單片機(jī)源程序如下:
- #include <reg52.h>
- #include <intrins.h>
- #define uchar unsigned char // 以后unsigned char就可以用uchar代替
- #define uint unsigned int // 以后unsigned int 就可以用uint 代替
- sfr ISP_DATA = 0xe2; // 數(shù)據(jù)寄存器
- sfr ISP_ADDRH = 0xe3; // 地址寄存器高八位
- sfr ISP_ADDRL = 0xe4; // 地址寄存器低八位
- sfr ISP_CMD = 0xe5; // 命令寄存器
- sfr ISP_TRIG = 0xe6; // 命令觸發(fā)寄存器
- sfr ISP_CONTR = 0xe7; // 命令寄存器
- sbit LcdRs_P = P2^7; // 1602液晶的RS管腳
- sbit LcdRw_P = P2^6; // 1602液晶的RW管腳
- sbit LcdEn_P = P2^5; // 1602液晶的EN管腳
- sbit Trig_P = P2^2; // 超聲波模塊的Trig管腳
- sbit Echo_P = P2^3; // 超聲波模塊的Echo管腳
- sbit KeySet_P = P3^2; // “設(shè)置”按鍵的管腳
- sbit KeyDown_P = P3^3; // “減”按鍵的管腳
- sbit KeyUp_P = P3^4; // “加”按鍵的管腳
- sbit Buzzer_P = P2^1; // 蜂鳴器的管腳
- sbit Led_P = P2^0; // LED報(bào)警燈的管腳
- uint gAlarm; // 報(bào)警距離變量
- // 單片機(jī)內(nèi)部EEPROM不使能
- void ISP_Disable()
- ISP_CONTR = 0;
- ISP_ADDRH = 0;
- ISP_ADDRL = 0;
- // 從單片機(jī)內(nèi)部EEPROM讀一個字節(jié),從0x2000地址開始
- unsigned char EEPROM_Read(unsigned int add)
- ISP_DATA = 0x00;
- ISP_CONTR = 0x83;
- ISP_CMD = 0x01;
- ISP_ADDRH = (unsigned char)(add>>8);
- ISP_ADDRL = (unsigned char)(add&0xff);
- // 對STC89C51系列來說,每次要寫入0x46,再寫入0xB9,ISP/IAP才會生效
- ISP_TRIG = 0x46;
- ISP_TRIG = 0xB9;
- _nop_();
- ISP_Disable();
- return (ISP_DATA);
- // 往單片機(jī)內(nèi)部EEPROM寫一個字節(jié),從0x2000地址開始
- void EEPROM_Write(unsigned int add,unsigned char ch)
- ISP_CONTR = 0x83;
- ISP_CMD = 0x02;
- ISP_DATA = ch;
- ISP_TRIG = 0x46;
- ISP_TRIG = 0xB9;
- _nop_();
- ISP_Disable();
- // 擦除單片機(jī)內(nèi)部EEPROM的一個扇區(qū)
- // 寫8個扇區(qū)中隨便一個的地址,便擦除該扇區(qū),寫入前要先擦除
- void Sector_Erase(unsigned int add)
- ISP_CONTR = 0x83;
- ISP_CMD = 0x03;
- ISP_TRIG = 0x46;
- ISP_TRIG = 0xB9;
- _nop_();
- ISP_Disable();
- // 毫秒級的延時函數(shù),time是要延時的毫秒數(shù)
- void DelayMs(uint time)
- uint i,j;
- for(i=0;i<time;i++)
- for(j=0;j<112;j++);
- // 1602液晶寫命令函數(shù),cmd就是要寫入的命令
- void LcdWriteCmd(uchar cmd)
- LcdRs_P = 0;
- LcdRw_P = 0;
- LcdEn_P = 0;
- P0=cmd;
- DelayMs(2);
- LcdEn_P = 1;
- DelayMs(2);
- LcdEn_P = 0;
- // 1602液晶寫數(shù)據(jù)函數(shù),dat就是要寫入的數(shù)據(jù)
- void LcdWriteData(uchar dat)
- LcdRs_P = 1;
- LcdRw_P = 0;
- LcdEn_P = 0;
- P0=dat;
- DelayMs(2);
- LcdEn_P = 1;
- DelayMs(2);
- LcdEn_P = 0;
- // 1602液晶初始化函數(shù)
- void LcdInit()
- LcdWriteCmd(0x38); // 16*2顯示,5*7點(diǎn)陣,8位數(shù)據(jù)口
- LcdWriteCmd(0x0C); // 開顯示,不顯示光標(biāo)
- LcdWriteCmd(0x06); // 地址加1,當(dāng)寫入數(shù)據(jù)后光標(biāo)右移
- LcdWriteCmd(0x01); // 清屏
- // 液晶光標(biāo)定位函數(shù)
- void LcdGotoXY(uchar line,uchar column)
- // 第一行
- if(line==0)
- LcdWriteCmd(0x80+column);
- // 第二行
- if(line==1)
- LcdWriteCmd(0x80+0x40+column);
- // 液晶輸出字符串函數(shù)
- void LcdPrintStr(uchar *str)
- while(*str!='\0')
- LcdWriteData(*str++);
- // 液晶輸出數(shù)字
- void LcdPrintNum(uint num)
- LcdWriteData(num/100+0x30); // 百位
- LcdWriteData(num%100/10+0x30); // 十位
- LcdWriteData(num%10+0x30); // 個位
- // 計(jì)算測到的距離
- uint GetDistance(void)
- uint ss; // 用于記錄測得的距離
- TH0=0;
- TL0=0;
- Trig_P=1; // 給超聲波模塊一個開始脈沖
- DelayMs(1);
- Trig_P=0;
- while(!Echo_P); // 等待超聲波模塊的返回脈沖
- TR0=1; // 啟動定時器,開始計(jì)時
- while(Echo_P); // 等待超聲波模塊的返回脈沖結(jié)束
- TR0=0; // 停止定時器,停止計(jì)時
- ss=((TH0*256+TL0)*0.034)/2; // 距離cm=(時間us * 速度cm/us)/2
- return ss;
- // 按鍵掃描
- void KeyScanf()
- uchar i;
- uchar dat1,dat2;
- if(KeySet_P==0) // 判斷是否有按鍵按下
- DelayMs(10); // 消除按鍵按下的抖動
- while(!KeySet_P); // 等待按鍵釋放
- DelayMs(10); // 消除按鍵松開的抖動
- LcdGotoXY(1,2); // 液晶第二行刷新顯示
- LcdPrintStr("alarm= cm");
- LcdGotoXY(1,8); // 顯示當(dāng)前的報(bào)警值
- LcdPrintNum(gAlarm);
- i=1;
- while(i)
- if(KeyDown_P==0) // 報(bào)警值減的處理
- DelayMs(300);
- if(gAlarm>2)
- gAlarm--;
- LcdGotoXY(1,8);
- if(KeyUp_P==0) // 報(bào)警值加的處理
- DelayMs(300);
- if(gAlarm<400)
- gAlarm++;
- LcdGotoXY(1,8);
- if(KeySet_P==0) // 再次按下設(shè)置鍵的判斷
- LcdGotoXY(1,0); // 液晶恢復(fù)測量時的內(nèi)容顯示
- LcdPrintStr(" S= cm ");
- i=0;
- dat1=gAlarm/100;
- dat2=gAlarm%100;
- Sector_Erase(0x2000);
- EEPROM_Write(0x2000,dat1);
- EEPROM_Write(0x2001,dat2);
- // 報(bào)警判斷
- void AlarmJudge(uint ss)
- uchar i;
- float alr1,alr2,alr3,alr4;
- alr1=gAlarm/4.00*1;
- alr2=gAlarm/4.00*2;
- alr3=gAlarm/4.00*3;
- alr4=gAlarm/4.00*4;
- // 報(bào)警頻率最快
- if(ss<alr1)
- for(i=0;i<10;i++)
- Led_P=0;
- Buzzer_P=0;
- DelayMs(50);
- Led_P=1;
- Buzzer_P=1;
- DelayMs(50);
- KeyScanf();
- // 報(bào)警頻率第二快
- else if(ss<alr2)
- for(i=0;i<5;i++)
- Led_P=0;
- Buzzer_P=0;
- DelayMs(100);
- Led_P=1;
- Buzzer_P=1;
- DelayMs(100);
- KeyScanf();
- // 報(bào)警頻率第三快
- else if(ss<alr3)
- for(i=0;i<2;i++)
- Led_P=0;
- Buzzer_P=0;
- DelayMs(200);
- Led_P=1;
- Buzzer_P=1;
- DelayMs(200);
- KeyScanf();
- // 報(bào)警頻率最慢
- else if(ss<alr4)
- for(i=0;i<2;i++)
- Led_P=0;
- Buzzer_P=0;
- DelayMs(300);
- Led_P=1;
- Buzzer_P=1;
- DelayMs(300);
- KeyScanf();
- // 不報(bào)警
- else
- Led_P=1;
- Buzzer_P=1;
- for(i=0;i<100;i++)
- KeyScanf();
- DelayMs(10);
- // 主函數(shù)
- void main()
- uchar dat1,dat2;
- uint dist;
- Trig_P=0;
- LcdInit(); // 執(zhí)行液晶初始化
- TMOD = 0x01; // 選擇定時器0,并且確定是工作方式1(為了超聲波模塊測量距離計(jì)時用的)
- LcdGotoXY(0,0); // 定位到第0行第0列
- LcdPrintStr(" HC-SR04 System "); // 第0行顯示“HC-SR04 System”
- LcdGotoXY(1,0); // 定位到第1行第0列
- LcdPrintStr(" S= cm "); // 第1行顯示“S= cm”
- dat1=EEPROM_Read(0x2000); // 從EEPROM讀取報(bào)警值
- dat2=EEPROM_Read(0x2001);
- gAlarm=dat1*100+dat2;
- if((gAlarm==0)||(gAlarm>400)) // 如果讀取到的報(bào)警值異常(等于0或大于400則認(rèn)為異常)
- gAlarm=25; // 重新賦值報(bào)警值為25
- while(1)
- dist=GetDistance(); // 通過超聲波模塊獲取距離
- LcdGotoXY(1,7); // 定位到第1行第7列
- LcdPrintNum(dist); // 將獲取到的距離在液晶上面顯示
- AlarmJudge(dist); // 判斷一下是否需要報(bào)警,是的話則報(bào)警
09、仿真圖.rar
(637.62 KB, 下載次數(shù): 324)
2019-10-10 20:34 上傳
點(diǎn)擊文件名下載附件
07、單片機(jī)程序(先解壓,后查看).rar
(283.83 KB, 下載次數(shù): 287)
2019-10-10 20:34 上傳
點(diǎn)擊文件名下載附件
