查看: 3364|回復: 0
四人搶答器VHDL編寫程序控制Quartus II
ID:422604 發表于 2019-11-27 08:49 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
entity sirenqiangda is
     port(rst,rst2,clk,en,en1,ta,tb,lad,a,b,c,d,stop,add:in std_logic;
          ring,warn:out std_logic;
          digit1,digit2:out std_logic_vector(3 downto 0);
          a_out, b_out, c_out, d_out:buffer std_logic_vector(3 downto 0);
          states:buffer std_logic_vector(3 downto 0));
end sirenqiangda;
architecture one of sirenqiangda is
   component qiangda is
       port(rst,clk,en,a,b,c,d:in std_logic;
            ring:out std_logic;
            state:out std_logic_vector(3 downto 0));
   end component;
   component jishu is
      port(rst,clk,en1,ta,tb,lad,stop:in std_logic;
           warn:out std_logic;
           digit1,digit2:out std_logic_vector(3 downto 0));
   end component;
   component jifen is
     port(rst2,clk,en,add:in std_logic;
          state:in std_logic_vector(3 downto 0);
          a_out, b_out, c_out, d_out:buffer std_logic_vector(3 downto 0));
   end component;
begin
      U1: qiangda port map (rst,clk,en,a,b,c,d,ring,states);
      U2: jishu   port map(rst,clk,en1,ta,tb,lad,stop,warn,digit1,digit2);
      U3: jifen   port map (rst2,clk,en,add,states,a_out, b_out, c_out, d_out);
end one;
四人搶答.rar
568.13 KB, 下載次數: 36, 下載積分: 黑幣 -5
