15,16,17,16,15,13,12,
  112.         15,15,-1},                                                           //小紅花
  113.         {8,9,10,11,12,10,8,15,13,11,12,12,10,
  114.         8,9,10,11,12,10,9,8,9,10,9,12,
  115.         8,9,10,11,12,10,8,15,13,11,12,10,
  116.         8,9,10,11,12,10,9,8,9,10,8,8,
  117.         15,13,11,12,12,8,15,13,11,12,10,
  118.         8,9,10,11,12,10,9,8,9,10,8,8,
  119.         15,13,11,12,12,8,15,13,11,12,10,
  120.         8,9,10,11,12,10,9,8,9,10,8,8,-1},        //小紅帽
  121.
  122.         {10,12,16,15,12,11,10,10,10,11,12,
  123.         13,12,10,12,16,15,12,11,
  124.         10,12,12,13,14,15,15,16,12,12,14,13,12,
  125.         10,12,15,13,15,16,15,14,12,10,12,
  126.         16,15,12,11,10,12,12,13,14,15,15,-1},        //雪絨花
  127. };
  128. uchar code Len[][100]= //內置音樂對應的節拍(音符持續時間)
  129. {
  130.         {1,1,2,4,1,1,1,4,
  131.         1,1,2,2,1,1,1,4,
  132.         1,1,1,1,2,1,1,1,
  133.         1,1,3,1,1,1,1,1,
  134.         1,1,1,6,1,1,2,1,
  135.         1,1,1,1,4,1,1,2,
  136.         1,1,1,1,1,4,1,1,
  137.         3,1,2,1,1,1,1,1,
  138.         3,1,1,1,1,1,1,2,
  139.         2,6,-1},
  140.         {3,1,2,2,2,1,
  141.         1,4,2,1,1,2,2,1,1,1,
  142.         1,4,3,1,2,1,1,2,2,
  143.         4,3,1,1,1,1,1,6,-1},
  144.         {2,1,1,2,1,1,2,2,2,3,
  145.         2,1,1,2,1,1,2,2,2,3,
  146.         2,1,1,1,1,2,2,1,1,1,
  147.         1,2,2,1,1,1,1,1,1,6,-1},
  148.
  149.         {2,3,1,3,2,2,
  150.         4,2,1,1,2,1,1,4,2,
  151.         1,1,2,1,2,2,4,2,1,
  152.         1,2,1,4,2,2,4,2,1,
  153.         1,4,1,1,1,1,1,1,1,
  154.         1,8,2,1,1,2,1,2,2,
  155.         4,2,1,1,2,2,4,-1},
  156.         {1,1,1,2,1,1,1,1,1,5,
  157.         1,1,1,2,1,1,1,1,1,5,
  158.         1,1,1,1,1,1,1,1,1,1,
  159.         2,3,1,1,1,2,1,1,1,1,
  160.         1,5,1,1,1,2,1,1,1,1,
  161.         1,2,1,3,1,1,1,4,1,1,
  162.         5,1,1,1,1,1,1,6,-1},
  163.         {1,1,2,1,1,1,1,3,1,1,
  164.         1,1,1,1,3,1,1,2,1,1,
  165.         1,1,2,1,1,1,1,1,1,1,
  166.         1,1,2,1,1,1,1,3,1,1,
  167.         1,1,3,1,1,2,1,
  168.         1,1,1,2,1,1,1,1,1,1,
  169.         1,1,1,4,-1},
  170.         {1,1,1,1,1,1,1,1,1,1,
  171.         1,1,3,1,1,1,1,1,1,1,
  172.         1,1,2,1,1,2,1,1,1,1,
  173.         1,1,1,1,1,1,1,1,1,1,1,
  174.         1,1,1,1,1,1,
  175.         1,1,2,1,1,2,
  176.         1,1,2,1,1,1,1,1,1,1,
  177.         1,1,3,1,1,1,1,1,1,1,
  178.         1,1,2,1,1,2,1,1,1,1,
  179.         1,1,2,1,1,1,1,1,1,-1},
  180.
  181.         {2,2,2,2,2,2,2,2,2,2,4,2,2,4,
  182.         1,1,1,1,2,2,1,1,1,1,2,2,2,2,4,2,2,4,-1},
  183.         {1,1,2,2,2,4,
  184.         1,1,2,2,2,4,
  185.         1,1,2,2,2,2,2,
  186.         1,1,2,2,2,4,-1},
  187.         {1,1,1,3,1,1,1,2,4,1,1,1,
  188.         3,1,2,2,4,1,1,4,
  189.         3,1,1,1,1,1,1,2,1,1,3,1,2,2,
  190.         1,1,1,1,5,4,3,1,
  191.         1,1,2,4,3,1,1,1,3,1,1,
  192.         2,2,2,2,1,1,1,1,4,-1},
  193.         {2,2,2,2,2,2,3,
  194.         2,2,2,2,2,2,3,
  195.         2,2,2,2,2,2,3,
  196.         2,2,2,2,2,2,3,
  197.         2,2,2,2,2,2,3,
  198.         2,2,2,2,2,2,4,-1},
  199.         {1,1,1,1,1,1,2,1,1,1,1,2,
  200.         1,1,1,1,1,1,2,1,1,1,1,2,
  201.         1,1,1,1,1,1,2,1,1,1,1,2,
  202.         1,1,1,1,1,1,2,1,1,1,1,3,-1},
  203.         {1,1,1,1,1,1,1,1,1,
  204.         1,1,1,1,1,1,1,2,
  205.         1,1,1,1,1,1,1,1,1,
  206.         1,1,1,1,1,1,1,2,
  207.         1,1,1,1,1,1,1,1,1,2,
  208.         1,1,1,1,1,1,1,2,
  209.         1,1,1,1,1,1,1,1,1,1,
  210.         1,1,1,1,1,1,1,3,-1},
  211.         {1,1,1,1,1,1,2,1,1,1,1,4,
  212.         2,1,1,4,2,1,1,4,
  213.         2,1,1,2,2,1,1,1,1,4,
  214.         2,1,1,3,1,1,1,1,1,4,
  215.         1,1,1,1,1,1,2,1,1,1,1,4,
  216.         1,1,1,1,4,1,1,1,1,4,
  217.         1,1,1,1,1,1,2,1,1,1,1,
  218.         4,4,-1},
  219.         {1,1,1,1,2,1,1,2,1,1,1,1,2,
  220.         1,1,1,1,1,1,1,1,2,2,2,2,
  221.         1,1,1,1,2,1,1,2,1,1,2,2,
  222.         1,1,1,1,1,1,1,1,2,2,2,2,
  223.         2,1,1,1,1,2,2,1,1,2,2,
  224.         1,1,1,1,1,1,1,1,2,2,2,2,
  225.         2,1,1,1,1,2,2,1,1,2,2,
  226.         1,1,1,1,1,1,1,1,2,2,2,2,-1},
  227.         {2,2,4,2,2,4,2,2,1,1,2,
  228.         4,4,2,2,4,2,2,4,
  229.         2,2,1,1,2,4,4,4,1,2,1,1,2,
  230.         2,2,4,2,2,2,2,4,4,2,2,
  231.         4,2,2,4,2,2,1,1,1,4,4,-1}
  232. };
  233. uint code tab[]={         //內置16個音符彈奏和播放時都是調用此數組內的數據用于定時器初值
  234.         63500,        //超低音 si
  235.         63628,63835,64021,64103,64260,64400,64524,          //低音do-si
  236.         64580,64684,64777,64820,64898,64968,65030,          //           do-si
  237.         65058,65110,65157,65178,65217,65252,65283,         //高音do-si
  238.         65313 };        //超高音do
  239. void delay1 (uint ms)      //粗略1ms延時函數,不精確
  240. {
  241.         uchar t;
  242.         while (ms--)
  243.         for(t=0;t<120;t++);
  244. }
  245. void delay(void)
  246. {
  247.         uchar i;
  248.         for (i=300;i>0;i--);
  249. }
  250. uchar getkey(void)                                  //矩陣按鍵掃描函數
  251. {
  252.         uchar scancode,tmpcode;
  253.         if((P1&0xf0)==0xf0)                         //無按鍵按下時此表達式成立
  254.         return (0);                                         //此函數返回值為0
  255.         scancode = 0xfe;                          //如果上面的if表達式不成立,此語句才可以執行
  256.         while((scancode&0x10)!=0)    //有按鍵按下時,此表達式成立
  257.         {
  258.                 P1=scancode;                           //將P0口賦值
  259.                 if((P1&0xf0)!=0xf0)           //判斷P0口的狀態
  260.                 {
  261.                         tmpcode = (P1&0xf0)|0x0f;                 //P0口的狀態與上0xf0,然后或上0x0f
  262.                         return((~scancode)+(~tmpcode));         //將兩個變量的值取反相加后返回此函數
  263.                 }
  264.                 else scancode=(scancode<<1)|0x01;           //如果上面的if語句不成立,將scancode左移一位
  265.         }
  266.         return(0xff);
  267. }
  268. void anjian()                                 //按鍵鍵值識別
  269. {
  270.         P1=0xf0;                                 //P1口賦值
  271.         if((P1&0xf0)!=0xf0)            //判斷是否有按鍵按下
  272.         {
  273.                 delay();                      //去抖
  274.                 if((P1&0xf0)!=0xf0)  //再次判斷有無按鍵按下
  275.                 {
  276.                         key=getkey();         //掃描按鍵
  277.                         Tone_Index=0;    //播放音符順序清零
  278.                         switch(key)            //根據掃描的按鍵編碼將k賦值
  279.                         {
  280.                                 case 0x88:         //按鍵編碼為0x88
  281.                                 k = 0;                 //k賦值0
  282.                                 break;                  //已經確定鍵值后提前跳出switch
  283.                                 case 0x48:   //如果不滿足上一個case則繼續向下判斷,直到有符合
  284.                                 k = 1;                  //k賦值1
  285.                                 break;       //下同,略
  286.                                 case 0x28:
  287.                                 k = 2 ;
  288.                                 break;
  289.                                 case 0x18:
  290.                                 k = 3 ;
  291.                                 break;
  292.                                 case 0x84:
  293.                                 k = 4 ;
  294.                                 break;
  295.                                 case 0x44:
  296.                                 k = 5 ;
  297.                                 break;
  298.                                 case 0x24:
  299.                                 k = 6 ;
  300.                                 break;
  301.                                 case 0x14:
  302.                                 k = 7 ;
  303.                                 break;
  304.                                 case 0x82:
  305.                                 k = 8 ;
  306.                                 break;
  307.                                 case 0x42:
  308.                                 k = 9 ;
  309.                                 break;
  310.                                 case 0x22:
  311.                                 k = 10 ;
  312.                                 break;
  313.                                 case 0x12:
  314.                                 k = 11 ;
  315.                                 break;
  316.                                 case 0x81:
  317.                                 k = 12 ;
  318.                                 break;
  319.                                 case 0x41:
  320.                                 k = 13 ;
  321.                                 break;
  322.                                 case 0x21:
  323.                                 k = 14 ;
  324.                                 break;
  325.                                 case 0x11:
  326.                                 k = 15 ;
  327.                                 break;
  328.                                 default :                 //如果以上都不符合,直接跳出,無鍵值輸出
  329.                                 break;
  330.                         }
  331.                 }
  332.         }
  333. }
  334. void main(void)                                                   //主函數
  335. {
  336.         SPK=0;
  337.         LED1=1;
  338.         LED2=0;                                                    //開機默認彈奏模式
  339.         P0=0xc0;                                                   //數碼管顯示0
  340.         IE=0x87;                                                   //定義外部中斷控制器
  341.         TMOD=0x01;                                                   //定義定時器0的工作方式
  342.         IT0=1;                                                           //外部中斷0為下降沿觸發
  343.         IT1=1;                                                           //外部中斷1為下降沿觸發
  344.         while(1)                                                   //進入死循環
  345.         {
  346.                 P1=0xf0;                                            //P1口賦值
  347.                 if((P1&0xf0)!=0xf0)                           //判斷P0口是否有變化
  348.                 {
  349.                         anjian();                                   //讀取鍵值
  350.                         P0=DSY_CODE[k];                           //顯示鍵值,也就是顯示音符
  351.                         if(FY==0)                                   //如果是彈奏模式
  352.                         {
  353.                                 STH0 = tab[k]/256;
  354.                                 STL0 = tab[k]%256;           //根據k的值賦初值給T0
  355.                                 TR0 = 1;               //打開定時器用于定時產生頻率發生
  356.                                 while ((P1&0xf0)!=0xf0); //按鍵不松開的話,T0就一直產生頻率
  357.                                 TR0=0;                 //按鍵松開后關閉T0計時,頻率停止
  358.                         }
  359.                         else  //如果是播放模式(上面的if語句不成立就執行else)
  360.                         {
  361.                                 while (FY==1)                                                          //進入播放模式
  362.                                 {
  363.                                         if(Song[k][Tone_Index]==-1)                  //一首播放完退出
  364.                                         {
  365.                                                 Tone_Index=0;
  366.                                                 SPK=0;
  367.                                                 break;
  368.                                         }
  369.                                         STH0=(tab[Song[k][Tone_Index]])/256;
  370.                                         STL0=(tab[Song[k][Tone_Index]])%256; //將內置音樂數組的數據賦給定時器做為初值計時
  371.                                 //        P0=DSY_CODE[Song[k][Tone_Index]];          //顯示播放的音符
  372.                                         TR0 = 1;                                                          //打開定時器定時開關
  373.                                         delay1(300*Len[k][Tone_Index]);          //節拍數組延時
  374.                                         Tone_Index++;                                                  //變量加準備播放下一個音符
  375.                                         TR0=0;        //停止定時器
  376.                                         anjian();                                                         //掃描按鍵
  377.                                         P0=DSY_CODE[k];                                                 //顯示音樂序號
  378.                                         while((P1&0xf0)!=0xf0);
  379.                                 }
  380.                         }
  381.                 }
  382.         }
  383. }
  384. void EXO_IXT() interrupt 0                  //外部中斷0
  385. {
  386.         FY=0;                                                  //彈奏模式
  387.         LED1=1;
  388.         LED2=0;                                                  //點亮彈奏模式指示燈
  389.         Tone_Index=0;                                  //歌曲音符序號清零,以便于下次播放內置音樂時從頭播放
  390. }
  391. void EX1_INT() interrupt 2                  //外部中斷1
  392. {
  393.         FY=1;                                                  //播放模式
  394.         LED1=0;                                                  //點亮播放模式指示燈
  395.         LED2=1;
  396. }
  397. void time0_int(void) interrupt 1 using 0   //定時器0
  398. {
  399.         TH0 = STH0;                                   //定時器賦初值
  400.         TL0 = STL0;
  401.         SPK=!SPK;                             //喇叭引腳取反,產生頻率的音樂
  402. }
電子琴.7z (6.46 MB, 下載次數: 389)
限于篇幅其余資料在壓縮包中,含視頻等
參與人數 2黑幣 +56 收起 理由
炸天幫二哈 + 6 很給力!
ID:328014 發表于 2019-12-10 01:13 | 顯示全部樓層
好資料,51黑有你更精彩!!!
ID:328014 發表于 2019-12-10 01:14 | 顯示全部樓層
好資料,51黑有你更精彩!!!
ID:657933 發表于 2019-12-27 22:50 | 顯示全部樓層
好資料,51黑有你更精彩!!!
ID:897709 發表于 2021-3-28 17:11 | 顯示全部樓層
好資料,51黑有你更精彩!!!
ID:923677 發表于 2021-5-19 19:04 | 顯示全部樓層
實驗板一定要用這個嗎?
ID:236196 發表于 2021-6-9 14:16 | 顯示全部樓層
好資料,51黑有你更精彩
ID:635085 發表于 2021-12-3 21:49 | 顯示全部樓層
好資料,51黑有你更精彩!!!
好資料,51黑有你更精彩!!!
ID:988176 發表于 2021-12-6 16:23 | 顯示全部樓層
好資料,51黑有你更精彩!!!
ID:988717 發表于 2021-12-6 17:03 | 顯示全部樓層
好資料,51黑有你更精彩
ID:590050 發表于 2021-12-6 17:07 | 顯示全部樓層
好資料,51黑有你更精彩!!!
ID:990070 發表于 2021-12-9 14:38 | 顯示全部樓層
好資料,51黑有你更精彩
ID:991603 發表于 2021-12-13 12:22 來自觸屏版 | 顯示全部樓層
好資料,51黑有你更精彩!!! 回復
ID:1030998 發表于 2022-5-31 17:38 | 顯示全部樓層
牛啊這四百多行
ID:943462 發表于 2022-6-7 00:14 來自觸屏版 | 顯示全部樓層
膜拜大佬
ID:1032926 發表于 2022-6-7 16:43 | 顯示全部樓層
好資料,51黑有你更精彩!!!
ID:1123976 發表于 2024-6-6 17:39 | 顯示全部樓層
好資料,51黑有你更精彩!!!
ID:1124454 發表于 2024-6-9 22:31 | 顯示全部樓層
博主太頂了!!!
ID:36322 發表于 2024-6-12 10:24 | 顯示全部樓層
這個很給力啊,資料很詳細
ID:1125843 發表于 2024-6-19 14:40 | 顯示全部樓層
好資料,51黑有你更精彩!!!
ID:1126090 發表于 2024-6-19 20:32 | 顯示全部樓層
哇,真的好厲害很有用
