向epprom寫入數值2,讀取之后數碼管顯示,再把數值加1,重復寫入讀取,顯示這個步驟,一直加到99,為什么數碼管卻一直顯示剛開始的數值
2,求各位前輩指點!
下面把代碼附上:
#include <reg52.h>
#include <intrins.h>
sbit SCL=P3^4;
sbit SDA=P3^5;
bit Ackflag;
char k;
char code duan[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90};
char code we[]={0xfe,0xfd};
void delay5us()
_nop_();
void init()
SCL=1;
delay5us();
SDA=1;
delay5us();
void I2c_start()
SCL=1;
delay5us();
SDA=1;
delay5us();
SDA=0;
delay5us();
void I2c_stop()
SCL=0;
SDA=0;
delay5us();
SCL=1;
delay5us();
SDA=1;
delay5us();
bit Read_Ack()
SCL=0;
SCL=1;
delay5us();
if(SDA)
SCL=0;
return 1;
SCL=0;
return 0;
void Send_Ack(bit i)
SCL=0;
if(i)
SDA=1;
SDA=0;
SCL=1;
delay5us();
SCL=0;
SDA=1;
void I2c_sendbyte(char dat)
char i;
for(i=0;i<8;i++)
SCL=0;
if(dat&0x80)
SDA=1;
SDA=0;
SCL=1;
dat=dat<<1;
SCL=0;
SDA=1;
char I2c_readbyte()
char i,dat;
for(i=0;i<8;i++)
dat<<=1;
SCL=0;
SCL=1;
if(SDA)
dat|=0x01;
return(dat);
void Write(char addr,char dat)
I2c_start();
I2c_sendbyte(0xa0);//send a byte address
if(Read_Ack())
Ackflag=1;
Ackflag=0;
I2c_sendbyte(addr);
if(Read_Ack())
Ackflag=1;
Ackflag=0;
I2c_sendbyte(dat);
if(Read_Ack())
Ackflag=1;
Ackflag=0;
I2c_stop();
char Read(char addr)
char dat;
I2c_start();
if(Read_Ack())
Ackflag=1;
Ackflag=0;
I2c_sendbyte(addr);
Read_Ack();
I2c_start();
I2c_sendbyte(0xa1); //read 1
if(Read_Ack())
Ackflag=1;
Ackflag=0;
dat=I2c_readbyte();
Send_Ack(1);
I2c_stop();
return (dat);
void delay(char z)
char x,y;
for(x=z;x>0;x--)
for(y=110;y>0;y--);
void display(char shi,char ge)
P2=0xfd;
P0=duan[ge];
delay(5);
P2=0xfe;
P0=duan[shi];
delay(5);
char num;
init();
TMOD=0x01;
EA=1;
ET0=1;
TH0=(65536-46080)/256;
TL0=(65536-46080)%256;
TR0=1;
for(k=2;k<100;k++)
Write(2,k);
delay(1);
num=Read(2);
if(Ackflag)
P1=0;
P1=0xff;
display(num/10,num%10);
