查看: 4124|回復: 2
STM32L151+SPI+TFTLCD+HAL例程
ID:356403 發(fā)表于 2019-10-21 14:30 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
        Lcd_Init();
        Lcd_Clear_xy(0,0,BLACK);
//        Gui_DrawFont_GBK16(0,0,YELLOW,RED,"TTTTTT");//顯示字符串
//        Gui_DrawFont_GBK16(0,0,YELLOW,RED,"YYYY");
//        Gui_DrawFont_GBK16(32,0,YELLOW,RED,"  ");
//        Lcd_Clear_xy(64,100,YELLOW);//清空 從64,100到128,128
//        Lcd_Clear_xy_xy(30,30,100,60,YELLOW);//清空從 30,30到100,60
//  Lcd_Clear_xy_xy(32,30,68,33,YELLOW);
        HAL_TIM_Base_Start_IT(&htim2);
        showimage(gImage_zxc);//顯示圖片
        //Gui_DrawFont_GBK16(40,116,YELLOW,RED,(uint8_t *)"TTTTTT");
        //Lcd_Clear(RED);//清屏填充顏色
        //showimage(gImage_zxc);
//向液晶屏寫一個8位指令
void Lcd_WriteIndex(uint8_t Index)
   //SPI 寫命令時序開始
    //NSS = 0;
    LCD_CS_CLR;
    LCD_RS_CLR;           //LCD_RS_CLR
    HAL_SPI_Transmit(&hspi1,&Index,1,0xfff);
    //NSS = 1;
    LCD_CS_SET;
//向液晶屏寫一個8位數(shù)據(jù)
void Lcd_WriteData(uint8_t Data)
        LCD_CS_CLR;
        LCD_RS_SET;
        HAL_SPI_Transmit(&hspi1,&Data,1,0xfff);
        LCD_CS_SET;
void LCD_WriteData_16Bit(uint16_t Data)
  uint8_t Data_H = Data>>8;
  uint8_t Data_L = Data&0xFF;
         LCD_CS_CLR;
         LCD_RS_SET;
         HAL_SPI_Transmit(&hspi1,&Data_H,1,0xfff);         //寫入高8位數(shù)據(jù)
         HAL_SPI_Transmit(&hspi1,&Data_L,1,0xfff);         //寫入低8位數(shù)據(jù)
         LCD_CS_SET;
//LCD Init For 1.44Inch LCD Panel with ST7735R.
void Lcd_Init(void)
       // LCD_GPIO_Init();
  HAL_GPIO_WritePin(GPIOA, GPIO_PIN_1, 1);
  LCD_RST_CLR;
        HAL_Delay(100);
        LCD_RST_SET;
        HAL_Delay(50);
        Lcd_WriteIndex(0x11);//Sleep exit
        HAL_Delay(120);
        //ST7735R Frame Rate
        Lcd_WriteIndex(0xB1);
        Lcd_WriteData(0x01);
        Lcd_WriteData(0x2C);
        Lcd_WriteData(0x2D);
        Lcd_WriteIndex(0xB2);
        Lcd_WriteIndex(0xB3);
        Lcd_WriteIndex(0xB4); //Column inversion
        Lcd_WriteData(0x07);
        //ST7735R Power Sequence
        Lcd_WriteIndex(0xC0);
        Lcd_WriteData(0xA2);
        Lcd_WriteData(0x02);
        Lcd_WriteData(0x84);
        Lcd_WriteIndex(0xC1);
        Lcd_WriteData(0xC5);
        Lcd_WriteIndex(0xC2);
        Lcd_WriteData(0x0A);
        Lcd_WriteData(0x00);
        Lcd_WriteIndex(0xC3);
        Lcd_WriteData(0x8A);
        Lcd_WriteData(0x2A);
        Lcd_WriteIndex(0xC4);
        Lcd_WriteData(0xEE);
        Lcd_WriteIndex(0xC5); //VCOM
        Lcd_WriteData(0x0E);
        Lcd_WriteIndex(0x36); //MX, MY, RGB mode
        Lcd_WriteData(0xC8);
        //ST7735R Gamma Sequence
        Lcd_WriteIndex(0xe0);
        Lcd_WriteData(0x0f);
        Lcd_WriteData(0x1a);
        Lcd_WriteData(0x18);
        Lcd_WriteData(0x2f);
        Lcd_WriteData(0x28);
        Lcd_WriteData(0x20);
        Lcd_WriteData(0x22);
        Lcd_WriteData(0x1f);
        Lcd_WriteData(0x1b);
        Lcd_WriteData(0x23);
        Lcd_WriteData(0x37);
        Lcd_WriteData(0x10);
        Lcd_WriteIndex(0xe1);
        Lcd_WriteData(0x17);
        Lcd_WriteData(0x33);
        Lcd_WriteData(0x2c);
        Lcd_WriteData(0x29);
        Lcd_WriteData(0x2e);
        Lcd_WriteData(0x30);
        Lcd_WriteData(0x39);
        Lcd_WriteData(0x3f);
        Lcd_WriteData(0x03);
        Lcd_WriteIndex(0x2a);
        Lcd_WriteData(0x7f);
        Lcd_WriteIndex(0x2b);
        Lcd_WriteData(0x9f);
        Lcd_WriteIndex(0xF0); //Enable test command
        Lcd_WriteIndex(0xF6); //Disable ram power save mode
        Lcd_WriteIndex(0x3A); //65k mode
        Lcd_WriteData(0x05);
        Lcd_WriteIndex(0x29);//Display on
SPITEST.7z
5.82 MB, 下載次數(shù): 89, 下載積分: 黑幣 -5
STM32CubeMXTFTLCD
ID:739683 發(fā)表于 2020-5-1 13:44 | 只看該作者
有屏幕的型號嗎?
ID:388463 發(fā)表于 2020-6-27 18:51 | 只看該作者
很好的參考文檔啊,完美
