查看: 5873|回復: 7
51單片機簡易密碼鎖PCB電路圖源程序(1602顯示)
  1. //包含頭文件
  2. #include <REG51.h>
  3. #include<intrins.h>
  4. //宏定義
  5. #define LCM_Data  P0                  //將P0口定義為LCM_Data
  6. #define uchar unsigned char
  7. #define uint  unsigned int
  8. //1602的控制腳
  9. sbit lcd1602_rs=P2^5;
  10. sbit lcd1602_rw=P2^6;
  11. sbit lcd1602_en=P2^7;
  12. sbit rs=  P2^5;
  13. sbit en = P2^7;
  14. sbit rw = P2^6;
  15. sbit busy=P0^7;//LCD1602顯示漢字的管腳
  16. sbit Scl=P3^4;                        //24C02串行時鐘
  17. sbit Sda=P3^5;                        //24C02串行數據
  18. sbit ALAM = P2^1;                //報警
  19. sbit KEY = P3^6;                //開鎖
  20. bit  pass=0;                        //密碼正確標志
  21. bit  ReInputEn=0;                //重置輸入允許標志
  22. bit  s3_keydown=0;                //3秒按鍵標志位
  23. bit  key_disable=0;                //鎖定鍵盤標志
  24. unsigned char countt0,second;        //t0中斷計數器,秒計數器
  25. void Delay5Ms(void);                //聲明延時函數
  26. unsigned char code a[]={0xFE,0xFD,0xFB,0xF7};                                 //控盤掃描控制表
  27. //液晶顯示數據數組
  28. unsigned char dui[] = {0x0,0x0,0x1A,0xA,0x1A,0x12,0x12,0x15}; //隊的字符表
  29. unsigned char dian[]={0x4,0x1F,0x15,0x1F,0x15,0x1F,0x4,0x7}; //大的字符表                                     //月的字符表
  30. unsigned char lan[] ={0xA,0x1B,0xA,0xC,0x1F,0x1A,0xE,0x1F}; //藍的字符表
  31. unsigned char da[] ={0x0,0x4,0x4,0x1F,0x4,0xA,0x11,0x0};//大的字符表
  32. unsigned char code start_line[]        = {"password:       "};
  33. unsigned char code name[]                  = {"==             =="};        //顯示名稱
  34. unsigned char code Correct[]         = {"     correct    "};                //輸入正確
  35. unsigned char code Error[]           = {"      error     "};          //輸入錯誤
  36. unsigned char code codepass[]        = {"      pass      "};
  37. unsigned char code LockOpen[]        = {"      open      "};                //OPEN
  38. unsigned char code SetNew[]         = {"SetNewWordEnable"};
  39. unsigned char code Input[]           = {"input:          "};                //INPUT
  40. unsigned char code ResetOK[]         = {"ResetPasswordOK "};
  41. unsigned char code initword[]        = {"Init password..."};
  42. unsigned char code Er_try[]                = {"error,try again!"};
  43. unsigned char code again[]                = {"input again     "};
  44. unsigned char InputData[6];        //輸入密碼暫存區
  45. unsigned char CurrentPassword[6]={0,0,0,0,0,0};                         //讀取EEPROM密碼暫存數組
  46. unsigned char TempPassword[6];
  47. unsigned char N=0;                                //密碼輸入位數記數
  48. unsigned char ErrorCont;                        //錯誤次數計數
  49. unsigned char CorrectCont;                        //正確輸入計數
  50. unsigned char ReInputCont;                         //重新輸入計數
  51. unsigned char code initpassword[6]={0,0,0,0,0,0};                        //輸入管理員密碼后將密碼初始為000000
  52. unsigned char code adminpassword[6]={2,0,1,9,0,1};                //輸入管理員密碼后將密碼初始為000000
  53. //*****************************************************************************
  54. //函數功能:LCD延時子程序
  55. //入口參數:ms
  56. //出口參數:
  57. //*****************************************************************************/
  58. void DelayUs2x(unsigned char t)
  59. {
  60. while(--t);
  61. }
  62. void DelayMs(unsigned char t)
  63. {
  64.
  65. while(t--)
  66. {
  67.      //大致延時1mS
  68.      DelayUs2x(245);
  69.          DelayUs2x(245);
  70. }
  71. }
  72. /*****************************************************************************
  73. 函數功能:測試LCD忙碌狀態
  74. 入口參數:
  75. 出口參數:busy_flag
  76. *****************************************************************************/
  77. bit lcd_check_busy()
  78. {
  79. P0=0Xff;
  80. rs = 0;
  81. rw = 1;
  82. en = 0;
  83. _nop_();
  84. en=1;
  85. return busy;
  86. }
  87. /*****************************************************************************
  88. 函數功能:寫指令數據到LCD子程序
  89. 入口參數:cmd
  90. 出口參數:
  91. *****************************************************************************/
  92. void lcd_wcmd(unsigned char cmd)
  93. {
  94. while(lcd_check_busy());    //判斷LCD是否忙碌
  95. rs = 0;
  96. rw = 0;
  97. en = 1;
  98. P0 = cmd;
  99. _nop_();
  100. en = 0;
  101. }
  102. /*****************************************************************************
  103. 函數功能:設定顯示位置子程序
  104. 入口參數:pos
  105. 出口參數:
  106. *****************************************************************************/
  107. void lcd_pos(unsigned char pos)
  108. {
  109. lcd_wcmd(pos | 0x80);
  110. }
  111. /*****************************************************************************
  112. 函數功能:寫入顯示數據到LCD子程序
  113. 入口參數:dat
  114. 出口參數:
  115. *****************************************************************************/
  116. void lcd_wdat(unsigned char dat)
  117. {
  118. while(lcd_check_busy()); //判斷LCD是否忙碌
  119. rs = 1;
  120. rw = 0;
  121. en = 1;
  122. P0 = dat;
  123. _nop_();
  124. en = 0;
  125. }
  126. /*****************************************************************************
  127. 函數功能:LCD初始化子程序
  128. 入口參數:
  129. 出口參數:
  130. *****************************************************************************/
  131. void lcd_init1()
  132. {
  133. lcd_wcmd(0x38);
  134. DelayMs(5);
  135. lcd_wcmd(0x38);
  136. DelayMs(5);
  137. lcd_wcmd(0x38);
  138. DelayMs(5);
  139. lcd_wcmd(0x38);    //8位數據,雙行顯示,5*7點陣
  140. lcd_wcmd(0x08);    //顯示關閉,無光標,光標不顯示
  141. lcd_wcmd(0x01);    //清顯示
  142. lcd_wcmd(0x06);    //光標右移
  143. DelayMs(5);
  144. lcd_wcmd(0x0c);    //開顯示,有光標,光標閃爍
  145. }
  146. /****************************************************************************
  147. 函數功能:建立藍電大隊字符
  148. 入口參數:
  149. 出口參數:
  150. *****************************************************************************/
  151. void lcd_setups()
  152. {unsigned int i;
  153. lcd_wcmd(0x40);
  154. for(i=0;i<8;i++)
  155. {
  156.         lcd_wdat(lan[i]);
  157. }
  158. lcd_wcmd(0x48);
  159. for(i=0;i<8;i++)
  160. {lcd_wdat(dian[i]);
  161. }
  162. lcd_wcmd(0x50);
  163. for(i=0;i<8;i++)
  164. {lcd_wdat(da[i]);
  165. }
  166. lcd_wcmd(0x58);
  167. for(i=0;i<8;i++)
  168. {lcd_wdat(dui[i]);
  169. }
  170. }
  171. //LCD1602顯示漢字子程序
  172. //=====================5ms延時==============================
  173. void Delay5Ms(void)
  174. {
  175.         unsigned int TempCyc = 5552;
  176.         while(TempCyc--);
  177. }
  178. //===================400ms延時==============================
  179. void Delay400Ms(void)
  180. {
  181. unsigned char TempCycA = 5;
  182. unsigned int TempCycB;
  183. while(TempCycA--)
  184. {
  185.   TempCycB=7269;
  186.   while(TempCycB--);
  187. }
  188. }
  189. //=============================================================================================
  190. //================================24C02========================================================
  191. //=============================================================================================
  192. void mDelay(uint t) //延時
  193. {
  194.         uchar i;
  195.            while(t--)
  196.            {
  197.                    for(i=0;i<125;i++)
  198.                    {;}
  199.            }
  200. }
  201.
  202. void Nop(void)                  //空操作
  203. {
  204.         _nop_();                  //僅作延時用一條語句大約1us
  205.         _nop_();
  206.         _nop_();
  207.         _nop_();
  208. }
  209. /*****24c02程序參照24c02時序圖*****/
  210. /*起始條件*/
  211. void Start(void)
  212. {
  213.         Sda=1;
  214.         Scl=1;
  215.         Nop();
  216.         Sda=0;
  217.         Nop();
  218. }
  219. /*停止條件*/
  220. void Stop(void)
  221. {
  222.         Sda=0;
  223.         Scl=1;
  224.         Nop();
  225.         Sda=1;
  226.         Nop();
  227. }
  228. /*應答位*/
  229. void Ack(void)
  230. {
  231.         Sda=0;
  232.         Nop();
  233.         Scl=1;
  234.         Nop();
  235.         Scl=0;
  236. }
  237. /*反向應答位*/
  238. void NoAck(void)
  239. {
  240.         Sda=1;
  241.         Nop();
  242.         Scl=1;
  243.         Nop();
  244.         Scl=0;
  245. }
  246. /*發送數據子程序,Data為要求發送的數據*/
  247. void Send(uchar Data)
  248. {
  249.            uchar BitCounter=8;
  250.            uchar temp;
  251.            do
  252.            {
  253.                    temp=Data;                                           //將待發送數據暫存temp
  254.                    Scl=0;
  255.                    Nop();
  256.                    if((temp&0x80)==0x80)                   //將讀到的數據&0x80
  257.                    Sda=1;
  258.                    else
  259.                    Sda=0;
  260.                    Scl=1;
  261.                    temp=Data<<1;                                   //數據左移
  262.                    Data=temp;                                           //數據左移后重新賦值Data
  263.                    BitCounter--;                                   //該變量減到0時,數據也就傳送完成了
  264.            }
  265.            while(BitCounter);                                   //判斷是否傳送完成
  266.            Scl=0;
  267. }
  268. /*讀一字節的數據,并返回該字節值*/
  269. uchar Read(void)
  270. {
  271.     uchar temp=0;
  272.         uchar temp1=0;
  273.         uchar BitCounter=8;
  274.         Sda=1;
  275.         do
  276.         {
  277.                 Scl=0;
  278.                 Nop();
  279.                 Scl=1;
  280.                 Nop();
  281.                 if(Sda)                                   //數據位是否為1
  282.                         temp=temp|0x01;           //為1 temp的最低位為1(|0x01,就是將最低位變為1)
  283.                 else                                   //如果為0
  284.                         temp=temp&0xfe;           //temp最低位為0(&0xfe(11111110)最低位就是0)
  285.                 if(BitCounter-1)           //BitCounter減1后是否為真
  286.                 {
  287.                         temp1=temp<<1;           //temp左移
  288.                         temp=temp1;
  289.                 }
  290.                 BitCounter--;                   //BitCounter減到0時,數據就接收完了
  291.         }
  292.         while(BitCounter);                   //判斷是否接收完成
  293.         return(temp);
  294. }
  295. void WrToROM(uchar Data[],uchar Address,uchar Num)
  296. {
  297.   uchar i;
  298.   uchar *PData;
  299.   PData=Data;
  300.   for(i=0;i<Num;i++)
  301.   {
  302.   Start();
  303.   Send(0xa0);
  304.   Ack();
  305.   Send(Address+i);
  306.   Ack();
  307.   Send(*(PData+i));
  308.   Ack();
  309.   Stop();
  310.   mDelay(20);
  311.   }
  312. }
  313. void RdFromROM(uchar Data[],uchar Address,uchar Num)
  314. {
  315.   uchar i;
  316.   uchar *PData;
  317.   PData=Data;
  318.   for(i=0;i<Num;i++)
  319.   {
  320.   Start();
  321.   Send(0xa0);
  322.   Ack();
  323.   Send(Address+i);
  324.   Ack();
  325.   Start();
  326.   Send(0xa1);
  327.   Ack();
  328.   *(PData+i)=Read();
  329.   Scl=0;
  330.   NoAck();
  331.   Stop();
  332.   }
  333. }
  334. //==================================================================================================
  335. //=======================================LCD1602====================================================
  336. //==================================================================================================
  337. #define yi 0x80 //LCD第一行的初始位置,因為LCD1602字符地址首位D7恒定為1(100000000=80)
  338. #define er 0x80+0x40 //LCD第二行初始位置(因為第二行第一個字符位置地址是0x40)
  339. //----------------延時函數,后面經常調用----------------------
  340. void delay(uint xms)//延時函數,有參函數
  341. {
  342.         uint x,y;
  343.         for(x=xms;x>0;x--)
  344.          for(y=110;y>0;y--);
  345. }
  346. //--------------------------寫指令---------------------------
  347. void write_1602com(uchar com)//****液晶寫入指令函數****
  348. {
  349.         lcd1602_rs=0;//數據/指令選擇置為指令
  350.         lcd1602_rw=0; //讀寫選擇置為寫
  351.         P0=com;//送入數據
  352.         delay(1);
  353.         lcd1602_en=1;//拉高使能端,為制造有效的下降沿做準備
  354.         delay(1);
  355.         lcd1602_en=0;//en由高變低,產生下降沿,液晶執行命令
  356. }
  357. //-------------------------寫數據-----------------------------
  358. void write_1602dat(uchar dat)//***液晶寫入數據函數****
  359. {
  360.         lcd1602_rs=1;//數據/指令選擇置為數據
  361.         lcd1602_rw=0; //讀寫選擇置為寫
  362.         P0=dat;//送入數據
  363.         delay(1);
  364.         lcd1602_en=1; //en置高電平,為制造下降沿做準備
  365.         delay(1);
  366.         lcd1602_en=0; //en由高變低,產生下降沿,液晶執行命令
  367. }
  368. //-------------------------初始化-------------------------
  369. void lcd_init(void)
  370. {
  371.         write_1602com(0x38);//設置液晶工作模式,意思:16*2行顯示,5*7點陣,8位數據
  372.         write_1602com(0x0c);//開顯示不顯示光標
  373.         write_1602com(0x06);//整屏不移動,光標自動右移
  374.         write_1602com(0x01);//清顯示
  375. }
  376. //========================================================================================
  377. //=========================================================================================
  378. //==============將按鍵值編碼為數值=========================
  379. unsigned char coding(unsigned char m)
  380. {
  381.         unsigned char k;
  382.         switch(m)
  383.         {
  384.                 case (0x11): k=1;break;
  385.                 case (0x21): k=2;break;
  386.                 case (0x41): k=3;break;
  387.                 case (0x81): k='A';break;
  388.                 case (0x12): k=4;break;
  389.                 case (0x22): k=5;break;
  390.                 case (0x42): k=6;break;
  391.                 case (0x82): k='B';break;
  392.                 case (0x14): k=7;break;
  393.                 case (0x24): k=8;break;
  394.                 case (0x44): k=9;break;
  395.                 case (0x84): k='C';break;
  396.                 case (0x18): k='*';break;
  397.                 case (0x28): k=0;break;
  398.                 case (0x48): k='#';break;
  399.                 case (0x88): k='D';break;
  400.         }
  401.         return(k);
  402. }
  403. //=====================按鍵檢測并返回按鍵值===============================
  404. unsigned char keynum(void)
  405. {
  406.         unsigned char row,col,i;
  407.         P1=0xf0;
  408.         if((P1&0xf0)!=0xf0)
  409.         {
  410.                    Delay5Ms();
  411.         Delay5Ms();
  412.                    if((P1&0xf0)!=0xf0)
  413.                 {
  414.                     row=P1^0xf0;          //確定行線
  415.                         i=0;
  416.                         P1=a[i];                  //精確定位
  417.                         while(i<4)
  418.                         {
  419.                                  if((P1&0xf0)!=0xf0)
  420.                                   {
  421.                                            col=~(P1&0xff);          //確定列線
  422.                                            break;            //已定位后提前退出
  423.                                   }
  424.                                 else
  425.                                   {
  426.                                            i++;
  427.                                            P1=a[i];
  428.                                   }
  429.                         }
  430.                 }
  431.                 else
  432.                 {
  433.                         return 0;
  434.                 }
  435.                 while((P1&0xf0)!=0xf0);
  436.                 return (row|col);                         //行線與列線組合后返回
  437.         }
  438.         else return 0;                                 //無鍵按下時返回0
  439. }
  440. //=======================一聲提示音,表示有效輸入========================
  441. void OneAlam(void)
  442. {
  443.         ALAM=0;
  444.         Delay5Ms();
  445.     ALAM=1;
  446. }
  447. //========================二聲提示音,表示操作成功========================
  448. void TwoAlam(void)
  449. {
  450.         ALAM=0;
  451.         Delay5Ms();
  452.     ALAM=1;
  453.     Delay5Ms();
  454.         ALAM=0;
  455.         Delay5Ms();
  456.     ALAM=1;
  457. }
  458. //========================三聲提示音,表示錯誤========================
  459. void ThreeAlam(void)
  460. {
  461.         ALAM=0;
  462.         Delay5Ms();
  463.     ALAM=1;
  464.     Delay5Ms();
  465.         ALAM=0;
  466.         Delay5Ms();
  467.     ALAM=1;
  468.     Delay5Ms();
  469.         ALAM=0;
  470.         Delay5Ms();
  471.     ALAM=1;
  472. }
  473. //=======================顯示提示輸入=========================
  474. void DisplayChar(void)
  475. {
  476.         unsigned char i;
  477.         if(pass==1)
  478.         {
  479.                 //DisplayListChar(0,1,LockOpen);
  480.                 write_1602com(er);                                   //在二行開始顯示
  481.                 for(i=0;i<16;i++)
  482.                 {
  483.                         write_1602dat(LockOpen[i]);           //顯示open 開鎖成功
  484.                 }
  485.         }
  486.         else
  487.         {
  488.                 if(N==0)
  489.                 {
  490.                         //DisplayListChar(0,1,Error);
  491.                         write_1602com(er);
  492.                         for(i=0;i<16;i++)
  493.                         {
  494.                                 write_1602dat(Error[i]);        //顯示錯誤
  495.                         }
  496.                 }
  497.                 else
  498.                 {
  499.                         //DisplayListChar(0,1,start_line);
  500.                         write_1602com(er);
  501.                         for(i=0;i<16;i++)
  502.                         {
  503.                                 write_1602dat(start_line[i]);//顯示開始輸入
  504.                         }
  505.                 }
  506.         }
  507. }
  508. //========================重置密碼==================================================
  509. //==================================================================================
  510. void ResetPassword(void)
  511. {
  512.         unsigned char i;
  513.         unsigned char j;
  514.         if(pass==0)
  515.         {
  516.                 pass=0;
  517.                 DisplayChar();           //顯示錯誤
  518.                 ThreeAlam();           //沒開鎖時按下重置密碼報警3聲
  519.         }
  520.         else                                   //開鎖狀態下才能進行密碼重置程序
  521.         {
  522.             if(ReInputEn==1)   //開鎖狀態下,ReInputEn置1,重置密碼允許
  523.                 {
  524.                         if(N==6)           //輸入6位密碼
  525.                         {
  526.                                 ReInputCont++;                        //密碼次數計數
  527.                                 if(ReInputCont==2)                //輸入兩次密碼
  528.                                 {
  529.                                         for(i=0;i<6;)
  530.                                         {
  531.                                                 if(TempPassword[i]==InputData[i])        //將兩次輸入的新密碼作對比
  532.                                                         i++;
  533.                                                 else        //如果兩次的密碼不同
  534.                                                 {
  535.                                                         //DisplayListChar(0,1,Error);
  536.                                                         write_1602com(er);
  537.                                                         for(j=0;j<16;j++)
  538.                                                         {
  539.        write_1602dat(Error[j]);        //顯示錯誤Error
  540.                                                         }
  541.                                                         ThreeAlam();                        //錯誤提示
  542.                                                         pass=0;                                        //關鎖
  543.                                                         ReInputEn=0;                        //關閉重置功能,
  544.                                                         ReInputCont=0;
  545.                                                         DisplayChar();
  546.                                                         break;
  547.                                                 }
  548.                                         }
  549.                                         if(i==6)
  550.                                         {
  551.                                                 //DisplayListChar(0,1,ResetOK);
  552.                                                 write_1602com(er);
  553.                                                 for(j=0;j<16;j++)
  554.                                                 {
  555.                                                         write_1602dat(ResetOK[j]);          //密碼修改成功,顯示
  556.                                                 }
  557.                                                 TwoAlam();                                //操作成功提示
  558.                                                  WrToROM(TempPassword,0,6);                //將新密碼寫入24C02存儲
  559.                                                 ReInputEn=0;
  560.                                         }
  561.                                         ReInputCont=0;
  562.                                         CorrectCont=0;
  563.                                 }
  564.                                 else                                          //輸入一次密碼時
  565.                                 {
  566.                                         OneAlam();
  567.                                         //DisplayListChar(0, 1, again);                 //顯示再次輸入一次
  568.                                         write_1602com(er);
  569.                                         for(j=0;j<16;j++)
  570.                                         {
  571.                                                 write_1602dat(again[j]);                        //顯示再輸入一次
  572.                                         }
  573.                                         for(i=0;i<6;i++)
  574.                                         {
  575.                                                 TempPassword[i]=InputData[i];                //將第一次輸入的數據暫存起來
  576.                                         }
  577.                                 }
  578.                         N=0;                                                //輸入數據位數計數器清零
  579.                    }
  580.             }
  581.         }
  582. }
  583. //=======================輸入密碼錯誤超過三過,報警并鎖死鍵盤======================
  584. void Alam_KeyUnable(void)
  585. {
  586.         P1=0x00;
  587.         {
  588.                 ALAM=~ALAM;                                 //蜂鳴器一直閃爍鳴響
  589.                 Delay5Ms();
  590.         }
  591. }
  592. //=======================取消所有操作============================================
  593. void Cancel(void)
  594. {
  595.         unsigned char i;
  596.         unsigned char j;
  597.         //DisplayListChar(0, 1, start_line);
  598.         write_1602com(er);
  599.         for(j=0;j<16;j++)
  600.         {
  601.                 write_1602dat(start_line[j]);          //顯示開機輸入密碼界面
  602.         }
  603.         TwoAlam();                                //提示音
  604.         for(i=0;i<6;i++)
  605.         {
  606.                 InputData[i]=0;                //將輸入密碼清零
  607.         }
  608.         KEY=1;                                        //關閉鎖
  609.         ALAM=1;                                        //報警關
  610.         pass=0;                                        //密碼正確標志清零
  611.         ReInputEn=0;                        //重置輸入充許標志清零
  612.         ErrorCont=0;                        //密碼錯誤輸入次數清零
  613.         CorrectCont=0;                        //密碼正確輸入次數清零
  614.         ReInputCont=0;                        //重置密碼輸入次數清零
  615.         s3_keydown=0;
  616.         key_disable=0;                        //鎖定鍵盤標志清零
  617.         N=0;                                        //輸入位數計數器清零
  618. }
  619. //==========================確認鍵,并通過相應標志位執行相應功能===============================
  620. void Ensure(void)
  621. {
  622.         unsigned char i,j;
  623.         RdFromROM(CurrentPassword,0,6);                                         //從24C02里讀出存儲密碼
  624.     if(N==6)
  625.         {
  626.             if(ReInputEn==0)                                                        //重置密碼功能未開啟
  627.                 {
  628.                         for(i=0;i<6;)
  629.                            {
  630.                                 if(CurrentPassword[i]==InputData[i])        //判斷輸入密碼和24c02中的密碼是否相同
  631.                                 {
  632.                                         i++;        //相同一位 i就+1
  633.                                 }
  634.                                 else        //如果有密碼不同
  635.                                 {
  636.                                         ErrorCont++;                                                //錯誤次數++
  637.                                         if(ErrorCont==3)                        //錯誤輸入計數達三次時,報警并鎖定鍵盤
  638.                                         {
  639.                                                 write_1602com(er);
  640.                                                 for(i=0;i<16;i++)
  641.                                                 {
  642.                                                         write_1602dat(Error[i]);
  643.                                                 }
  644.                                                 do
  645.                                                 Alam_KeyUnable();
  646.                                                 while(1);
  647.                                         }
  648.                                         else                                         //錯誤次數小于3次時,鎖死鍵盤3秒,然后重新可以輸入
  649.                                         {
  650.                                                 TR0=1;                                //開啟定時
  651.                                                 key_disable=1;                        //鎖定鍵盤
  652.                                                 pass=0;                                        //pass位清零
  653.                                                 break;                                        //跳出
  654.                                         }
  655.                                 }
  656.                         }
  657.                         if(i==6)                                         //密碼輸入對時
  658.                         {
  659.                                 if((InputData[0]==adminpassword[0])&&(InputData[1]==adminpassword[1])&&(InputData[2]==adminpassword[2])&&(InputData[3]==adminpassword[3])&&(InputData[4]==adminpassword[4])&&(InputData[5]==adminpassword[5]))
  660.                                    {
  661.                                         WrToROM(initpassword,0,6);                                 //強制將初始密碼寫入24C02存儲
  662.                                         write_1602com(er);
  663.                                         for(j=0;j<16;j++)
  664.                                         {
  665.                                                 write_1602dat(initword[j]);                                //顯示初始化密碼
  666.                                         }
  667.                                         TwoAlam();        //成功提示音
  668.                                         Delay400Ms();        //延時400ms
  669.                                         TwoAlam();        //成功提示音
  670.                                         N=0;        //輸入位數計數器清零
  671.                                 }
  672.                                 else
  673.                                 {
  674.                                         CorrectCont++;                                        //輸入正確變量++
  675.                                         if(CorrectCont==1)                                //正確輸入計數,當只有一次正確輸入時,開鎖
  676.                                         {
  677.                                                 //DisplayListChar(0,1,LockOpen);
  678.                                                 write_1602com(er);
  679.                                                 for(j=0;j<16;j++)
  680.                                                 {
  681.                                                         write_1602dat(LockOpen[j]);                  //顯示open開鎖畫面
  682.                                                 }
  683.                                                 TwoAlam();                        //操作成功提示音
  684.                                                 KEY=0;        //開鎖
  685.                                                 pass=1;        //置正確標志位
  686.                                                 TR0=1;        //開啟定時
  687.                                                 for(j=0;j<6;j++)        //將輸入清除
  688.                                                 {
  689.                                                         InputData[i]=0;        //開鎖后將輸入位清零
  690.                                                 }
  691.                                         }
  692.                                         else        //當兩次正確輸入時,開啟重置密碼功能
  693.                                         {
  694.                                                 write_1602com(er);
  695.                                                 for(j=0;j<16;j++)
  696.                                                 {
  697.                                                         write_1602dat(SetNew[j]);                                        //顯示重置密碼界面
  698.                                                 }
  699.                                                 TwoAlam();        //操作成功提示
  700.                                                 ReInputEn=1;        //允許重置密碼輸入
  701.                                                 CorrectCont=0;        //正確計數器清零
  702.                                         }
  703.                                 }
  704.                           }
  705.
  706.                         else                        //=========================當第一次使用或忘記密碼時可以用131420對其密碼初始化============
  707.                         {
  708.                                 if((InputData[0]==adminpassword[0])&&(InputData[1]==adminpassword[1])&&(InputData[2]==adminpassword[2])&&(InputData[3]==adminpassword[3])&&(InputData[4]==adminpassword[4])&&(InputData[5]==adminpassword[5]))
  709.                                    {
  710.                                         WrToROM(initpassword,0,6);                                 //強制將初始密碼寫入24C02存儲
  711.                                         write_1602com(er);
  712.                                         for(j=0;j<16;j++)
  713.                                         {
  714.                                                 write_1602dat(initword[j]);                                //顯示初始化密碼
  715.                                         }
  716.                                         TwoAlam();        //成功提示音
  717.                                         Delay400Ms();        //延時400ms
  718.                                         TwoAlam();        //成功提示音
  719.                                         N=0;        //輸入位數計數器清零
  720.                                 }
  721.                                 else        //密碼輸入錯誤
  722.                                 {
  723.                                         write_1602com(er);
  724.                                         for(j=0;j<16;j++)
  725.                                         {
  726.                                                 write_1602dat(Error[j]);                                 //顯示錯誤信息
  727.                                         }
  728.                                         ThreeAlam();        //錯誤提示音
  729.                                         pass=0;
  730.                                 }
  731.                         }
  732.                 }
  733.                 else        //當已經開啟重置密碼功能時,而按下開鎖鍵,
  734.                 {
  735.                         //DisplayListChar(0,1,Er_try);
  736.                         write_1602com(er);
  737.                         for(j=0;j<16;j++)
  738.                         {
  739.                                 write_1602dat(Er_try[j]);                          //錯誤,請重新輸入
  740.                         }
  741.                         ThreeAlam();                                                          //錯誤提示音
  742.                 }
  743.         }
  744.         else                                   //密碼沒有輸入到6位時,按下確認鍵時
  745.         {
  746.                 //DisplayListChar(0,1,Error);
  747.                 write_1602com(er);
  748.                 for(j=0;j<16;j++)
  749.                 {
  750.                         write_1602dat(Error[j]);                 //顯示錯誤
  751.                 }
  752.                 ThreeAlam();        //錯誤提示音
  753.                 pass=0;
  754.         }
  755.
  756.         N=0;        //將輸入數據計數器清零,為下一次輸入作準備
  757. }
  758. //==============================主函數===============================
  759. void main(void)
  760. {
  761.         unsigned char KEY,NUM;
  762.         unsigned char i,j;
  763.         P1=0xFF;                                    //P1口復位
  764.         TMOD=0x11;                                   //定義工作方式
  765.         TL0=0xB0;
  766.         TH0=0x3C;                                   //定時器賦初值
  767.         EA=1;                                           //打開中斷總開關
  768.         ET0=1;                                           //打開中斷允許開關
  769.         TR0=0;                                           //打開定時器開關
  770.         Delay400Ms();         //啟動等待,等LCM講入工作狀態
  771.         lcd_init();         //LCD初始化
  772.
  773.         write_1602com(yi);//日歷顯示固定符號從第一行第0個位置之后開始顯示
  774.
  775.                 lcd_setups();              //建立字符
  776.                 for(i=0;i<16;i++)
  777.         {
  778.                 write_1602dat(name[i]);//向液晶屏寫開機畫面
  779.         }
  780.         write_1602com(er);
  781.         for(i=0;i<16;i++)
  782.         {
  783.                 write_1602dat(start_line[i]);//寫輸入密碼等待界面
  784.         }
  785.         write_1602com(er+9);        //設置光標位置
  786.         write_1602com(0x0f);        //設置光標為閃爍
  787.         Delay5Ms(); //延時片刻(可不要)
  788.         N=0;                        //初始化數據輸入位數
  789.
  790.                 lcd_pos(0x04);   //起始列位置          //顯示藍
  791. lcd_wdat(0x00);
  792. lcd_pos(0x06);//終止列位置
  793. lcd_pos(0x06);             //顯示電
  794. lcd_wdat(0x01);
  795. lcd_pos(0x08);
  796. lcd_pos(0x08);            //顯示大
  797. lcd_wdat(0x02);
  798. lcd_pos(0x010);
  799.
  800. lcd_pos(0x0a);            //顯示隊
  801. lcd_wdat(0x03);
  802. lcd_pos(0x0b);
  803.         while(1)                 //進入循環
  804.         {
  805.                 if(key_disable==1)                                                //鎖定鍵盤標志為1時
  806.                         Alam_KeyUnable();                                        //報警鍵盤鎖
  807.                 else
  808.                         ALAM=1;        //關報警
  809.                 KEY=keynum();                                                        //讀按鍵的位置碼
  810.                 if(KEY!=0)        //當有按鍵按下時
  811.                 {
  812.                         if(key_disable==1)                                        //鎖定鍵盤標志為1時
  813.                         {
  814.                                 second=0;                                                //秒清零
  815.                         }
  816.                         else        //沒有鎖定鍵盤時
  817.                         {
  818.                                 NUM=coding(KEY);                                //根據按鍵的位置將其編碼,編碼值賦值給NUM
  819.                                 {
  820.                                         switch(NUM)                                        //判斷按鍵值
  821.                                         {
  822.                                                 case ('A'):         ;                                         break;
  823.                                                 case ('B'):                ;                                     break;
  824.                                                 case ('C'):
  825.        write_1602com(yi);//日歷顯示固定符號從第一行第0個位置之后開始顯示
  826.        for(i=0;i<16;i++)
  827.        {
  828.        write_1602dat(name[i]);//向液晶屏寫開機畫面
  829.        }
  830.        if(N>=1) N--;        OneAlam();        //按鍵提示音
  831.        //DisplayOneChar(6+N,1,'*');
  832.        for(j=N;j<16;j++)
  833.        {
  834.        write_1602com(er+6+j);
  835.        write_1602dat(' ');
  836.        }
  837.        for(j=0;j<N;j++)
  838.        {
  839.        write_1602com(er+6+j);                                //顯示位數隨輸入增加而增加
  840.        write_1602dat('*');                                        //但不顯示實際數字,用*代替
  841.        }
  842.        InputData[N]=N+4;
  843.        break;                //ABC是無定義按鍵
  844.                                                 case ('D'): ResetPassword();                break;      //重新設置密碼
  845.                                                 case ('*'): Cancel();                                break;      //取消當前輸入
  846.                                                 case ('#'): Ensure();                                 break;           //確認鍵,
  847.                                                 default:        //如果不是功能鍵按下時,就是數字鍵按下
  848.                                                 {
  849.                                                         //DisplayListChar(0,1,Input);
  850.                                                         if(N<6)                                                           //當輸入的密碼少于6位時,接受輸入并保存,大于6位時則無效。
  851.                                                         {
  852.        write_1602com(er);
  853.        for(i=0;i<16;i++)
  854.        {
  855.        write_1602dat(Input[i]);                                //顯示輸入畫面
  856.        }
  857.        OneAlam();        //按鍵提示音
  858.        for(j=0;j<=N;j++)
  859.        {
  860.        write_1602com(er+6+j);                                //顯示位數隨輸入增加而增加
  861.        write_1602dat('*');                                        //但不顯示實際數字,用*代替
  862.        }
  863.        InputData[N]=NUM;                                                //將數字鍵的碼賦值給InputData[]數組暫存
  864.        N++;        //密碼位數加
  865.                                                         }
  866.                                                         else        //輸入數據位數大于6后,忽略輸入
  867.                                                         {
  868.        N=6;        //密碼輸入大于6位時,不接受輸入
  869.        break;
  870.                                                         }
  871.                                                 }
  872.                                         }
  873.                                 }
  874.                         }
  875.                  }
  876.         }
  877. }
  878. //*********************************中斷服務函數**************************************
  879. void  time0_int(void) interrupt 1                    //定時器T0
  880. {
  881.         TL0=0xB0;
  882.         TH0=0x3C;                  //定時器重新賦初值
  883.         //TR0=1;
  884.         countt0++;                           //計時變量加,加1次時50ms
  885.           if(countt0==20)                   //加到20次就是1s
  886.            {
  887.                 countt0=0;                   //變量清零
  888.                 second++;                   //秒加
  889.                 if(pass==1)                   //開鎖狀態時
  890.                 {
  891.                         if(second==1)                        //秒加到1s時
  892.                         {
  893.                                 TR0=0;                                //關定時器
  894.                                 TL0=0xB0;
  895.                                 TH0=0x3C;                        //再次賦初值
  896.                                 second=0;                        //秒清零
  897.                         }
  898.                 }
  899.                 else                                                //不在開鎖狀態時
  900.                 {
  901.                         if(second==3)                        //秒加到3時
  902.                         {
  903.                                 TR0=0;                                //關閉定時器
  904.                                 second=0;                        //秒清零
  905.                                 key_disable=0;                //鎖定鍵盤清零
  906.                                 s3_keydown=0;
  907.                                 TL0=0xB0;
  908.                                 TH0=0x3C;                        //重新賦初值
  909.                         }
  910.                         else
  911.                             TR0=1;                                //打開定時器
  912.                 }
  913.
  914.            }
  915. }
11-視頻講解.rar (9.03 MB, 下載次數: 71)
密碼鎖2.rar (66.48 KB, 下載次數: 104)
密碼鎖硬件圖.7z (2.07 MB, 下載次數: 100)
收藏收藏10 分享淘帖 頂2 踩
ID:599674 發表于 2019-10-25 21:09 | 只看該作者
感謝分享
ID:628333 發表于 2019-10-28 15:00 | 只看該作者
為什么我下來用不了
ID:393768 發表于 2019-10-31 23:54 | 只看該作者
請問LCD1602 只能顯示d第一行的白方快是咋回事
ID:253767 發表于 2019-11-1 07:53 | 只看該作者
謝謝分享!!!
ID:634141 發表于 2019-11-1 23:08 | 只看該作者
不錯,學習中
ID:679122 發表于 2020-1-3 23:50 | 只看該作者
收藏一波
ID:795477 發表于 2020-7-2 11:18 | 只看該作者
有人知道這是幾位密碼嗎
