使用veriog實(shí)現(xiàn)冒泡排序
verilog源程序如下:
- `timescale 1ns / 1ps
- // Company:
- // Engineer:
- // Create Date: 09:16:46 03/30/2018
- // Design Name:
- // Module Name: mian
- // Project Name:
- // Target Devices:
- // Tool versions:
- // Description:
- // Dependencies:
- // Revision:
- // Revision 0.01 - File Created
- // Additional Comments:
- //=============================== 說(shuō)明 =====================================
- // 按照地址從小往大遞增的順序,數(shù)據(jù)是從大到小排列
- module main#(
- parameter ROW_WIDTH = 8, //行
- parameter COL_WIDTH = 16 //列
- input clk,
- input rst,
- input enable
- reg [15:0] comp_data_i; //數(shù)據(jù)
- reg valid_i; //數(shù)據(jù)有效
- reg [15:0] data [COL_WIDTH:1];
- reg [7:0] count;
- initial
- begin
- data[1] = 16'd20;
- // data[2] = 16'd723;
- data[2] = 16'd20;
- data[3] = 16'd12;
- data[4] = 16'd456;
- data[5] = 16'd278;
- data[6] = 16'd9756;
- data[7] = 16'd433;
- data[8] = 16'd10000;
- data[9] = 16'd21;
- data[10] = 16'd724;
- data[11] = 16'd15;
- data[12] = 16'd458;
- data[13] = 16'd279;
- data[14] = 16'd9758;
- data[15] = 16'd439;
- data[16] = 16'd30;
- end
- always@(posedge clk or posedge rst)
- begin
- if(rst)
- begin
- count <= COL_WIDTH + 1;
- valid_i <= 0;
- comp_data_i <= 0;
- end
- else if(enable)
- begin
- count <= 1;
- end
- else if(count <= COL_WIDTH)
- begin
- comp_data_i <= data[count];
- count <= count + 1;
- valid_i <= 1;
- end
- else
- begin
- valid_i <= 0;
- count <= count;
- end
- end
- // 并行比較排序算法
- parallel u0_parallel (
- .clk ( clk ),
- .rst ( rst ),
- .comp_data_i ( comp_data_i ),
- .valid_i ( valid_i )
- // 串行比較排序算法
- serial u1_serial (
- .clk ( clk ),
- .rst ( rst ),
- // 冒泡法
- bubbling u2_bubbling (
- .clk ( clk ),
- .rst ( rst ),
- endmodule
Sort_prj.rar
(844 KB, 下載次數(shù): 15)
2019-10-28 16:27 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
評(píng)分
查看全部評(píng)分
