查看: 1226|回復: 0
智能澆花1602第一次可以顯示,而且各種功能都行,后面再上電就一排黑了,咋回事 求...
ID:615514 發表于 2019-11-22 22:59 | 顯示全部樓層 |閱讀模式
#include "1602.h"
#include "delay.h"
#include <intrins.h>
#define _NOP() _nop_()
sbit RS = P2^4;
sbit RW = P2^5;
sbit EN = P2^6;
#define DataPort    P0
#define DataPIN     P0
#define CLR_RS (RS=0)
#define SET_RS (RS=1)
#define CLR_RW (RW=0)
#define SET_RW (RW=1)
#define CLR_EN (EN=0)
#define SET_EN (EN=1)
LcdReset();
DelayMs(10);
sprintf(temp,"1111111111111111");//???????
DispStr(0,0,(unsigned char *)temp);//??????
DispStr(0,1,(unsigned char *)temp);//??????
?????????DispStr
??    ?????????????λ???????????????????
??    ????x--λ?????????
          y--λ?????????
          ptr--???????????λ??????
void DispStr(uchar x,uchar y,uchar *ptr)
    uchar *temp;
    uchar i,n = 0;
    temp = ptr;
    while(*ptr++ != '\0')   n++;    //???????????Ч????????
    for (i=0;i<n;i++)
        Disp1Char(x++,y,temp);
        if (x == 0x10)
            break;
?????????DispNchar
??    ?????????????λ???????????N?????
          y--λ?????????
          n--???????
          ptr--?????????λ??????
void DispNChar(uchar x,uchar y, uchar n,uchar *ptr)
    uchar i;
    for (i=0;i<n;i++)
        Disp1Char(x++,y,ptr);
        if (x == 0x10)
           x = 0;
            y ^= 1;
?????????LocateXY
??    ??????????????????λ??????????
          y--λ?????????
void LocateXY(uchar x,uchar y)
    uchar temp;
    temp = x&0x0f;
    y &= 0x01;
    if(y)   temp |= 0x40;  //??????2??
    temp |= 0x80;
    LcdWriteCommand(temp,1);
?????????Disp1Char
??    ????????λ???????????
          y--λ?????????
          data--????????????
void Disp1Char(uchar x,uchar y,uchar data1)
    LocateXY( x, y );
    LcdWriteData( data1 );
?????????LcdReset
??    ?????1602????????и?λ????
void LcdReset(void)
//    DataDir  = 0xFF;                 //??????????????
    LcdWriteCommand(0x38, 0);     //?漲???λ????
    DelayMs(5);
    DelayMs(5);
    DelayMs(5);
    LcdWriteCommand(0x38, 1);  //?????????
    LcdWriteCommand(0x08, 1);  //??????
    LcdWriteCommand(0x01, 1);     //???????
    LcdWriteCommand(0x06, 1);  //д???????岻???
    LcdWriteCommand(0x0c, 1);  //????????????α??????
void LcdClear(void)
LcdWriteCommand(0x01,1);
DelayMs(5);
?????????LcdWriteCommand
??    ???????????д??????
??    ????cmd--????
          chk--????????????1???????0??????
void LcdWriteCommand(uchar cmd,uchar chk)
    if (chk) WaitForEnable();   // ????????
    CLR_RS;
    CLR_RW;
    _NOP();
    DataPort = cmd;             //????????д????????
    _NOP();
    SET_EN;                     //??????????????
    _NOP();
    _NOP();
    CLR_EN;
?????????LcdWriteData
??    ??????????????????д?????????
??    ????data--??????????
void LcdWriteData( uchar data1 )
    WaitForEnable();        //?????????
    SET_RS;
    CLR_RW;
    SET_EN;
_NOP();
    DataPort = data1;        //?????????д????????
    _NOP();
    _NOP();
    _NOP();
    CLR_EN;
?????????WaitForEnable
??    ??????1602?????????????
void WaitForEnable(void)
   unsigned int later=0;
DataPort=0xff;
    CLR_RS;
    SET_RW;
    _NOP();
    SET_EN;
    _NOP();
    _NOP();
//    while((DataPIN&Busy)!=0);
    while(((DataPIN&0x80)!=0)&&(later<1000))
      DelayUs2x(2);
      later++;
    CLR_EN;
