查看: 2730|回復(fù): 0
51單片機(jī)8155交通燈 原理圖 加仿真代碼
ID:647522 發(fā)表于 2019-11-22 22:04 | 顯示全部樓層 |閱讀模式
#include<REG52.H>
#include<absacc.h>
#define COMMAND XBYTE[0X1F00]
#define PA XBYTE[0X1F01]
#define PB XBYTE[0x1f02]
sbit cs=P2^5;
sbit om=P2^4;
sbit state=P2^6;
sbit int0=P3^2;
sbit int1=P3^3;
uchar k1=1,k2=1;
uchar a,shi,ge,shi1,ge1,num1,num2,num3;
uchar t;
uchar t1;
uchar dx_hong,dx_huang,dx_lv,nb_hong,nb_huang,nb_lv;
uchar run_state=1;
uchar ledflag1=1,ledflag2=3;//r y g y
uchar code table[]={
0x3f,0x06,0x5b,0x4f,
0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x77,0x7c,
0x39,0x5e,0x79,0x71};
void delayms(uint xms);
void display1(uchar shi,uchar ge,uchar shi1,uchar ge1);
void djs(uchar xs,uchar xs1);
void init(void);
void keyscan(void);
{init();
cs=0;
om=1;
COMMAND=0X0F;
PB=0XFF;
IT0=1;
IT1=1;
EX0=EX1=1;
      keyscan();
   if(run_state){
        TR0=1;
     if(ledflag1==1){
            t=20;/*dx_hong=0; dx_huang=1; dx_lv=1;*/
            PB&=~(0X07);
            PB|=0X01;
   else if((ledflag1==2)||(ledflag1==4)){
          t=3;/*dx_hong=1; dx_huang=0; dx_lv=1;*/
          PB&=~(0X07);
          PB|=0X02;
   else if(ledflag1==3){
          t=17;/*dx_hong=1; dx_huang=1; dx_lv=0;*/
          PB&=~(0X07);
          PB|=0X04;
   if(ledflag2==1){
          t1=20;/*nb_hong=0;nb_huang=1;nb_lv=1;*/
          PB&=~(0X07<<3);
          PB|=0X01<<3;
   else if((ledflag2==2)||(ledflag2==4)){
          t1=3;/*nb_hong=1;nb_huang=0;nb_lv=1;*/
          PB&=~(0X07<<3);
          PB|=0X02<<3;
   else if(ledflag2==3){
   t1=17;/*nb_hong=1;nb_huang=1;nb_lv=0;*/
        PB&=~(0X07<<3);
        PB|=0X04<<3;
   djs(t,t1);
   }else
        TR0=0;
      PA=0X00;
void keyscan(void)//p2^6
  static key_state=1;
   if(key_state&&(state==0))
    delayms(10);
    if(state==0)
   key_state=0;
    run_state=!run_state;
   }else if(state)
   key_state=1;
uint i,j;
for(i=xms;i>0;i--)
for(j=110;j>0;j--);
P2=0xfe;
PA=0x00;
PA=table[shi];
delayms(5);
P2=0xfd;
PA=0x00;
PA=table[ge];
delayms(5);
P2=0xfb;
PA=0x00;
PA=table[shi1];
delayms(5);
P2=0xf7;
PA=0x00;
PA=table[ge1];
delayms(5);
  shi=(xs-num2)/10;
  ge=(xs-num2)%10;
   shi1=(xs1-num3)/10;
  ge1=(xs1-num3)%10;
   display1(shi,ge,shi1,ge1);
   if((xs-(num2-1))==0)
   num2=0;
   if(ledflag1<4)ledflag1++;
   else ledflag1=1;
   if((xs1-(num3-1))==0)
   num3=0;
   if(ledflag2<4)ledflag2++;
   else ledflag2=1;
void init(void)
TMOD=0x11;
TH0=(65536-50000)/256;
TL0=(65536-50000)%256;
EA=1;
ET0=1;
TR0=1;
void T0_time()interrupt 1
num1++;
if(num1==20)
num1=0;
num2++;
num3++;
void INT0_HANDER(void) interrupt 0
   delayms(10);
         if(int0==0)
         if(run_state==0)
     if(k1<3)k1++;
                 else k1=1;
                 if(k1==1){PB&=~(0X07);PB|=0X01;}
                 else if(k1==2){PB&=~(0X07);PB|=0X02;}
                 else if(k1==3){PB&=~(0X07);PB|=0X04;}
void INT1_HANDER(void) interrupt 2
   delayms(10);
         if(int1==0)
         if(run_state==0)
     if(k2<3)k2++;
                 else k2=1;
                 if(k2==1){PB&=~(0X07<<3);PB|=(0X01<<3);}
                 else if(k2==2){PB&=~(0X07<<3);PB|=(0X02<<3);}
                 else if(k2==3){PB&=~(0X07<<3);PB|=(0X04<<3);}
[img]file:///C:/Users/wzy/AppData/Roaming/Tencent/Users/624399639/QQ/WinTemp/RichOle/A)VUO4QSM[@$Y$O)[ZNYB_4.png[/img]
參與人數(shù) 1黑幣 +50 收起 理由
