查看: 1179|回復: 0
初學Arduino單片機的藍牙小車,倒退時小車異常
ID:564485 發表于 2019-11-7 21:40 | 顯示全部樓層 |閱讀模式
代碼如下:#include <SoftwareSerial.h>
SoftwareSerial  mySerial(8,9);  //定義軟串口對象
void setup() {
  // put your setup code here, to run once:
  mySerial.begin(115200);  //藍牙接收串口
  int_car_pin();
  set_speed(140);
//前進--0xa
//后退--0xb
//前進--0xc
//后退--0xd
//停止--0x10
void loop() {
  // put your main code here, to run repeatedly:
  int ch = 0;
  mySerial.listen(); //表示監聽我們的軟串口數據
  while(mySerial.available() > 0)
         Serial.println("Recv data : ");
        ch = mySerial.read(); //軟串口讀出,寫到arduino開發板上
        switch(ch)
            case 0xa:
              car_forward();
              break;
            case 0xb:
              car_back();
               break;
            case 0xc:
              car_left();
              break;
            case 0xd:
              car_right();
              break;
            case 0x10:
              car_stop();
              break;
  return ;
//對應的四個電機驅動
int  IN1 = 13;  //右邊輪子
int  IN2 = 12;  //右邊輪子
int  IN3 = 11;  //左邊輪子
int  IN4 = 10;  //左邊輪子
int pwmleft  = 5;
int pwmright = 6;
void int_car_pin() {
  pinMode(IN1,OUTPUT);
  pinMode(IN2,OUTPUT);
  pinMode(IN3,OUTPUT);
  pinMode(IN4,OUTPUT);
void leftMotorForward() //左邊正轉
  digitalWrite(IN3, LOW);
  digitalWrite(IN4, HIGH);
void leftMotorBack() //左邊反轉
  digitalWrite(IN3, HIGH);
  digitalWrite(IN4, LOW);
void rightMotorForward() //右邊正轉
{//1
  digitalWrite(IN1, LOW);
  digitalWrite(IN2, HIGH);
void rightMotorBack() //右邊發轉
{//2
  digitalWrite(IN1, HIGH);
  digitalWrite(IN2, LOW);
void car_forward()
     leftMotorForward();
     rightMotorForward();
     delay(500);
void car_back()
      leftMotorBack();
      rightMotorBack();
      delay(500);
void car_left()
      leftMotorBack();
      delay(500);
      car_forward();
      delay(500);
void car_right()
      leftMotorForward();
      rightMotorBack();
      delay(500);
      car_forward();
      delay(500);
void car_stop()
     delay(500);
void set_speed(int speed_value)
     analogWrite(pwmleft, speed_value);
     analogWrite(pwmright, speed_value);
運行后,小車前行,哎左轉,右轉正常。
倒退時小車異常
求大神解決
