查看: 1063|回復: 0
秒表還有四個錯誤不會改了大佬幫幫唄 求幫助
ID:612570 發(fā)表于 2019-11-24 12:12 | 顯示全部樓層 |閱讀模式
       SEC      EQU 30H        ;
       UNIT     EQU 40H        ;
       TEN      EQU 41H        ;
       ORG          0000H
       AJMP     START
       ORG          000BH     ;
       AJMP     T0INS
       ORG          0100H
START:MOV      SP,   #50H            ;
       MOV      TMOD, #01H     ;
       MOV      TH0,  #3CH    ;
       MOV      TL0,  #0B0H
       MOV      SEC,  #00H
       MOV      UNIT, #00H
       MOV      TEN,  #00H
       MOV      R7,   #20     ;
       SETB     ET0
       SETB     EA
  LOOP:LCALL    DISP
       MOV      P3,  #0FFH
       MOV      20H, P3
       LCALL    DELAY10
       MOV      A, P3
       CJNE     A, 20H, LOOP
       JNB      P3.2, KEY1
       JNB      P3.3, KEY2
       JNB      P3.5, KEY3
       SJMP     LOOP
  KEY1:SETB     TR0
       LJMP     LOOP
  KEY2:CLR      TR0
       LJMP     LOOP
  KEY3:CLR      TR0
       MOV      SEC, #00H
        LJMP    LOOP
T0INS:
              CLR      EA                 ;
              MOV     TL0,#3CH
              MOV      TH0,#0B0H        ;
              SETB     EA                 ;
              DJNZ     R7,EXIT         ;
              MOV      R7,#00               ;
              MOV      P1,A            ;
              RL       A                   ;
  EXIT:RETI                         ;
  DISP:MOV      A, SEC         ;
       MOV      B, #10         ;
       DIV      AB
       MOV      TEN,A         ;
       MOV      UNIT,B
       PUSH     ACC
       MOV      DPTR,#TAB        ;
        MOV     A,UNIT
       MOVC     A,@A+DPTR      ;
       MOV      P0,A
       SETB     P2.1
       LCALL    DELAY10
       CLR      P2.1
       MOV      A,TEN
       MOVC     A,@A+DPTR
       MOV      P0,A
       SETB     P2.0
       LCALL    DELAY10
       CLR      P2.0
       POP      ACC
       RET
   TAB:DB 0C0H,0F9H,0A4H,0B0H,99H,92H,82H,0F8H,80H,90H
DELAY10:MOV R7,#10
    D1:MOV R6,#200
    D2:MOV R5,#250
       DJNZ R5,$
       DJNZ R6,D2
       DJNZ R7,D1
       RET
       END
assembling miaobiao.ASM...
miaobiao.ASM(2): error A9: SYNTAX ERROR
miaobiao.ASM(14): error A9: SYNTAX ERROR
miaobiao.ASM(50): error A9: SYNTAX ERROR
miaobiao.ASM(53): error A9: SYNTAX ERROR
miaobiao.ASM - 4 Error(s), 0 Warning(s).
