查看: 8885|回復: 13
單片機LRC萬用表表制作程序+PCB文件
ID:646125 發表于 2019-12-6 20:13 | 顯示全部樓層 |閱讀模式
希望可以幫助你們
  1. #include <reg52.h>
  3. #define uint  unsigned        int
  4. #define C1  0.045
  5. uchar code WenDu1[]="數\xfd字萬用表   ";
  6. uchar code WenDu2[]="歡迎使用        ";
  7. uchar code code_L[]="電感:          ";
  8. uchar code code_R[]="電阻:          ";
  9. uchar code code_C[]="電容:          ";
  10. uchar code code_e[]="錯誤:          ";
  11. uchar  num;
  12. sbit key1  =P1^0;
  13. sbit key2  =P1^1;
  14. sbit key3  =P1^2;
  15. //unsigned long LZ=0;
  16. //float f=0;
  17. float LZ=0;
  18. float RX=0;
  19. float CX=0;
  20. float f=0;
  21. float temp_f[4];
  22. unsigned int tt,th1,tl1;
  23. unsigned int pluse=0;
  24. bit flag=0;
  25. unsigned char key_num=0;
  26. #define  L 1
  27. #define  R 2
  28. #define  C 3
  29. sbit aa1 =P2^0;
  30. sbit bb1 =P2^1;
  31. #include<Lcd12864.h>
  32. void cd4051(unsigned char num)
  33. {
  34.                 switch(num){
  35.                                 case 1: bb1=0;aa1=0;break;
  36.                                 case 2: bb1=0;aa1=1; break;
  37.                                 case 3: bb1=1;aa1=0; break;
  38.                                 default : aa1=1;aa1=1;break;
  39.                 }
  40. }
  41. void scan_key()
  42. {
  43.                 if(!key1){
  44.                                 if(!key1){
  45.                                                 while(!key1);
  46.                                                 key_num=1;
  47.                                                 cd4051(L);
  48.                                         //        aa1=0;bb1=0;
  49.                                             Lcd_ShowSring(4,0,code_L);
  50.                                                 Lcd_ShowSring(1,15,"L");
  51.                                 }
  52.                 }
  53.                 if(!key2){
  54.                                 if(!key2){
  55.                                                 while(!key2);
  56.                                                 key_num=2;
  57.                                                 cd4051(R);
  58.                                         //aa1=0;bb1=1;
  59.                                                 Lcd_ShowSring(4,0,code_R);
  60.                                                 Lcd_ShowSring(1,15,"R");
  61.                                 }
  62.                 }
  63.                 if(!key3){
  64.                                 if(!key3){
  65.                                                 while(!key3);
  66.                                                 key_num=3;
  67.                                                 cd4051(C);
  68.                                            //aa1=1;bb1=0;
  69.                                                 Lcd_ShowSring(4,0,code_C);
  70.                                                 Lcd_ShowSring(1,15,"C");
  71.                                 }
  72.                 }
  73. }
  74.         //中斷初始化
  75.   void init()
  76.   {
  77. //        TMOD=0x11;                //定時器0和定時器1都是方式1,16位定時器
  78.         //定時器設置
  79.     TMOD=0x51;                 //設置定時器0,方式1:16位定時器
  80.         TH1=0x00;         //定時器1高位裝初值
  81.         TL1=0x00;         //定時器1低位裝初值
  82.         ET1=1;        //定時器1          使能位
  83.
  84.         TH0=(65535-50000)/255;          //定時器1高位裝初值
  85.         TL0=(65535-50000)%255;;          //定時器1高位裝初值
  86.         ET0=1;   ////定時器0          使能位
  87.         TR0=1;
  88.         TR1=1;
  89.         EA=1;//        總中斷
  90. }
  91. void Measurement_L();//電感測量
  92. void Measurement_R();//電阻測量
  93. void Measurement_C();//電容測量
  94. unsigned char gather_num=0;
  95. unsigned char m_second=0;
  96. void main ()
  97. {
  98.         LCDInit();
  99.         Lcd_ShowSring(1,0,WenDu1);
  100.         Lcd_ShowSring(2,0,WenDu2);
  101. //        Lcd_ShowSring(4,0,code_R);
  102.         init();
  103. //        cd4051(R);
  104. //        key_num=2;
  105.         while(1){
  106.
  107.
  108.             scan_key();
  109.                 if(flag){
  110.                         flag=0;
  111.                         //在十ms里面記了這么多個脈沖
  112.                         // 那么一個脈沖的周期就是  50ms/tt/1000  (s)   化簡得到  f  20tt
  113.                         if(gather_num<4) {
  114.                                         temp_f[gather_num]=pluse*65536+256*TH1+TL1;          //1000000000000 12  100000000 8
  115.                                         gather_num++;
  116.                         }
  117.                         else{
  118.                                         gather_num=0;
  119.                                         f=(temp_f[0]+temp_f[1]+temp_f[2]+temp_f[3])/4.0;
  120.                                 //        Lcd_Display(3,0,f);
  121.                                         switch(key_num)         {
  122.
  123.                                                         case 1:Measurement_L();        break;
  124.                                                         case 2:Measurement_R(); break;
  125.                                                         case 3:Measurement_C(); break;
  126.                                                         default :break;
  127.
  128.                                         }
  129.                         }
  130.
  131.                         TH0=(65535-50000)/255;          //定時器1高位裝初值
  132.                         TL0=(65535-50000)%255;;          //定時器1高位裝初值
  133.                         TH1=0;                          //清零開始重新計數
  134.                         TL1=0;
  135.                         pluse=0;
  136.                         TR0=1;//開定時器計時10ms;//使能位外部中斷0 數10內有多少個脈沖
  137.                         TR1=1;//進行新一輪的計數
  138.                         m_second=0;
  139.
  140.
  141. //                    num++;
  142. //                        Lcd_Display(4,4,num);
  143.                 }
  144.
  145.         }
  146. }
  147. void time0()interrupt 1                //定時器0 服務
  148. {
  149. //        TR1=0;//關掉定時器1
  150.
  151. //        TH0=(65535-50000)/255;          //定時器1高位裝初值
  152. //        TL0=(65535-50000)%255;;          //定時器1高位裝初值 */
  153.         TH0=60;          //定時器1高位裝初值
  154.         TL0=235;;          //定時器1高位裝初值
  155.         m_second++;
  156.         if(m_second==20){
  157.                         TR1=0;//關掉定時器1
  158.                         TR0=0; // 關掉定時器0
  159.                 m_second=0;
  160.                 flag=1;
  161.         }
  162.
  163. }
  164. void time1()interrupt 3                //定時器1 服務
  165. {
  166.                    pluse++;
  167.                 TH1=0;
  168.                 TL1=0;
  169. }
  170. void Measurement_L()
  171. {
  172.                         if(f==0){
  173.                                 LZ=0;
  174.                                 Lcd_ShowSring(4,0,code_L);
  175.                         }
  176.                         else {
  177.                                 LZ=5.63466627*10e10/f/f;
  178.                                 LZ=LZ/1.0727272727272727272727272727273;
  179.                                 Lcd_ShowSring(4,0,"電感:");
  180.                           Lcd_Display_u(4,4,LZ);
  181.                         }
  182.
  183.                         if(LZ>99999999)        {
  184.                         //         Lcd_ShowSring(4,0,code_e);
  185.                         }
  186.
  187.
  188.
  189. }
  190. void Measurement_R()//電阻測量
  191. {
  192.
  193.                         if(f==0){
  194.
  195.                                         RX=0;
  196.
  197.                         }
  198.                         else if(  0< f&& f<30) {        //1M   7
  199.                                            RX=        14400000.0/f;
  200.                                         RX= RX-3000;
  201.                                         RX  =RX/2/0.95;  //修正
  202.
  203.                         }
  204.                         else if(f <700) {        //10k   650
  205.                                            RX=        14400000.0/f;
  206.                                         RX= RX-3000;
  207.                                         RX  =RX/2/0.95;  //修正
  208.                                          //
  209.                         }
  210.                         else if(f <1500) {        //4.7k  1209
  211.                                            RX=        14400000.0/f;
  212.                                         RX= RX-3000;
  213.                                         RX  =RX/2/0.94;  //修正
  214.
  215.                         }
  216.                          else if(f <3000) {        //1k        2983
  217.                                            RX=        14400000.0/f;
  218.                                         RX= RX-3000;
  219.                                          RX  =RX/2/0.91;  //修正
  220.                                         //0.91286863270777479892761394101877
  221.
  222.                         }
  223.                         else if(f <4500) {
  224.                                            RX=        14400000.0/f;
  225.                                         RX= RX-3000;
  226.        //修正  200   4372
  227.                                         RX  =RX/2/0.74;  //修正
  228.
  229.                         }
  230.                         else if(f <5000) {
  231.                                            RX=        14400000.0/f;
  232.                                         RX= RX-3000;
  233.        //修正  100
  234.                                         RX  =RX/2/0.50;  //修正
  235.
  236.                         }
  237.                         if(RX==0){
  238.                                         Lcd_ShowSring(4,0,code_R);
  239.                         } else{
  240.                                         Lcd_ShowSring(4,0,"電阻:");
  241.                                         Value_to_ASCII1(4,3, RX);
  242.                         }
  243.                         if(RX>99999999)        {
  244.                         //        Lcd_ShowSring(4,0,code_e);
  245.                         }
  246.
  247.
  248. }
  249. void Measurement_C()//C測量
  250. {
  251.                         if(f==0){
  252.
  253.                                         CX=0;
  254.                                         Lcd_ShowSring(4,0,code_C);
  255.                         }
  256.                         else if(f>5000){
  257.                                    CX=0;
  258.                                    Lcd_ShowSring(4,0,code_C);
  259.                         }
  260.                         else {
  261.                                 CX=48100.00/f/1.0276595744680851063829787234043;//修正
  262.                                 Lcd_ShowSring(4,0,"電容:");
  263.                             Value_to_ASCIIC(4,3,CX);
  264.                         }
  265. //                        Lcd_ShowSring(4,0,"電容:");
  266. //                        Value_to_ASCIIC(4,3,CX);
  267.                         if(CX>99999999)        {
  268. //                                Lcd_ShowSring(4,0,code_e);
  269.                         }
  270.
  271. }
程序.7z (1.16 MB, 下載次數: 153)
ID:770983 發表于 2020-7-17 09:36 | 顯示全部樓層
這個屏是什么型號啊?
ID:228467 發表于 2020-7-17 10:17 | 顯示全部樓層
CHENGLCD 發表于 2020-7-17 09:36
這個屏是什么型號啊?
應該就是普通的12864屏吧
ID:603592 發表于 2020-7-17 12:19 | 顯示全部樓層
兩個PCB 下面的是什么的
ID:804703 發表于 2020-7-17 13:31 | 顯示全部樓層
這個屏是什么型號啊?
ID:25481 發表于 2020-7-18 08:15 | 顯示全部樓層
ST7920串口12864,帶字庫。
ID:690831 發表于 2020-7-18 13:38 | 顯示全部樓層
測頻率,計算LCR值嗎
ID:795427 發表于 2022-1-16 11:12 | 顯示全部樓層
雖然沒有電容的ESR值測量,但是還是很不錯的。
ID:655665 發表于 2022-1-16 14:56 | 顯示全部樓層
電感 電容  電阻的測量范圍是多少?
ID:969272 發表于 2022-1-17 18:43 | 顯示全部樓層
這個表準確嗎?
ID:1016543 發表于 2022-4-8 11:55 | 顯示全部樓層
范圍是多少啊大佬,我是小白
ID:1016543 發表于 2022-4-8 12:00 | 顯示全部樓層
我在東北玩51 發表于 2020-7-17 12:19
兩個PCB 下面的是什么的
背面走線。。。。。
ID:228452 發表于 2022-4-11 22:23 | 顯示全部樓層
What is the value of inductor LX1 ?
Thanks for the code
ID:67185 發表于 2022-11-30 12:11 | 顯示全部樓層
這不是電橋原理吧!
