只需一步,快速開(kāi)始
查看: 2496|回復(fù): 0
stm8s單片機(jī) SPI驅(qū)動(dòng)一直卡住 調(diào)不出來(lái) 求助
ID:610433 發(fā)表于 2019-10-14 17:45 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
以下是我的AD7193 spi主機(jī)模式驅(qū)動(dòng)(stm8s)
一直停在RDY口,就是MISO復(fù)用,一直不拉低,死循環(huán)
我懷疑是spi讀寫(xiě)沒(méi)寫(xiě)好,還有就是spi硬件調(diào)試的時(shí)候,gpio口需要設(shè)置嘛?
求看一看,找出原因
#define MISO_STATE             GPIO_ReadInputPin(GPIOC, GPIO_PIN_7)
#define PMOD1_CS_LOW           GPIO_WriteLow(GPIOE, GPIO_PIN_5)
#define PMOD1_CS_HIGH          GPIO_WriteHigh(GPIOE, GPIO_PIN_5)
unsigned char SPI_Init7193(unsigned char lsbFirst, unsigned long clockFreq, unsigned char clockPol, unsigned char clockEdg)
  SPI_DeInit();
  SPI_Init(SPI_FIRSTBIT_MSB, SPI_BAUDRATEPRESCALER_16, SPI_MODE_MASTER, SPI_CLOCKPOLARITY_HIGH, SPI_CLOCKPHASE_1EDGE, SPI_DATADIRECTION_2LINES_FULLDUPLEX, SPI_NSS_SOFT, 0x07);
  SPI_Cmd(ENABLE);
  GPIO_Init(GPIOE, GPIO_PIN_5, GPIO_MODE_OUT_PP_LOW_FAST);     //SPI CS/NSS
  GPIO_WriteLow(GPIOE, GPIO_PIN_5);
  return 1;
unsigned char SPI_Write7193(unsigned char slaveDeviceId, unsigned char* data, unsigned char n)
   unsigned char byte = 0;
   unsigned char read = 0;
   for(byte = 0;byte < n;byte++)
     while(SPI_SR_TXE==0);
     SPI_SendData(data[byte]);
     while(SPI_SR_RXNE==0);
     read = SPI_ReceiveData();
   return n;
unsigned char SPI_Read7193(unsigned char slaveDeviceId, unsigned char* data, unsigned char n)
     data[byte] = SPI_ReceiveData();
   return n;
