查看: 870|回復: 0
nordic lcd 顯示LCD源碼
ID:632518 發(fā)表于 2019-10-30 14:19 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
        NRF_GPIO->OUTCLR = (1UL<<LCD_RESET);
        nrf_delay_ms(15);
        NRF_GPIO->OUTSET = (1UL<<LCD_RESET);
        nrf_delay_ms(15);
        NRF_GPIO->OUTSET = (1UL<<LCD_PWM_BK_EN);
        NRF_GPIO->OUTSET = (1UL<<LCD_3V3);
        nrf_delay_ms(20);
LCD_CM_WRITE(0x36);
LCD_DATA_WRITE(0x00);
LCD_CM_WRITE(0x3A);
LCD_DATA_WRITE(0x55); //65K/16Bit, 66-->262K/18bit
LCD_CM_WRITE(0xB2);
LCD_DATA_WRITE(0x0C);
LCD_DATA_WRITE(0x33);
LCD_CM_WRITE(0xB7);
LCD_DATA_WRITE(0x21);   //VGH,VGL;  75
LCD_CM_WRITE(0xBB);
LCD_DATA_WRITE(0x3F);   //Vcom=1.625V;  3D
LCD_CM_WRITE(0xC2);
LCD_DATA_WRITE(0x01);
LCD_CM_WRITE(0xC3);
LCD_DATA_WRITE(0x19);   //GVDD=4.8V
LCD_CM_WRITE(0xC4);
LCD_DATA_WRITE(0x20);   //VDV, 0x20:0v
LCD_CM_WRITE(0xC6);
LCD_DATA_WRITE(0x0F);   //0x0F:60Hz
LCD_CM_WRITE(0xD0);
LCD_DATA_WRITE(0xA4);
LCD_DATA_WRITE(0xA1);
LCD_CM_WRITE(0xE0);
LCD_DATA_WRITE(0x70);
LCD_DATA_WRITE(0x04);
LCD_DATA_WRITE(0x08);
LCD_DATA_WRITE(0x09);
LCD_DATA_WRITE(0x05);
LCD_DATA_WRITE(0x2A);
LCD_DATA_WRITE(0x41);
LCD_DATA_WRITE(0x07);
LCD_DATA_WRITE(0x13);
LCD_DATA_WRITE(0x29);
LCD_DATA_WRITE(0x2F);
LCD_CM_WRITE(0xE1);
LCD_DATA_WRITE(0x03);
LCD_DATA_WRITE(0x0A);
LCD_DATA_WRITE(0x06);
LCD_DATA_WRITE(0x2B);
LCD_DATA_WRITE(0x34);
LCD_DATA_WRITE(0x12);
LCD_DATA_WRITE(0x14);
LCD_DATA_WRITE(0x28);
LCD_DATA_WRITE(0x2E);
LCD_CM_WRITE(0x21);  //Display Inversion On
LCD_CM_WRITE(0x29);
