注釋掉的為轉(zhuǎn)四字節(jié)方案
未注釋掉的為直觀顯示數(shù)據(jù)方案
定時器1中斷1ms
INTERRUPT_HANDLER(TIM1_UPD_OVF_TRG_BRK_IRQHandler, 11)
/* In order to detect unexpected events during development,
it is recommended to set a breakpoint on the following instruction.
// uint16_t i, j;
// TIM1_ClearITPendingBit(TIM1_IT_UPDATE);
// GPIO_WriteHigh(GPIOD, GPIO_PIN_3);
// while(( UART3_GetFlagStatus(UART3_FLAG_TXE)==RESET));
// UART3_SendData8(1);
// for(i = 0; i < 60000; i++);
// GPIO_WriteLow(GPIOD, GPIO_PIN_3);
static u16 time = 0;
float root = 0;
// u8 * p;
// u8 ftc1, ftc2, ftc3, ftc4;
// u8 high3, low3;
UartReadMonitor(1);
if(time == 100)
root = SF6Root(273,0.5);
UART3_SendData8((u8)((unsigned int)(root/100)%10)+48);
UART3_SendData8((u8)((unsigned int)(root/10)%10)+48);
UART3_SendData8((u8)((unsigned int)(root/1)%10)+48);
UART3_SendData8('.');
UART3_SendData8((u8)((unsigned int)(root*10)%10)+48);
UART3_SendData8((u8)((unsigned int)(root*100)%10)+48);
UART3_SendData8((u8)((unsigned int)(root*1000)%10)+48);
// p = (u8 *)(&root);
// high3 = (u8)root;
// low3 = (u8)((root - high3)*100);
// ftc1 = *p++;
// ftc2 = *p++;
// ftc3 = *p++;
// ftc4 = *p;
// UART3_SendData8(high3);
// UART3_SendData8(low3);
// UART3_SendData8(ftc4);
// UART3_SendData8(ftc3);
// UART3_SendData8(ftc2);
// UART3_SendData8(ftc1);
time = 0;
time++;
