通過adc0832讀取PT100電壓值數(shù)碼管顯示-50——100度的范圍非常準確,程序及仿真。
仿真原理圖如下(proteus7.5仿真工程文件可到本帖附件中下載)
2019-12-10 00:29 上傳
2019-12-10 00:30 上傳
2019-12-10 00:30 上傳
- #include<reg51.h>
- #include<math.h>
- #define uchar unsigned char
- #define uint unsigned int
- sbit cs=P1^2;
- sbit clk=P1^0;
- sbit di=P1^1;
- uchar num,num1,i,a,b,c;
- int wendu;
- sbit we = P2^7; //位定義數(shù)碼管位選鎖存器接口
- sbit du = P2^6; //位定義數(shù)碼管段選鎖存器接口
- //數(shù)碼管段選表
- uchar code leddata[]={
- 0x3F, //"0"
- 0x06, //"1"
- 0x5B, //"2"
- 0x4F, //"3"
- 0x66, //"4"
- 0x6D, //"5"
- 0x7D, //"6"
- 0x07, //"7"
- 0x7F, //"8"
- 0x6F, //"9"
- 0x40, //"-"
- 0x00, //熄滅
- 0x00 //自定義
- void delay(uint x)
- uchar y;
- for(;x>0;x--)
- for(y=110;y>0;y--);
- uchar ADC0832()
- cs=1;
- clk=0;
- cs=0;
- di=1;
- clk=1;
- clk=0;
- di=1;
- clk=1;
- clk=0;
- di=0;
- clk=1;
- clk=0;
- di=1;
- for(i=0;i<8;i++)
- clk=1;
- clk=0;
- num=num<<1;
- num|=(uchar)di;
- cs=1;
- return num;
- void main()
- while(1)
- ADC0832();
- if(num<=38)
- wendu=num-69;
- if(num>38&&num<=70)
- wendu=num-70;
- if(num>70)
- wendu=num-71;
- if(wendu>=0)
- a=wendu/100;
- b=wendu%100/10;
- c=wendu%10;
- if(a>0)
- P0 = 0xfd;//1111 1101 只選通第二位數(shù)碼管
- we = 1; //打開位選
- we = 0; //關(guān)閉位選
- P0 = leddata[a]; //顯示2
- du = 1;//打開段選
- du = 0; //關(guān)閉段選
- delay(2);//延時
- if(a!=0||b>0)
- P0 = 0xfb;// 1111 1011只選通第三位數(shù)碼管
- we = 1; //打開位選
- P0 = leddata[b]; //顯示3
- du = 1;//打開段選
- delay(2);//延時
- P0 = 0xf7;//1111 0111 只選通第四位數(shù)碼管
- we = 1; //打開位選
- P0 = leddata[c]; //顯示4
- du = 1;//打開段選
- delay(2);//延時
- else
- num1=abs(wendu);
- a=num1/100;
- b=num1%100/10;
- c=num1%10;
- if(num1>9)
- we = 1; //打開位選
- P0 = leddata[10]; //顯示2
- du = 1;//打開段選
- delay(2);//延時
- else
- we = 1; //打開位選
- P0 = leddata[10]; //顯示3
- du = 1;//打開段選
- delay(2);//延時
- if(a>0)
- we = 1; //打開位選
- du = 1;//打開段選
- delay(2);//延時
- if(a!=0||b>0)
- we = 1; //打開位選
- du = 1;//打開段選
- delay(2);//延時
- we = 1; //打開位選
- du = 1;//打開段選
- delay(2);//延時
2019-12-10 00:31 上傳
Keil代碼與Proteus7.5仿真dsn文件下載:
pt100.zip
(106.81 KB, 下載次數(shù): 427)
2019-12-6 19:36 上傳
下載積分: 黑幣 -5
