查看: 3157|回復: 3
ADE7758三相電能表讀寫程序和初始化 單片機程序
ID:648979 發表于 2019-11-26 14:30 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
  1. /*file name :DB_ADE7758_OREG.C*/
  2. /*Function  :Read ADE7758 register and Write ADE7758 register */
  3. #include<AM80C52.H>
  4. #include "DB_ADE7758_OREG.H"
  5. sbit DB_CS_A=0x90;
  6. sbit DB_CS_B=0x91;
  7. sbit DB_CS_C=0x92;
  8. sbit Dout=0x97;
  9. sbit Din =0x96;
  10. sbit Sclk=0x95;
  11. #define DB_X5045_CS0     P1=P1&0x0f8
  12. #define DB_ADE7758_CS1   P1=P1|0x01;P1=P1&0x0f9
  13. #define DB_LED_CS2       P1=P1|0x02;P1=P1&0x0fa
  14. #define DB_LED_CS3       P1=P1|0x03;P1=P1&0x0fb
  15. #define DB_DS1302_CS4    P1=P1|0x04;P1=P1&0x0fc
  16. #define DB_Uselct_CS     P1=P1|0x07
  17. unsigned char ADE7758_ReadData(void)
  18.   {
  19.      unsigned char ReadData;
  20.      unsigned int i;
  21.      ReadData=0x0;
  22.      Dout = 1;
  23.      for(i=0;i<8;i++)
  24.      {
  25.        ReadData=ReadData<<1;
  26.        Sclk=0;
  27.        YS();
  28.        Sclk=1;
  29.        YS();
  30.        if(Dout)
  31.        {
  32.         ReadData=ReadData | 0x01;
  33.        }
  34.        else
  35.        {
  36.         ReadData=ReadData & 0xfe;
  37.        }
  38.        YS();
  39.      }
  40.      Sclk=0;
  41.      return ReadData;
  42.   }
  43. void ADE7758_WriteDatain(unsigned char Datain)
  44.   {
  45.      unsigned char i;
  46.      unsigned char Temp_Data;
  47.      Temp_Data=Datain;
  48.      Sclk=0;
  49.      i=0;
  50.     for(i=0;i<8;i++)
  51.        {
  52.          Sclk = 1;
  53.          YS();
  54.           if((Temp_Data & 0x80)==0x80)
  55.          {
  56.            Din = 1;
  57.          }
  58.          else
  59.          {
  60.            Din = 0;
  61.          }
  62.          Sclk = 0;
  63.          YS();
  64.          Temp_Data=Temp_Data<<1;
  65.        }
  66.   }
  67. void ADE7758_InitA()
  68.   {
  69.      /*寫相應寄存器*/
  70.      /*寫12位是先寫入高4位,再寫入低8位*/
  71.      DB_ADE7758_CS1;
  72.      ADE7758_WriteDatain(0x80);
  73.      DB_Uselct_CS;
  74.      /*使能輸出脈沖*/
  75.      DB_ADE7758_CS1;
  76.      ADE7758_WriteDatain(OPMODE_W8);
  77.      ADE7758_WriteDatain(0x00);
  78.      DB_Uselct_CS;
  79.      DB_ADE7758_CS1;
  80.      ADE7758_WriteDatain(GAIN_W8);
  81.      ADE7758_WriteDatain(0x00);
  82.      DB_Uselct_CS;
  83.      /*設置VARCF為無功功率輸出脈沖*/
  84.      DB_ADE7758_CS1;
  85.      ADE7758_WriteDatain(WAVMODE_W8);
  86.      ADE7758_WriteDatain(0x00);
  87.      DB_Uselct_CS;
  88.      /*設置有功增益*/
  89.      DB_ADE7758_CS1;
  90.      ADE7758_WriteDatain(AWG_W12);
  91.      ADE7758_WriteDatain(ref[133]);
  92.      ADE7758_WriteDatain(ref[132]);
  93.      DB_Uselct_CS;
  94.      DB_ADE7758_CS1;
  95.      ADE7758_WriteDatain(BWG_W12);
  96.      ADE7758_WriteDatain(ref[135]);
  97.      ADE7758_WriteDatain(ref[134]);
  98.      DB_Uselct_CS;
  99.      DB_ADE7758_CS1;
  100.      ADE7758_WriteDatain(CWG_W12);
  101.      ADE7758_WriteDatain(ref[137]);
  102.      ADE7758_WriteDatain(ref[136]);
  103.      DB_Uselct_CS;
  104.      /*設置無功增益為默認1*/
  105.      DB_ADE7758_CS1;
  106.      ADE7758_WriteDatain(AVARG_W12);
  107.      ADE7758_WriteDatain(ref[139]);
  108.      ADE7758_WriteDatain(ref[138]);
  109.      DB_Uselct_CS;
  110.      DB_ADE7758_CS1;
  111.      ADE7758_WriteDatain(BVARG_W12);
  112.      ADE7758_WriteDatain(ref[141]);
  113.      ADE7758_WriteDatain(ref[140]);
  114.      DB_Uselct_CS;
  115.      DB_ADE7758_CS1;
  116.      ADE7758_WriteDatain(CVARG_W12);
  117.      ADE7758_WriteDatain(ref[143]);
  118.      ADE7758_WriteDatain(ref[142]);
  119.      DB_Uselct_CS;
  120.      /*設置輸出脈沖累計的是單相還是三相*/
  121.      DB_ADE7758_CS1;
  122.      ADE7758_WriteDatain(COMPMODE_W8);
  123.      ADE7758_WriteDatain(0xbC);
  124.      DB_Uselct_CS;
  125.      DB_ADE7758_CS1;
  126.      ADE7758_WriteDatain(LCYCMODE_W8);
  127.      ADE7758_WriteDatain(0x3f);
  128.      DB_Uselct_CS;
  129.      DB_ADE7758_CS1;
  130.      ADE7758_WriteDatain(LINECYC_W16);
  131.      ADE7758_WriteDatain(0x0f);
  132.      ADE7758_WriteDatain(0xff);
  133.      DB_Uselct_CS;
  134.      DB_ADE7758_CS1;
  135.      ADE7758_WriteDatain(WDIV_W8);
  136.      ADE7758_WriteDatain(0x32);
  137.      DB_Uselct_CS;
  138.      DB_ADE7758_CS1;
  139.      ADE7758_WriteDatain(VARDIV_W8);
  140.      ADE7758_WriteDatain(0x32);
  141.      DB_Uselct_CS;
  142.      DB_ADE7758_CS1;
  143.      ADE7758_WriteDatain(VADIV_W8);
  144.      ADE7758_WriteDatain(0x32);
  145.      DB_Uselct_CS;
  146.      /*設置有功輸出脈沖分頻系數*/
  147.      DB_ADE7758_CS1;
  148.      ADE7758_WriteDatain(APCFNUM_W16);
  149.      ADE7758_WriteDatain(0x00);
  150.      ADE7758_WriteDatain(0x00);
  151.      DB_Uselct_CS;
  152.      DB_ADE7758_CS1;
  153.      ADE7758_WriteDatain(APCFDEN_W12);
  154.      ADE7758_WriteDatain(ref[57]);
  155.      ADE7758_WriteDatain(ref[56]);
  156.      DB_Uselct_CS;
  157.      /*設置無功輸出脈沖分頻系數*/
  158.      DB_ADE7758_CS1;
  159.      ADE7758_WriteDatain(VARCFNUM_W16);
  160.      ADE7758_WriteDatain(0x00);
  161.      ADE7758_WriteDatain(0x00);
  162.      DB_Uselct_CS;
  163.      DB_ADE7758_CS1;
  164.      ADE7758_WriteDatain(VARCFDEN_W12);
  165.      ADE7758_WriteDatain(ref[59]);
  166.      ADE7758_WriteDatain(ref[58]);
  167.      DB_Uselct_CS;
  168.      /*相位補償*/
  169.      DB_ADE7758_CS1;
  170.      ADE7758_WriteDatain(APHCAL_W7);
  171.      ADE7758_WriteDatain(ref[144]);
  172.      DB_Uselct_CS;
  173.      DB_ADE7758_CS1;
  174.      ADE7758_WriteDatain(BPHCAL_W7);
  175.      ADE7758_WriteDatain(ref[146]);
  176.      DB_Uselct_CS;
  177.      DB_ADE7758_CS1;
  178.      ADE7758_WriteDatain(CPHCAL_W7);
  179.      ADE7758_WriteDatain(ref[148]);
  180.      DB_Uselct_CS;
  181.      /*電壓補償*/
  182.      /*DB_ADE7758_CS1;
  183.      ADE7758_WriteDatain(AVRMSOS_W12);
  184.      ADE7758_WriteDatain(ref[13]);
  185.      ADE7758_WriteDatain(ref[12]);
  186.      DB_Uselct_CS;
  187.      DB_ADE7758_CS1;
  188.      ADE7758_WriteDatain(BVRMSOS_W12);
  189.      ADE7758_WriteDatain(ref[15]);
  190.      ADE7758_WriteDatain(ref[14]);
  191.      DB_Uselct_CS;
  192.      DB_ADE7758_CS1;
  193.      ADE7758_WriteDatain(CVRMSOS_W12);
  194.      ADE7758_WriteDatain(ref[17]);
  195.      ADE7758_WriteDatain(ref[16]);
  196.      DB_Uselct_CS; */
  197.       /*電流增益*/
  198.      DB_ADE7758_CS1;
  199.      ADE7758_WriteDatain(AIGAIN_W12);
  200.      ADE7758_WriteDatain(ref[19]);
  201.      ADE7758_WriteDatain(ref[18]);
  202.      DB_Uselct_CS;
  203.      DB_ADE7758_CS1;
  204.      ADE7758_WriteDatain(BIGAIN_W12);
  205.      ADE7758_WriteDatain(ref[21]);
  206.      ADE7758_WriteDatain(ref[20]);
  207.      DB_Uselct_CS;
  208.      DB_ADE7758_CS1;
  209.      ADE7758_WriteDatain(CIGAIN_W12);
  210.      ADE7758_WriteDatain(ref[23]);
  211.      ADE7758_WriteDatain(ref[22]);
  212.      DB_Uselct_CS;
  213. }
  214. void YS()
  215. {
  216. unsigned char  i;
  217. for(i=0;i<0xff;i++);
  218. }
收藏收藏2 分享淘帖 頂 踩
ID:1 發表于 2019-11-26 14:37 | 只看該作者
本帖需要重新編輯補全電路原理圖,源碼,詳細說明與圖片即可獲得100+黑幣(帖子下方有編輯按鈕)
ID:650094 發表于 2019-11-26 17:02 | 只看該作者
我覺得還不錯
ID:421481 發表于 2019-11-26 19:10 | 只看該作者
我覺得也是
