單片機(jī)源程序如下:
- //#include<reg52.h>
- #include<STC_NEW_8051.H>
- #include<LCD12864.H>
- #include<eeprom.h>
- #include<ADC.h>
- #include<math.h>
- /****定義按鍵接口**************/
- sbit Mode=P3^2;
- sbit Add=P3^3;
- sbit Dec=P3^4;
- sbit Ent=P3^5;
- sbit Dsp=P3^7;
- sbit J5=P2^7;
- sbit LED=P4^2;
- sbit G1=P4^3;
- unsigned char id,num;
- unsigned int a[8];
- //void Add_key1();
- void Lcd_Mark2(void);
- /*void Lcd_Mark3(void)
- Mcs=1;Scs=0;
- g= a[0]/100%10;
- d= a[0]/10%10;
- e= a[0]%10;
- Disp_Digit(0,0,zero+g*16);
- Disp_Digit(0,8,zero+d*16);
- Disp_Digit(0,16,zero+e*16);
- Disp_Digit(0,24,space);
- Disp_Digit(0,32,space);
- g= a[1]/100%10;
- d= a[1]/10%10;
- e= a[1]%10;
- Disp_Digit(2,0,zero+g*16);
- Disp_Digit(2,8,zero+d*16);
- Disp_Digit(2,16,zero+e*16);
- Disp_Digit(2,24,space);
- Disp_Digit(2,32,space);
- g= a[2]/100%10;
- d= a[2]/10%10;
- e= a[2]%10;
- Disp_Digit(4,0,zero+g*16);
- Disp_Digit(4,8,zero+d*16);
- Disp_Digit(4,16,zero+e*16);
- Disp_Digit(4,24,space);
- Disp_Digit(4,32,space);
- g= a[3]/100%10;
- d= a[3]/10%10;
- e= a[3]%10;
- Disp_Digit(6,0,zero+g*16);
- Disp_Digit(6,8,zero+d*16);
- Disp_Digit(6,16,zero+e*16);
- Disp_Digit(6,24,space);
- Disp_Digit(6,32,space);
- Disp_Digit(6,40,space);
- Disp_Digit(6,48,space);
- Mcs=0;Scs=1;
- g= a[4]/100%10;
- d= a[4]/10%10;
- e= a[4]%10;
- g= a[5]/100%10;
- d= a[5]/10%10;
- e= a[5]%10;
- g= a[6]/100%10;
- d= a[6]/10%10;
- e= a[6]%10;
- g= a[7]/100%10;
- d= a[7]/10%10;
- e= a[7]%10;
- 定時(shí)器初始化子程序
- void Init_Timer0(void)
- TMOD |= 0x01; //使用模式1,16位定時(shí)器,使用"|"符號(hào)可以在使用多個(gè)定時(shí)器時(shí)不受影響
- TH0=0x00; //給定初值,這里使用定時(shí)器最大值從0開始計(jì)數(shù)一直到65535溢出
- TL0=0x01;
- ET0=1; //定時(shí)器中斷打開
- TR0=1; //定時(shí)器開關(guān)打開
- void Delay100(int num)//延時(shí)函數(shù) 10ms
- { int i,j;
- for ( i=num;i>0;i--)
- for ( j=12490;j>0;j--)
- void Disp(void);
- void main()
- year=Byte_Read(0X00)<<2;
- month=Byte_Read(0X01);
- date=Byte_Read(0X02);
- hour=Byte_Read(0X03);
- min=Byte_Read(0X04);
- sec=Byte_Read(0X05);
- week=Byte_Read(0X06);
- Init_Timer0();
- EA = 1; //打開總中斷
- InitADC();
- Init_lcd();
- Clr_Scr(); J5=1;
- Delay100(30);
- // Delay12864(20000);
- Lcd_Mark1();
- // Delay12864(10000);
- EA=1;
- flag=0;G1=1;
- while(1)
- write_com(Disp_On);
- a[0]=(GetADCResult(0)<<2|ADC_LOW2); a[0]=a[0]/100*3*month; Delay12864(20);
- a[1]=(GetADCResult(1)<<2|ADC_LOW2); a[1]=a[1]/100*3*month; Delay12864(20);
- // a[2]=GetADCResult(2);
- // a[3]=GetADCResult(3);
- // a[4]=GetADCResult(4);
- // a[5]=GetADCResult(5);a[5]=a[5]<<1;
- // a[6]=GetADCResult(6);a[5]=a[6]<<1;
- // a[7]=GetADCResult(7);a[5]=a[7]<<1;
- //a[3]=ad[3];
- if(Dsp==0)
- if(Dsp==0)
- flag=~flag ;
- while(Dsp==0);
- if( flag==0)
- {//Disp();
- Clr_Scr(); Lcd_Mark1(); Lcd_Mark2();
- if( flag==1)
- { Clr_Scr(); Disp();
- if ((a[0]>300)&&(a[1]>300))
- {Delay100(1000);G1=0;
- if ( G1==0)
- if( (a[0]<year)&&(a[1]<year))
- Delay100(hour);
- J5=0;Delay100(hour);J5=1;
- // if( (a[5]>year)||(a[6]>year)||(a[7]>year))
- // {J5=0;Delay100(100 ); }
- // if( (a[2]>month)||(a[3]>month)||(a[4]>month))
- // { Delay100(min-30 );
- // J5=0; Delay100(100 ); J5=1; }
- // if( (a[2]>date)||(a[3]>date)||(a[4]>date))
- // { Delay100(sec-30 );
- if(Ent==0)
- { if(Ent==0)
- { Sector_Erase(0x00);
- Byte_Program(0x00, year>>2);
- Byte_Program(0x00+1, month);
- Byte_Program(0x00+2, date);
- Byte_Program(0x00+3, hour);
- Byte_Program(0x00+4, min);
- Byte_Program(0x00+5, sec);
- Byte_Program(0x00+6, week);
- while(Ent==0); }
- /* switch( id )
- case 0: Disp( ); Delay12864(20000); break;//正常顯示
- case 1:year1 = 1;Add_key1(); Disp( ); break;//年
- case 2:month1=1;Add_key1();Disp();break;//月
- case 3:day1=1;;Add_key1();Disp();break; //日
- case 4:hour1=1;Add_key1();Disp();break;//星期
- case 5:min1=1;Add_key1();Disp();break; //小時(shí)
- case 6:sec1=1;Add_key1();Disp();break; //分鐘
- case 7:sec1=1;Add_key1();Disp();break; //秒
- default:break;
- void Timer0_isr(void) interrupt 1 using 1
- TH0=0x00; //重新賦值
- TL0=0x01;
- LED=~LED;
- { if(Mode==0)
- // Delay12864(20);
- if(Mode==0)
- id++;
- if(id>8) id=0;
- while(Mode==0); }
- if(id==1)
- { if(Add==0)
- Delay12864(20);
- if(Add==0)
- { year++;
- if (year>0x0fff) year=0;
- while(Add==0);
- if(Dec==0)
- Delay12864(20);
- if(Dec==0)
- { year--; if (year<0x00) year=0;
- while(Dec==0);
- if(id==2)
- { if(Add==0)
- Delay12864(20);
- if(Add==0)
- { month++;if (month>0xff) month=0;
- while(Add==0);
- if(Dec==0)
- Delay12864(20);
- if(Dec==0)
- { month--;if (month<0x00) month=0;
- while(Dec==0);
- if(id==3)
- { if(Add==0)
- Delay12864(20);
- if(Add==0)
- { date++; if (date>0xff) date=0;
- while(Add==0);
- if(Dec==0)
- Delay12864(20);
- if(Dec==0)
- {date--;//if (date<0x00) date=0;
- while(Dec==0);
- if(id==4)
- { if(Add==0)
- Delay12864(20);
- if(Add==0)
- { hour++;
- if(hour>100)hour=0;
- while(Add==0);
- if(Dec==0)
- Delay12864(20);
- if(Dec==0)
- {hour--;if(hour>100)hour=0;
- while(Dec==0);
- if(id==5)
- { if(Add==0)
- Delay12864(20);
- if(Add==0)
- { min++;if((min>0xff)||(min<30))min=30;
- while(Add==0);
- if(Dec==0)
- Delay12864(20);
- if(Dec==0)
- {min--;if((min>0xff)||(min<30))min=30;
- while(Dec==0);
- if(id==6)
- { if(Add==0)
- Delay12864(20);
- if(Add==0)
- { sec++;if((sec>0xff)||(sec<30))sec=30;
- while(Add==0);
- if(Dec==0)
- Delay12864(20);
- if(Dec==0)
- {sec--;if((sec>0xff)||(sec<30))sec=30;
- while(Dec==0);
- if(id==7)
- { if(Add==0)
- Delay12864(20);
- if(Add==0)
- { week++;if(week>100)week=0;
- while(Add==0);
- if(Dec==0)
- Delay12864(20);
- if(Dec==0)
- {week--;if(week>100)week=0;
- while(Dec==0);
- if(id==8)
- id=0;
- { write_com(Disp_On);
- Mcs=0;Scs=1; //第二屏
- f= a[0]/1000%10;
- g= a[0]/100%10;
- d= a[0]/10%10;
- e= a[0]%10;
- Disp_Digit(2,16,zero+f*16);
- Disp_Digit(2,24,zero+g*16);
- Disp_Digit(2,32,zero+d*16);Disp_Digit(2,40,point );
- Disp_Digit(2,48,zero+e*16);
- f= a[1]/1000%10;
- g= a[1]/100&10;
- d= a[1]/10%10;
- e= a[1]%10;
- Disp_Digit(4,16,zero+f*16);
- Disp_Digit(4,24,zero+g*16);
- Disp_Digit(4,32,zero+d*16); Disp_Digit(4,40,point );
- Disp_Digit(4,48,zero+e*16);
- Disp_Digit(6,16,zero+( week/10)*16);
- Disp_Digit(6,24,zero+( week%10)*16);
- void Disp(void)//顯示和閃爍函數(shù)
- unsigned int i=0;
- unsigned char a=0,b=0,c=0,f=0;
- Clr_Scr();
- Mcs=1;Scs=0;
- Disp_Digit(0,0,space); Disp_Digit(0,8,space);Disp_Digit(0,16,space); Disp_Digit(0,24,space);
- Disp_Chinese(0,32,bao);
- Disp_Chinese(0,48,hu);
- Mcs=1;Scs=0;
- {Disp_Chinese(2,0,dya);
- Disp_Chinese(2,16,ya);
- f=year/1000;
- g=year/100; //低壓值
- d=year/10%10;
- e=year%10;
- if(id!=1)
- { Disp_Digit(2,32,zero+f*16);
- Disp_Digit(2,40,zero+g*16);
- Disp_Digit(2,48,zero+d*16);// Disp_Digit(2,48,point );
- Disp_Digit(2,56,zero+e*16);}
- if(id==1)
- { Disp_Digit_f(2,32,zero+f*16);
- Disp_Digit_f(2,40,zero+g*16);
- Disp_Digit_f(2,48,zero+d*16);// Disp_Digit(2,48,point );
- Disp_Digit_f(2,56,zero+e*16);}
- { g=hour/100;
- d=hour/10%10;
- e=hour%10;
- Mcs=1;Scs=0;
- Disp_Chinese(4,0,xian); Disp_Chinese(4,16,shi);
- if(id!=4)
- { Disp_Digit(4,40,zero+d*16); Disp_Digit(4,48,point );
- Disp_Digit(4,56,zero+e*16);}
- if(id==4)
- { Disp_Digit_f(4,40,zero+d*16); Disp_Digit_f(4,48,point );
- Disp_Digit_f(4,56,zero+e*16);}
- d=week/10;
- e=week%10; //地址
- Mcs=1;Scs=0;
- Disp_Chinese(6,0,di);
- Disp_Chinese(6,16,zhi);
- Disp_Digit(6,32,space); Disp_Digit(6,40,space);
- if(id!=7)
- { Disp_Digit(6,48,zero+d*16);
- Disp_Digit(6,56,zero+e*16);}
- if(id==7)
- { Disp_Digit_f(6,48,zero+d*16);
- Disp_Digit_f(6,56,zero+e*16);}
- { Mcs=0;Scs=1; //右
- Disp_Chinese(0,0,tiao);
- Disp_Chinese(0,16,zheng);
- Disp_Digit(0,32,space); Disp_Digit(0,40,space); Disp_Digit(0,48,space); Disp_Digit(0,56,space);
- { g=month/100;
- d=month/10%10;
- e=month%10;
- Disp_Digit(2,0,space); Disp_Digit(2,8,space);
- Disp_Digit(2,16,K); Disp_Digit(2,24,space);
- if(id!=2)
- { Disp_Digit(2,32,zero+g*16);
- Disp_Digit(2,40,zero+d*16);
- Disp_Digit(2,48,zero+e*16);}
- if(id==2)
- { Disp_Digit_f(2,32,zero+g*16);
- Disp_Digit_f(2,40,zero+d*16);
- Disp_Digit_f(2,48,zero+e*16);}
- Disp_Digit(2,56,space);
- d=sec/10%10;
- e=sec%10;
- Mcs=0;Scs=1;
- Disp_Digit(4,0,space); Disp_Digit(4,8,space); Disp_Digit(4,16,space); Disp_Digit(4,24,space);
- Disp_Digit(4,32,space); Disp_Digit(4,40,space); Disp_Digit(4,48,space); Disp_Digit(4,56,space);
- Mcs=0;Scs=1;
- d=id/10;
- e=id%10;
- Mcs=0;Scs=1;
- Disp_Chinese(6,0,tiao); Disp_Chinese(6,16,zheng);
- Disp_Digit(6,40,zero+d*16);//送顯示
- Disp_Digit(6,48,zero+e*16);
- Disp_Digit(6,56,space);
低壓.rar
(57.7 KB, 下載次數(shù): 8)
2019-11-16 11:02 上傳
點(diǎn)擊文件名下載附件
