查看: 2841|回復: 1
51單片機音樂盒元件清單與源程序
ID:638831 發表于 2019-11-9 20:23 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
一.材料
發光二極管                                  18個;
按鍵                                              4個;
STC89c52單片機                        1個;
單片機插座                                  1個;
11.0592MHZ的晶振                  1個;
22pf電容*2,10uf電容              1個;
喇叭                                              1個;
三極管                                          1個;
滑動變阻器                                  1個;
電阻10k                                       1個;
電阻5.1k           1個;
電源
杜邦線若干;
#include <reg51.h>
sbit speaker = P3^1;
sbit key0 = P2^0;
sbit key1 = P2^1;
sbit key2 = P2^2;
sbit key3 = P2^3;
unsigned char k, i;
unsigned char timer0h, timer0l, time ,num ,tempi,tempstop,tempan,temptime;
unsigned char code table[]={//我做的數碼管 數字顯示
0x3f,0x30,0xed,0x79,
0x72,0x5b,0x5f};
unsigned char code table[]={  //數碼管 數字顯示
0x3f,0x06,0x5b,0x4f,
0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x77,0x7c,
0x39,0x5e,0x79,0x71};
//---------------------------------1 2 3 4 5 6 7音調
code unsigned char FREQH[] = {           //TH0部分
    0xF2, 0xF3, 0xF5, 0xF5, 0xF6, 0xF7, 0xF8,       //低音1234567
    0xF9, 0xF9, 0xFA, 0xFA, 0xFB, 0xFB, 0xFC, 0xFC,   //中
    0xFC, 0xFD, 0xFD, 0xFD, 0xFD, 0xFE,              //高
    0xFE, 0xFE, 0xFE, 0xFE, 0xFE, 0xFE, 0xFF    //超高
code unsigned char FREQL[] = {           //TL0部分
    0x42, 0xC1, 0x17, 0xB6, 0xD0, 0xD1, 0xB6,
    0x21, 0xE1, 0x8C, 0xD8, 0x68, 0xE9, 0x5B, 0x8F,
    0xEE, 0x44, 0x6B, 0xB4, 0xF4, 0x2D,
    0x47, 0x77, 0xA2, 0xB6, 0xDA, 0xFA, 0x16
code unsigned char song[][150]={    //歌曲
{3,2,2, 3,2,2, 3,2,2, 1,2,1, 3,2,2, 0,0,0, 5,2,2, 0,0,0,
5,1,2, 0,0,0, 1,2,1, 0,0,0, 5,1,1, 0,0,0, 3,1,2, 0,0,0,
6,1,2, 7,1,2, 7,1,2, 6,1,2, 5,1,2, 3,2,2, 5,2,1, 6,2,1,
0,0,0, 4,2,1, 5,2,1, 0,0,0, 3,2,1, 0,0,0, 1,2,1, 2,2,1,
7,1,2, 0,0,0, 1,2,2, 0,0,0, 5,1,1, 0,0,0, 0,0,0, 3,1,1,
0,0,0, 6,1,2, 7,1,2, 0,0,0, 7,1,2, 6,1,2, 5,1,2, 3,2,2, 0,0,100
{6, 2, 3,  5, 2, 1,  3, 2, 2,  5, 2, 2,  1, 3, 2,  6, 2, 1,  5, 2, 1,
//一個音符有三個數字。前為第幾個音、中為第幾個八度、后為時長(以半拍為單位)。
//6, 2, 3 分別代表:6, 中音, 3個半拍;
//5, 2, 1 分別代表:5, 中音, 1個半拍;
//3, 2, 2 分別代表:3, 中音, 2個半拍;
//5, 2, 2 分別代表:5, 中音, 2個半拍;
//1, 3, 2 分別代表:1, 高音, 2個半拍;
6, 2, 4, 3, 2, 2, 5, 2, 1, 6, 2, 1, 5, 2, 2, 3, 2, 2, 1, 2, 1,
6, 1, 1, 5, 2, 1, 3, 2, 1, 2, 2, 4, 2, 2, 3, 3, 2, 1, 5, 2, 2,
5, 2, 1, 6, 2, 1, 3, 2, 2, 2, 2, 2, 1, 2, 4, 5, 2, 3, 3, 2, 1,
2, 2, 1, 1, 2, 1, 6, 1, 1, 1, 2, 1, 5, 1, 6, 0, 0, 100},
{6, 3, 1, 6, 3, 1, 6, 3, 1, 6, 3, 1, 6, 3, 1, 6, 3, 1, 0,0,100},
{0,0,1, 0,0,100},
void delay(unsigned char t)     //節拍
unsigned char t1;
unsigned long t2;
for(t1 = 0; t1 < t; t1++)
  for(t2 = 0; t2 < 8000; t2++);
TR0 = 0;
void delaya(unsigned char t)     //節拍
unsigned char t1;
unsigned long t2;
  for(t2 = 0; t2 < 2000; t2++);
TR0 = 0;
void delay1(int z)   //延遲z ms
int i,j;
for(i=0;i<110;i++)
  for(j=0;j<z;j++);
void an()  //按鍵檢測
P2=0xff;
if(key1==0||key2==0||key3==0)
  delay1(10);
  if(key1==0)
   num++;
   if(num==4)
     num=0;
   i=0;
   time=0;
  if(key2==0)
   num--;
   if(num==-1)
     num=3;
   i=0;
   time=0;
  if(key3==0)
   tempstop=!tempstop;
  while(!key1||!key2||!key3);
  delay1(5);
void an()  //按鍵檢測
P2=0xff;
tempan=P2;
tempan=tempan&0x0f;
while(tempan!=0x0f)
  delay1(5);
  tempan=P2;
  tempan=tempan&0x0f;
  while(tempan==0x0f);
  switch(tempan)
   case 0x0e:
    num++;
    if(num==4)
      num=0;
    i=0;
    time=0;
    break;
   case 0x0d:
    num--;
    if(num==-1)
      num=3;
    i=0;
    time=0;
    break;
   case 0x0b:
    tempstop=!tempstop;
    break;
   case 0x07:
    temptime=!temptime;
    break;
  while(tempan!=0x0f)
   tempan=P2;
   tempan=tempan&0x0f;
   delay1(5);
void main(void)
tempi=1;
TMOD = 1;
ET0 = 1;
EA = 1;
  if(song[num][i+2]==100)
   i=0;
  k = song[num]+7*(song[num][i + 1]-1);
  timer0h = FREQH[k];
  timer0l = FREQL[k];
  time = song[num][i + 2];
  if(tempi==1)
  i += 3;
  TH0 = timer0h;
  TL0 = timer0l;
  TR0 = 1;
  if(!temptime)
   delay(time);
   delaya(time);
  P1=table[num+1];
  while(tempstop)
   an();
void t0int() interrupt 1
    TR0 = 0;
    speaker = !speaker;
    TH0 = timer0h;
    TL0 = timer0l;
    TR0 = 1;
  an();
收藏收藏2 分享淘帖 頂 踩
ID:895633 發表于 2021-3-28 22:41 | 只看該作者
樓主  有仿真圖嗎   還有材料還需要買什么嗎  我想做出來  謝謝
