查看: 2964|回復(fù): 2
c51單片機(jī)數(shù)碼管顯示C語(yǔ)言程序問(wèn)題,for循環(huán)為顯示秒數(shù)的數(shù)組賦值
ID:453144 發(fā)表于 2019-10-14 20:46 | 只看該作者 |只看大圖 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
目前在用c51的數(shù)碼管做一個(gè)秒表,使用了一個(gè)for循環(huán)為顯示秒數(shù)的數(shù)組賦值,但不知道什么原因,效果沒(méi)有實(shí)現(xiàn),下面是程序源代碼。
  1. #include <reg52.h>
  2. #define uint unsigned int
  4. sbit LED = P0^0;
  5. sbit JA = P2^2;
  6. sbit JB = P2^3;
  7. sbit JC = P2^4;
  8. uchar code led[]={
  9. 0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,
  10. 0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
  11. uchar ledbuff[8]={0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF};
  12. uint cnt = 0;
  13. uint sec = 0;
  14. uchar i ;
  15. uchar x ;
  16. void delay(uint z);
  17. int main(void)
  18. {
  19. i=0;
  20.         TMOD = 0x01;   //0000 0001
  21.         TH0 = 0XFC;
  22.         TL0 = 0X18;
  23.         TR0 = 1;
  24.         EA = 1;
  25.         ET0 = 1;
  26.         while(1)
  27.         {if(cnt >=1000)
  28.                 {
  29.
  30.                           cnt=0;
  31.                           ledbuff[0]=led[sec%10];
  32.                                 for(x=1;x<=8;x++)
  33.                         {
  34.                                 ledbuff[x]=led[sec/(x*10)%10];
  35.                         }
  36. sec++;
  37.                 }
  38.
  39.
  40.         }
  41.
  42.
  43.         return 0;
  44. }
  45. void interrupttimer0() interrupt 1
  46. {
  47.         TH0 = 0XFC;
  48.         TL0 = 0X18;
  49.         P0 = 0XFF;
  50.         cnt++;    //cnt放在中斷中了
  51.         switch(i)
  52.         {
  53.                 case 0: JA=1;JB=1;JC=1;P0=ledbuff[i];i++;break;
  54.                 case 1: JA=1;JB=1;JC=0;P0=ledbuff[i];i++;break;
  55.                 case 2: JA=1;JB=0;JC=1;P0=ledbuff[i];i++;break;
  56.                 case 3: JA=1;JB=0;JC=0;P0=ledbuff[i];i++;break;
  57.                 case 4: JA=0;JB=1;JC=1;P0=ledbuff[i];i++;break;
  58.                 case 5: JA=0;JB=1;JC=0;P0=ledbuff[i];i++;break;
  59.                 case 6: JA=0;JB=0;JC=1;P0=ledbuff[i];i++;break;
  60.                 case 7: JA=0;JB=0;JC=0;P0=ledbuff[i];i=0;break;
  61.         }
  62.
  63. }
ID:332444 發(fā)表于 2019-10-15 08:32 | 只看該作者
ID:213173 發(fā)表于 2019-10-15 10:01 | 只看該作者
主要是數(shù)據(jù)分解代碼有問(wèn)題,uint sec = 0;數(shù)據(jù)范圍0~65536,其次138位碼也有問(wèn)題,給你改好了。
  4. //sbit LED = P0^0;
  5. sbit JA = P2^2;
  6. sbit JB = P2^3;
  7. sbit JC = P2^4;
  11. uchar ledbuff[8]={0x3f,0x3f,0x3f,0x3f,0x3f,0x3f,0x3f,0x3f};
  12. uint cnt = 0;
  13. uint sec = 0;
  14. uint y;
  15. uchar i;
  16. uchar x;
  17. int main(void)
  18. {
  19.         i=0;
  21.         TH0 = 0XFC;
  22.         TL0 = 0X18;
  23.         TR0 = 1;
  24.         EA = 1;
  25.         ET0 = 1;
  26.         while(1)
  27.         {
  28.                 if(cnt >=1000)
  29.                 {
  30.                         cnt=0;
  31.                         sec++;//大于65535=0
  32.                         y=sec;
  33.                         for(x=0;x<=5;x++)
  34.                         {
  35.                                 ledbuff[x]=led[y%10];
  36.                                 y/=10;
  37.                         }
  38.                 }
  39.         }
  40. }
  41. void interrupttimer0() interrupt 1
  42. {
  43.         TH0 = 0XFC;
  44.         TL0 = 0X18;
  45.         cnt++;    //cnt放在中斷中了
  46.         P0 = 0x00;//消隱
  47.         switch(i)
  48.         {
  49.                 case 0: JA=1;JB=1;JC=1;break;
  50.                 case 1: JA=0;JB=1;JC=1;break;
  51.                 case 2: JA=1;JB=0;JC=1;break;
  52.                 case 3: JA=0;JB=0;JC=1;break;
  53.                 case 4: JA=1;JB=1;JC=0;break;
  54.                 case 5: JA=0;JB=1;JC=0;break;
  55.                 case 6: JA=1;JB=0;JC=0;break;
  56.                 case 7: JA=0;JB=0;JC=0;break;
  57.         }
  58.         P0=ledbuff[i];
  59.         i++;
  60.         i%=8;
  61. }
