查看: 1709|回復: 0
51單片機 99秒馬表設計
ID:633011 發(fā)表于 2019-10-30 23:27 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include <AT89X51.H>
unsigned char code dispcode[]={0x3f,0x06,0x5b,0x4f,
                               0x66,0x6d,0x7d,0x07,
                               0x7f,0x6f,0x77,0x7c,
                               0x39,0x5e,0x79,0x71,0x00};
unsigned char second;
unsigned char keycnt;
unsigned int tcnt;
void main(void)
  unsigned char i,j;
  TMOD=0x02;
  ET0=1;
  EA=1;
  second=0;
  P0=dispcode[second/10];
  P2=dispcode[second%10];
      if(P3_5==0)
          for(i=20;i>0;i--)
          for(j=248;j>0;j--);
          if(P3_5==0)
              keycnt++;
              switch(keycnt)
                  case 1:
                    TH0=0x06;
                    TL0=0x06;
                    TR0=1;
                    break;
                  case 2:
                    TR0=0;
                    break;
                  case 3:
                    keycnt=0;
                    second=0;
                    break;
              while(P3_5==0);
void t0(void) interrupt 1 using 0
  tcnt++;
  if(tcnt==400)
      tcnt=0;
      second++;
      if(second==100)
          second=0;
《AT89S51單片機試驗及實踐教程》用Proteus仿真34例(C代碼 仿真實例).zip
4.93 MB, 下載次數(shù): 11, 下載積分: 黑幣 -5
