程序仿真原理圖都有:::
程序:
#include<reg52.h>
#include<intrins.h>
#define LCDIO P0
sbit rs=P2^0;
sbit rd=P2^1;
sbit lcden=P2^2;
sbit acc0=ACC^0; //移位時的第0位
sbit acc7=ACC^7; //移位時用的第7位
sbit ct=P2^3;
sbit speaker=P3^5;
sbit DQ=P2^5;//ds18b20與單片機(jī)連接口
int djs11=0,js,dsmin=0,dshour=0;
uchar second,minute,hour,day,month,year,week,count=0;
uchar ReadValue,num,time;
uint tvalue;//溫度值
uchar tflag;
uchar code table[]={" 2000-00-00 FRI"};
uchar code table1[]={" 00:00:00 "};
uchar code table2[]= "THUFRISATSUNMONTUEWES";
char szdata[8];
char szdata1[8];
uchar data disdata[5];
sbit DATA=P3^3; //時鐘數(shù)據(jù)接口
sbit RST=P3^4;
sbit SCLK=P3^2;
sbit menu=P2^7; //菜單
sbit add=P2^6; //加一
sbit dec=P2^4;
sbit set=P2^3 ; //減一
sbit djs=P3^6;
void miaobiao();
void yx();
void delayms(int x)
char i;
while(x--)
for(i=150;i>0;i--);
void delay(uint z)
uint x,y;
for(x=z;x>0;x--)
for(y=110;y>0;y--);
void delay1(uint z)
for(;z>0;z--);
void write_com(uchar com)
rs=0;
rd=0;
lcden=0;
LCDIO=com;
delay(5);
lcden=1;
delay(5);
lcden=0;
void write_date(uchar date)
rs=1;
rd=0;
lcden=0;
LCDIO=date;
delay(5);
lcden=1;
delay(5);
lcden=0;
void init()
uchar num;
lcden=0;
write_com(0x38);
write_com(0x0c);
write_com(0x06);
write_com(0x01);
write_com(0x80);
delay(5);
write_com(0x80);
for(num=0;num<15;num++)
write_date(table[num]);
delay(5);
write_com(0x80+0x40);
write_date(table1[num]);
delay(5);
void Write1302(uchar dat)
uchar i;
SCLK=0; //拉低SCLK,為脈沖上升沿寫入數(shù)據(jù)做好準(zhǔn)備
delay1(2); //稍微等待,使硬件做好準(zhǔn)備
for(i=0;i<8;i++) //連續(xù)寫8個二進(jìn)制位數(shù)據(jù)
DATA=dat&0x01; //取出dat的第0位數(shù)據(jù)寫入1302
delay(2); //稍微等待,使硬件做好準(zhǔn)備
SCLK=1; //上升沿寫入數(shù)據(jù)
SCLK=0; //重新拉低SCLK,形成脈沖
dat>>=1; //將dat的各數(shù)據(jù)位右移1位,準(zhǔn)備寫入下一個數(shù)據(jù)位
void WriteSet1302(uchar Cmd,uchar dat)
RST=0; //禁止數(shù)據(jù)傳遞
SCLK=0; //確保寫數(shù)居前SCLK被拉低
RST=1; //啟動數(shù)據(jù)傳輸
Write1302(Cmd); //寫入命令字
Write1302(dat); //寫數(shù)據(jù)
SCLK=1; //將時鐘電平置于已知狀態(tài)
uchar Read1302(void)
uchar i,dat;
for(i=0;i<8;i++) //連續(xù)讀8個二進(jìn)制位數(shù)據(jù)
dat>>=1; //將dat的各數(shù)據(jù)位右移1位,因為先讀出的是字節(jié)的最低位
if(DATA==1) //如果讀出的數(shù)據(jù)是1
dat|=0x80; //將1取出,寫在dat的最高位
SCLK=1; //將SCLK置于高電平,為下降沿讀出
delay1(2); //稍微等待
SCLK=0; //拉低SCLK,形成脈沖下降沿
delay1(2); //稍微等待
return dat; //將讀出的數(shù)據(jù)返回
uchar ReadSet1302(uchar Cmd)
uchar dat;
RST=0; //拉低RST
dat=Read1302(); //讀出數(shù)據(jù)
void Init_DS1302(void)
WriteSet1302(0x8E,0x00); //根據(jù)寫狀態(tài)寄存器命令字,寫入不保護(hù)指令
WriteSet1302(0x80,((0/10)<<4|(0%10))); //根據(jù)寫秒寄存器命令字,寫入秒的初始值
WriteSet1302(0x82,((12/10)<<4|(12%10))); //根據(jù)寫分寄存器命令字,寫入分的初始值
WriteSet1302(0x84,((11/10)<<4|(11%10))); //根據(jù)寫小時寄存器命令字,寫入小時的初始值
WriteSet1302(0x86,((25/10)<<4|(25%10))); //根據(jù)寫日寄存器命令字,寫入日的初始值
WriteSet1302(0x88,((1/10)<<4|(1%10))); //根據(jù)寫月寄存器命令字,寫入月的初始值
WriteSet1302(0x8c,((13/10)<<4|(13%10))); //nian
WriteSet1302(0x8a,((1/10)<<4|(1%10)));
void DisplaySecond(uchar x)
uchar i,j;
i=x/10;
j=x%10;
write_com(0xc7);
write_date(0x30+i);
write_date(0x30+j);
void DisplayMinute(uchar x)
uchar i,j;
i=x/10;
j=x%10;
write_com(0xc4);
write_date(0x30+i);
write_date(0x30+j);
void DisplayHour(uchar x)
uchar i,j;
i=x/10;
j=x%10;
write_com(0xc1);
write_date(0x30+i);
write_date(0x30+j);
void DisplayDay(uchar x)
uchar i,j;
i=x/10;
j=x%10;
write_com(0x89);
write_date(0x30+i);
write_date(0x30+j);
void DisplayMonth(uchar x)
uchar i,j;
i=x/10;
j=x%10;
write_com(0x86);
write_date(0x30+i);
write_date(0x30+j);
void DisplayYear(uchar x)
uchar i,j;
i=x/10;
j=x%10;
write_com(0x83);
write_date(0x30+i);
write_date(0x30+j);
void DisplayWeek(uchar x)
{ uchar i;
x=x*3;
write_com(0x8c);
for(i=0;i<3;i++)
write_date(table2[x]);
x++;
void read_date(void)
ReadValue = ReadSet1302(0x81);
second=((ReadValue&0x70)>>4)*10 + (ReadValue&0x0F);
ReadValue = ReadSet1302(0x83);
minute=((ReadValue&0x70)>>4)*10 + (ReadValue&0x0F);
ReadValue = ReadSet1302(0x85);
hour=((ReadValue&0x70)>>4)*10 + (ReadValue&0x0F);
ReadValue = ReadSet1302(0x87);
day=((ReadValue&0x70)>>4)*10 + (ReadValue&0x0F);
ReadValue = ReadSet1302(0x89);
month=((ReadValue&0x70)>>4)*10 + (ReadValue&0x0F);
ReadValue = ReadSet1302(0x8d);
year=((ReadValue&0x70)>>4)*10 + (ReadValue&0x0F);
ReadValue=ReadSet1302(0x8b); //讀星期
week=ReadValue&0x07;
if((year==szdata[1])&&(month==szdata[2])&&(day==szdata[3])&&(week==szdata[4])&&(hour==szdata[5])&&(minute==szdata[6])&&(second==szdata[7])) speaker=0;
DisplaySecond(second);
DisplayMinute(minute);
DisplayHour(hour);
DisplayDay(day);
DisplayMonth(month);
DisplayYear(year);
DisplayWeek(week);
void turn_val(char newval,uchar flag,uchar newaddr,uchar s1num)
newval=ReadSet1302(newaddr); //讀取當(dāng)前時間
newval=((newval&0x70)>>4)*10+(newval&0x0f); //將bcd碼轉(zhuǎn)換成十進(jìn)制
if(flag) //判斷是加一還是減一
newval++;
switch(s1num)
{ case 1: if(newval>99) newval=0;
DisplayYear(newval);
break;
case 2: if(newval>12) newval=1;
DisplayMonth(newval);
break;
case 3: if(newval>31) newval=1;
DisplayDay(newval);
break;
case 4: if(newval>6) newval=0;
DisplayWeek(newval);
break;
case 5: if(newval>23) newval=0;
DisplayHour(newval);
break;
case 6: if(newval>59) newval=0;
DisplayMinute(newval);
break;
case 7: if(newval>59) newval=0;
DisplaySecond(newval);
break;
default:break;
newval--;
switch(s1num)
{ case 1: if(newval<0) newval=99;
break;
case 2: if(newval<0) newval=12;
break;
case 3: if(newval<0) newval=31;
DisplayDay(newval);
break;
case 4: if(newval<0) newval=6;
break;
case 5: if(newval<0) newval=23;
break;
case 6: if(newval<0) newval=59;
break;
case 7: if(newval<0) newval=59;
break;
default:break;
WriteSet1302((newaddr-1),((newval/10)<<4)|(newval%10)); //將新數(shù)據(jù)寫入寄存器
void turn_val11(char newval,uchar flag,uchar newaddr,uchar s1num)
newval=szdata[s1num]; //讀取當(dāng)前時間
//newval=((newval&0x70)>>4)*10+(newval&0x0f); //將bcd碼轉(zhuǎn)換成十進(jìn)制
newval++;
switch(s1num)
break;
break;
DisplayDay(newval);
break;
break;
break;
break;
break;
default:break;
newval--;
switch(s1num)
break;
break;
DisplayDay(newval);
break;
break;
break;
break;
break;
default:break;
szdata[s1num]= newval;
szdata1[s1num]=newval;
//WriteSet1302((newaddr-1),((newval/10)<<4)|(newval%10)); //將新數(shù)據(jù)寫入寄存器
//鍵盤掃描程序
void key_scan(void)
{ uchar miao,s1num=0;
if(menu==0)
delay(5);
if(menu==0)
while(!menu);
s1num++;
write_com(0xc9);
write_date(' ');//顯示符號位
write_com(0xca);
write_date(' ');//顯示百位
write_com(0xcb);
write_date('T');//顯示十位
write_com(0xcc);
write_date('-');//顯示個位
write_com(0xcd);
write_date('S');//顯示小數(shù)點(diǎn)
write_com(0xce);
write_date('E');//顯示小數(shù)位
write_com(0xcf);
write_date('T');
if(menu==0)
delay(5);
if(menu==0)
while(!menu);
s1num++;
rd=0;
miao=ReadSet1302(0x81);
second=miao;
WriteSet1302(0x80,miao|0x80);
write_com(0x0f);//光標(biāo)閃射
if(s1num==1)
{ year=ReadSet1302(0x8d);
write_com(0x80+4); //年光標(biāo)
if(add==0)
delay(3);
if(add==0)
{ while(!add);
turn_val(year,1,0x8d,1);
if(dec==0)
delay(3);
if(dec==0)
{ while(!dec);
turn_val(year,0,0x8d,1);
if(s1num==2)
month=ReadSet1302(0x89);
write_com(0x80+7); //月光標(biāo)
if(add==0)
delay(3);
if(add==0)
{ while(!add);
turn_val(month,1,0x89,2);
if(dec==0)
delay(3);
if(dec==0)
{ while(!dec);
turn_val(month,0,0x89,2);
if(s1num==3)
{ day=ReadSet1302(0x87);
write_com(0x80+10);//日光標(biāo)
if(add==0)
delay(3);
if(add==0)
{ while(!add);
turn_val(day,1,0x87,3);
if(dec==0)
delay(3);
if(dec==0)
{ while(!dec);
turn_val(day,0,0x87,3); //寫入日寄存器
if(s1num==4)
{ week=ReadSet1302(0x8b);
write_com(0x80+14); //星期光標(biāo)
if(add==0)
delay(3);
if(add==0)
{ while(!add);
turn_val(week,1,0x8b,4);
if(dec==0)
delay(3);
if(dec==0)
{ while(!dec);
turn_val(week,0,0x8b,4);
if(s1num==5)
{ hour=ReadSet1302(0x85);
write_com(0x80+0x40+2); //時光標(biāo)
if(add==0)
delay(3);
if(add==0)
{ while(!add);
turn_val(hour,1,0x85,5);
if(dec==0)
delay(3);
if(dec==0)
{ while(!dec);
turn_val(hour,0,0x85,5);
if(s1num==6)//調(diào)時間分
{ minute=ReadSet1302(0x83);
write_com(0x80+0x40+5);
if(add==0)
delay(5);
if(add==0)
{ while(!add);
turn_val(minute,1,0x83,6); //寫入分寄存器
if(dec==0)
delay(3);
if(dec==0)
{ while(!dec);
turn_val(minute,0,0x83,6); //寫入分寄存器
if(s1num==7)//調(diào)時間秒
{ second=ReadSet1302(0x81);
write_com(0x80+0x40+8);//秒光標(biāo)
if(add==0)
delay(3);
if(add==0)
{ while(!add);
if(second==0x60)
second=0x00;
turn_val(second,1,0x81,7);
if(dec==0)
delay(3);
if(dec==0)
{ while(!dec);
turn_val(second,0,0x81,7);
if(s1num==8)
{ miao=ReadSet1302(0x81);
second=miao;
WriteSet1302(0x80,second&0x7f);
s1num=0;//s1num清零//
write_com(0x0c);//光標(biāo)不閃爍//
break;
if(ct==0)
delay(5);
if(ct==0)
while(!ct);
s1num++;
write_com(0xc9);
write_com(0xca);
write_com(0xcb);
write_date('C');//顯示十位
write_com(0xcc);
write_com(0xcd);
write_com(0xce);
write_com(0xcf);
write_date('T');
DisplaySecond(szdata1[7]);
DisplayMinute(szdata1[6]);
DisplayHour(szdata1[5]);
DisplayDay(szdata1[3]);
DisplayMonth(szdata1[2]);
DisplayYear(szdata1[1]);
DisplayWeek(szdata1[4]);
if(ct==0)
delay(5);
if(ct==0)
while(!ct);
s1num++;
rd=0;
second=miao;
if(s1num==1)
{ year=0x00;
if(add==0)
delay(3);
if(add==0)
{ while(!add);
turn_val11(year,1,0x8d,1);
if(dec==0)
delay(3);
if(dec==0)
{ while(!dec);
turn_val11(year,0,0x8d,1);
if(s1num==2)
month=0x00;
if(add==0)
delay(3);
if(add==0)
{ while(!add);
turn_val11(month,1,0x89,2);
if(dec==0)
delay(3);
if(dec==0)
{ while(!dec);
turn_val11(month,0,0x89,2);
if(s1num==3)
{ day=0x00;
if(add==0)
delay(3);
if(add==0)
{ while(!add);
turn_val11(day,1,0x87,3);
if(dec==0)
delay(3);
if(dec==0)
{ while(!dec);
turn_val11(day,0,0x87,3); //寫入日寄存器
if(s1num==4)
{ week=0x00;
if(add==0)
delay(3);
if(add==0)
{ while(!add);
turn_val11(week,1,0x8b,4);
if(dec==0)
delay(3);
if(dec==0)
{ while(!dec);
turn_val11(week,0,0x8b,4);
if(s1num==5)
{ hour=0x00;
if(add==0)
delay(3);
if(add==0)
{ while(!add);
turn_val11(hour,1,0x85,5);
if(dec==0)
delay(3);
if(dec==0)
{ while(!dec);
turn_val11(hour,0,0x85,5);
{ minute=0x00;
if(add==0)
delay(5);
if(add==0)
{ while(!add);
turn_val11(minute,1,0x83,6); //寫入分寄存器
if(dec==0)
delay(3);
if(dec==0)
{ while(!dec);
turn_val11(minute,0,0x83,6); //寫入分寄存器
{ second=0x00;
if(add==0)
delay(3);
if(add==0)
{ while(!add);
if(second==0x60)
second=0x00;
turn_val11(second,1,0x81,7);
if(dec==0)
delay(3);
if(dec==0)
{ while(!dec);
turn_val11(second,0,0x81,7);
if(s1num==8)
second=miao;
s1num=0;//s1num清零//
break;
void Timer0_init()
js=0;
TMOD=0x01; //T0為定時器方式1
TH0=0x4c;
TL0=0x00;
//IT1=1;
ET0=1;//EX1=1;
EA=1;
void timer0() interrupt 1 using 1
TF0=0;
//TH0=0x4c;
//TL0=0x00;
TH0=0xb3;
TL0=0x4c;
js++;
if(js==1)
{ js=0;
djs11++;
//led1=~led1;
if(djs11>59)
djs11=0;
dsmin=dsmin+1;
if(dsmin>59)
dsmin=0;
dshour=dshour+1;
if(dshour>24) dshour=0;
void miaobiao()
{ int i,j;
write_com(0x80);write_date(' ');
write_com(0x81);write_date(' ');
write_com(0x82);write_date(' ');
write_com(0x83);write_date(' ');
write_com(0x84);write_date(' ');
write_com(0x85);write_date(' ');
write_com(0x86);write_date(' ');
write_com(0x87);write_date(' ');
write_com(0x88);write_date(' ');
write_com(0x89);write_date(' ');
write_com(0x8a);write_date(' ');
write_com(0x8b);write_date(' ');
write_com(0x8c);write_date(' ');
write_com(0x8d);write_date(' ');
write_com(0x8e);write_date(' ');
write_com(0x8f);write_date(' ');
write_com(0xc0);write_date(' ');
write_com(0xc1);write_date(' ');
write_com(0xc2);write_date(' ');
write_com(0xc3);write_date(' ');
write_com(0xc4);write_date(' ');
write_com(0xc5);write_date(' ');
write_com(0xc6);write_date(' ');
write_com(0xc7);write_date(' ');
write_com(0xc8);write_date(' ');
write_com(0xc9);write_date(' ');
write_com(0xca);write_date(' ');
write_com(0xcb);write_date(' ');
write_com(0xcc);write_date(' ');
write_com(0xcd);write_date(' ');
write_com(0xce);write_date(' ');
write_com(0xcf);write_date(' ');
{ if(add==0)
delayms(30);
if(add==0)
TR0=1;
if(dec==0)
delayms(30);
if(dec==0)
TR0=0;
if(set==0)
delayms(30);
if(set==0)
djs11=0;
TR0=0;
dsmin=0;
dshour=0;
if(djs==0)
delayms(30);
if(djs==0)
yx();
write_com(0xc4);
i=dshour/10;
j=dshour%10;
write_date(0x30+i);
write_date(0x30+j);
write_date(':');
i=dsmin/10;
j=dsmin%10;
write_date(0x30+i);
write_date(0x30+j);
write_date(':');
i=djs11/10;
j=djs11%10;
write_date(0x30+i);
write_date(0x30+j);
void delay_18B20(unsigned int i)//延時1微秒
while(i--);
void ds1820rst()/*ds1820復(fù)位*/
{ unsigned char x=0;
DQ = 1; //DQ復(fù)位
delay_18B20(4); //延時
DQ = 0; //DQ拉低
delay_18B20(100); //精確延時大于480us
DQ = 1; //拉高
delay_18B20(40);
uchar ds1820rd()/*讀數(shù)據(jù)*/
{ unsigned char i=0;
unsigned char dat = 0;
for (i=8;i>0;i--)
{ DQ = 0; //給脈沖信號
dat>>=1;
DQ = 1; //給脈沖信號
if(DQ)
dat|=0x80;
delay_18B20(10);
return(dat);
void ds1820wr(uchar wdata)/*寫數(shù)據(jù)*/
{unsigned char i=0;
for (i=8; i>0; i--)
{ DQ = 0;
DQ = wdata&0x01;
delay_18B20(10);
DQ = 1;
wdata>>=1;
read_temp()/*讀取溫度值并轉(zhuǎn)換*/
{uchar a,b;
ds1820rst();
ds1820wr(0xcc);//*跳過讀序列號*/
ds1820wr(0x44);//*啟動溫度轉(zhuǎn)換*/
ds1820rst();
ds1820wr(0xbe);//*讀取溫度*/
a=ds1820rd();
b=ds1820rd();
tvalue=b;
tvalue<<=8;
tvalue=tvalue|a;
if(tvalue<0x0fff)
tflag=0;
{tvalue=~tvalue+1;
tflag=1;
tvalue=tvalue*(0.625);//溫度值擴(kuò)大10倍,精確到1位小數(shù)
return(tvalue);
void ds1820disp()//溫度值顯示
{ uchar flagdat;
disdata[0]=tvalue/1000+0x30;//百位數(shù)
disdata[1]=tvalue%1000/100+0x30;//十位數(shù)
disdata[2]=tvalue%100/10+0x30;//個位數(shù)
disdata[3]=tvalue%10+0x30;//小數(shù)位
if(tflag==0)
flagdat=0x20;//正溫度不顯示符號
flagdat=0x2d;//負(fù)溫度顯示負(fù)號:-
if(disdata[0]==0x30)
{disdata[0]=0x20;//如果百位為0,不顯示
if(disdata[1]==0x30)
{disdata[1]=0x20;//如果百位為0,十位為0也不顯示
write_com(0xc9);
write_date(flagdat);//顯示符號位
write_com(0xca);
write_date(disdata[0]);//顯示百位
write_com(0xcb);
write_date(disdata[1]);//顯示十位
write_com(0xcc);
write_date(disdata[2]);//顯示個位
write_com(0xcd);
write_date(0x2e);//顯示小數(shù)點(diǎn)
write_com(0xce);
write_date(disdata[3]);//顯示小數(shù)位
write_com(0xcf);
write_date('C');
void yx()
init();
read_date();
read_temp();//讀取溫度
ds1820disp();//顯示
key_scan();
if(add==0)
delayms(30);
if(add==0)
speaker=1;
if(dec==0)
delayms(30);
if(dec==0)
speaker=1;
if(djs==0)
delay(5);
if(djs==0)
miaobiao();
init();
Timer0_init();
// Init_DS1302(); //將1302初始化
speaker=1;
szdata1[1]=0x00;
szdata1[2]=0x00;
szdata1[3]=0x00;
szdata1[4]=0x00;
szdata1[5]=0x00;
szdata1[6]=0x00;
szdata1[7]=0x00;
yx();
