查看: 2330|回復: 0
c51藍牙智能車
ID:646658 發表于 2019-11-21 17:25 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include<reg52.h>
#include <intrins.h>
#include <math.h>
/****************1602**I/O口******************/
sbit rs = P1^1;
sbit lcden = P3^3;   //外部中斷入口
sbit state = P0^7;   //1說明液晶繁忙
/*********模式選擇端口************/
sbit key = P2^4;
/***************超聲波**I/O口******************/
sbit trig = P1^0;
sbit echo = P3^2;
/******************尋跡IO口聲明********************/
/*白線為0,黑線為1*/
sbit trace1 = P3^5;     /*1路*/
sbit trace2 = P2^5;     /*2路*/
sbit trace3 = P2^6;     /*3路*/
/***************測試燈**I/O口******************/
sbit led = P2^0;
/*****************電機驅動**IO口*****************/
/*使能端*/
sbit em1 = P1^4;        //左后
sbit em2 = P1^7;        //右后
sbit em3 = P2^7;        //右前
sbit em4 = P2^3;        //左前
/*電機口*/
sbit in1 = P1^2;        //左后
sbit in2 = P1^3;
sbit in3 = P1^5;        //右后
sbit in4 = P1^6;
sbit in5 = P3^6;        //右前
sbit in6 = P3^7;
sbit in7 = P2^1;        //左前
sbit in8 = P2^2;
/***************定義全局變量******************/
uchar table1[] = "Distance:";     //1602顯示
uchar table2[] = "cm";
uchar table3[] = "Tracing";
uchar flag_ula;               //超聲波接收標志
float distance;               //計算距離
uchar bluetoothdata;          //接受藍牙串口數據
/****************函數聲明******************/
void Reverse();
void Stop();
/*****************宏定義******************/
#define cycle   15
#define cycle1  100
/***********************延時類函數***********************/
/*毫秒延時*/
void Delayms(uint x)
    uint a, b;
    for(a = x; a > 0; a--)
        for(b = 110; b > 0; b--);
/*微妙延時*/
void Delay10us(unsigned char i)
   unsigned char j;
    do{
        j = 10;
        do
            _nop_();
        while(--j);
      while(--i);
/***************初始化中斷************/
void  init_T0()
    TMOD = 0x20;
    TH0 = 0;
    TL0 = 0;
    EA = 1;
    IT0 = 1;       //外部0中斷的中斷方式為:下降沿中斷
    ES = 1;        //開串口中斷
    SCON = 0x50;
