程序的目的是實(shí)現(xiàn) 八位數(shù)碼管實(shí)時(shí)顯示時(shí)分秒,循環(huán)顯示周期為“00-00-00 至 23-59-59”。
按鍵1設(shè)置時(shí)加 按鍵2設(shè)置時(shí)減1 按鍵3進(jìn)入設(shè)置模式 按鍵4切換鬧鐘和時(shí)鐘顯示界面 按鍵5設(shè)置時(shí)位選
大部分內(nèi)容已經(jīng)實(shí)現(xiàn) 在我想加入T1做為定時(shí)檢測(cè)鬧鐘與時(shí)鐘數(shù)值并在鬧鐘與時(shí)鐘數(shù)值相等時(shí)使得蜂鳴器響1分鐘 但T1定時(shí)器中斷無(wú)法正常運(yùn)作。
2019-10-30 12:51 上傳
單片機(jī)源程序如下:
- #include <reg51.h>
- #define uc unsigned char
- #define ui unsigned int
- uc code duan[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
- uc code weima[]={0xfe,0xfd,0xf7,0xef,0xbf,0x7f};
- int zancun1[6];
- int zancun2[6];
- uc second1=0,minute1=0,hour1=0,second2=0,minute2=0,hour2=0;
- ui mode=0,set=0,setw=0,set1=0,setw1=0;
- sbit K1=P3^0;
- sbit K2=P3^1;
- sbit K3=P3^2;
- sbit K4=P3^3;
- sbit K5=P3^4;
- sbit P00=P0^0;
- void chu1(uc x,y,z,o,p,q)
- zancun1[0]=x%10;
- zancun1[1]=x/10;
- zancun1[2]=y%10;
- zancun1[3]=y/10;
- zancun1[4]=z%10;
- zancun1[5]=z/10;
- zancun2[0]=o%10;
- zancun2[1]=o/10;
- zancun2[2]=p%10;
- zancun2[3]=p/10;
- zancun2[4]=q%10;
- zancun2[5]=q/10;
- void save1()
- second1=zancun1[1]*10+zancun1[0];
- minute1=zancun1[3]*10+zancun1[2];
- hour1=zancun1[5]*10+zancun1[4];
- void save2()
- second2=zancun2[1]*10+zancun2[0];
- minute2=zancun2[3]*10+zancun2[2];
- hour2=zancun2[5]*10+zancun2[4];
- ui chouse(int a,int b)
- switch(a)
- case 0: if(b<=0||b>=10){b=0;}zancun1[0]=b;break;
- case 1: if(b<=0||b>=6){b=0;}zancun1[1]=b;break;
- case 2: if(b<=0||b>=10){b=0;}zancun1[2]=b;break;
- case 3: if(b<=0||b>=6){b=0;}zancun1[3]=b;break;
- case 4: if(b<=0||b>=5){b=0;}zancun1[4]=b;break;
- case 5: if(b<=0||b>=3){b=0;}zancun1[5]=b;break;
- return (set=b);
- ui chouse2(int a,int b)
- switch(a)
- case 0: if(b<=0||b>=10){b=0;}zancun2[0]=b;break;
- case 1: if(b<=0||b>=6){b=0;}zancun2[1]=b;break;
- case 2: if(b<=0||b>=10){b=0;}zancun2[2]=b;break;
- case 3: if(b<=0||b>=6){b=0;}zancun2[3]=b;break;
- case 4: if(b<=0||b>=5){b=0;}zancun2[4]=b;break;
- case 5: if(b<=0||b>=3){b=0;}zancun2[5]=b;break;
- return (set1=b);
- void delay(unsigned int y)
- unsigned char j;
- unsigned int i;
- for(i=0;i<y;i++)
- for(j=0;j<120;j++);
- void shizhong(ui o,p,q)
- P1=weima[0];
- P2=duan[o%10];
- delay(8);
- P1=weima[1];
- P2=duan[o/10];
- delay(8);
- P1=weima[2];
- P2=duan[p%10];
- delay(8);
- P1=weima[3];
- P2=duan[p/10];
- delay(8);
- P1=weima[4];
- P2=duan[q%10];
- delay(8);
- P1=weima[5];
- P2=duan[q/10];
- delay(8);
- P1=0xdb;
- P2=0x40;
- delay(8);
- P1=0xff;
- void time0s()
- TMOD|=0X01;
- TH0=0X3c;
- TL0=0Xb0;
- ET0=1;
- TR0=1;
- PT0=1;
- PT1=0;
- void time1sON()
- TMOD|=0X10;
- TH1=0X3c;
- TL1=0Xb0;
- ET1=1;
- TR1=1;
- void Time0() interrupt 1
- static ui i=0;
- TH0=0X3C;
- TL0=0Xb0;
- i++;
- if(i==20)
- i=0;
- second1++;
- if(second1==60)
- second1=0;
- minute1++;
- if(minute1==60)
- minute1=0;
- hour1++;
- if(hour1==24)
- hour1=0;
- void Time1() interrupt 3
- static ui i=0,r=0;
- TH1=0X3C;
- TL1=0Xb0;
- if(i==20)
- r++;
- if(r==60)
- if(minute1==minute2&&hour1==hour2)
- for(r=0;r<10;r++)
- P00=~P00;
- delay(100);
- r=0;
- void key()
- EA=1;
- EX1=1;
- IT1=1;
- EX0=1;
- IT0=1;
- void key3() interrupt 0
- EX1=0;
- chu1(second1,minute1,hour1,second2,minute2,hour2);
- while(1)
- if(mode==0)
- set=zancun1[setw];
- P1=weima[setw];
- P2=duan[set];
- delay(400);
- P1=0xff;
- delay(400);
- if(K1==0){delay(50);set++;chouse(setw,set);}
- if(K2==0){delay(50);set--;chouse(setw,set);}
- if(K5==0){delay(50);setw++;set=0;if(setw>=6){setw=0;}}
- if(K3==0){delay(50);save1();set=0;setw=0;break;}
- else
- set1=zancun2[setw1];
- P1=weima[setw1];
- P2=duan[set1];
- delay(400);
- P1=0xff;
- delay(400);
- if(K1==0){delay(50);set1++;chouse2(setw1,set1);}
- if(K2==0){delay(50);set1--;chouse2(setw1,set1);}
- if(K5==0){delay(50);setw1++;set1=0;if(setw1>=6){setw1=0;}}
- if(K3==0){delay(50);save2();set1=0;setw1=0;break;}
- IE0=0;
- IE1=0;
- EX1=1;
- void key4() interrupt 2
- mode=~mode;
- IE1=0;
- void main()
- key();
- time0s();
- time1sON();
- while(1)
- if(mode==0)
- shizhong(second1,minute1,hour1);
- if(mode!=0)
- shizhong(second2,minute2,hour2);
