這個晶振是6MHz ORG 0000H LJMP MAIN ORG 001BH LJMP ZD ORG 0030H MAIN: MOV SP,#60H MOV TMOD,#10H MOV TH1, #3CH MOV TL1, #0B0H MOV R0,#00H MOV R2,#10 SETB EA SETB ET1 SETB TR1 SJMP $ ZD: PUSH ACC PUSH PSW PUSH DPL PUSH DPH DJNZ R2,RETURN MOV A,R0 MOV DPTR,#TAB MOVC A,@A+DPTR MOV P1,A INC R0 CJNE R0,#8,RETURN1 MOV R0,#00H RETURN1:MOV R2,#10 RETURN:MOV TH1,#3CH MOV TH1,#0B0H POP DPH POP DPL POP PSW POP ACC RETI TAB:DB 0FAH,0F5H,0AFH,5FH,0AAH,55H,00H,0FFH; END |
