查看: 3499|回復(fù): 10
奇怪了 真奇怪了 關(guān)于74hc595驅(qū)動(dòng)LED的問(wèn)題
ID:590194 發(fā)表于 2019-10-8 17:08 | 顯示全部樓層 |閱讀模式
顯示效果應(yīng)該是 011111111 11111111 11111111 01111111 11111111 11111111
但是實(shí)際效果是 011111111 11111111 11111111 11111111 11111111 11111111
第二行應(yīng)該是 101111111 11111111 11111111 10111111 11111111 11111111
實(shí)際效果是    101111111 11111111 11111111 01111111 11111111 11111111
導(dǎo)致最后顯示到最后一個(gè)的時(shí)最后2個(gè)LED一起滅
void In_Data(unsigned char a,b,c)
        unsigned char i,j,u;
for(u=0;u<6;u++)
  if(u==0){j=a;}
  if(u==1){j=b;}
  if(u==2){j=c;}
  if(u==3){j=a;}
  if(u==4){j=b;}
  if(u==5){j=c;}
        for(i=0;i<8;i++)
                j<<=1;
                _nop_();_nop_();
                Ds=CY;
               _nop_();_nop_();
                Sh=0;
                _nop_();_nop_();
                Sh=1;
        St=0;
        _nop_();_nop_();
        St=1;
if(i==0){In_Data(0x7F,0xFF,0xFF);}//01111111 11111111 11111111
if(i==1 || i==45){In_Data(0xBF,0xFF,0xFF);}//10111111 11111111 11111111
if(i==2 || i==44){In_Data(0xDF,0xFF,0xFF);}//11011111 11111111 11111111
if(i==3 || i==43){In_Data(0xEF,0xFF,0xFF);}//11101111 11111111 11111111
if(i==4 || i==42){In_Data(0xF7,0xFF,0xFF);}//11110111 11111111 11111111
if(i==5 || i==41){In_Data(0xFB,0xFF,0xFF);}//11111011 11111111 11111111
if(i==6 || i==40){In_Data(0xFD,0xFF,0xFF);}//11111101 11111111 11111111
if(i==7 || i==39){In_Data(0xFE,0xFF,0xFF);}//11111110 11111111 11111111
if(i==8 || i==38){In_Data(0xFF,0x7F,0xFF);}//11111111 01111111 11111111
if(i==9 || i==37){In_Data(0xFF,0xBF,0xFF);}//11111111 10111111 11111111
if(i==10 || i==36){In_Data(0xFF,0xDF,0xFF);}//11111111 11011111 11111111
if(i==11 || i==35){In_Data(0xFF,0xEF,0xFF);}//11111111 11101111 11111111
if(i==12 || i==34){In_Data(0xFF,0xF7,0xFF);}//11111111 11110111 11111111
if(i==13 || i==33){In_Data(0xFF,0xFB,0xFF);}//11111111 11111011 11111111
if(i==14 || i==32){In_Data(0xFF,0xFD,0xFF);}//11111111 11111101 11111111
if(i==15 || i==31){In_Data(0xFF,0xFE,0xFF);}//11111111 11111110 11111111
if(i==16 || i==30){In_Data(0xFF,0xFF,0x7F);}//11111111 11111111 01111111
if(i==17 || i==29){In_Data(0xFF,0xFF,0xBF);}//11111111 11111111 10111111
if(i==18 || i==28){In_Data(0xFF,0xFF,0xDF);}//11111111 11111111 11011111
if(i==19 || i==27){In_Data(0xFF,0xFF,0xEF);}//11111111 11111111 11101111
if(i==20 || i==26){In_Data(0xFF,0xFF,0xF7);}//11111111 11111111 11110111
if(i==21 || i==25){In_Data(0xFF,0xFF,0xFB);}//11111111 11111111 11111011
if(i==22 || i==24){In_Data(0xFF,0xFF,0xFD);}//11111111 11111111 11111101
if(i==23){In_Data(0xFF,0xFF,0xFE);}//11111111 11111111 11111110
DelayMS(1200);
i++;
if(i==46){i=0;}
ID:213173 發(fā)表于 2019-10-9 11:04 | 顯示全部樓層
  1. #include <reg51.h>
  2. #include <intrins.h>
  3. sbit Ds=P1^0;
  4. sbit Sh=P1^1;
  5. sbit St=P1^2;
  6. void DelayMS(unsigned int z)
  7. {
  8.         unsigned char x;
  9.         while(z--)
  10.                 for(x=120;x>0;x--);
  11. }
  12. void In_Data(unsigned char a,b,c)
  13. {
  14.         unsigned char i,j,u;
  15.         for(u=0;u<6;u++)
  16.         {
  17.                 if(u==0){j=a;}
  18.                 if(u==1){j=b;}
  19.                 if(u==2){j=c;}
  20.                 if(u==3){j=a;}
  21.                 if(u==4){j=b;}
  22.                 if(u==5){j=c;}
  23.                 for(i=0;i<8;i++)
  24.                 {
  25.                         j<<=1;
  26.                         _nop_();_nop_();
  27.                         Ds=CY;
  28.                         _nop_();_nop_();
  29.                         Sh=0;
  30.                         _nop_();_nop_();
  31.                         Sh=1;
  32.                 }
  33.         }
  34.         St=0;
  35.         _nop_();_nop_();
  36.         St=1;
  37. }
  38. void main()
  39. {
  40.         unsigned char i;
  41.         while(1)
  42.         {
  43.                 if(i==0)          {In_Data(0x7F,0xFF,0xFF);}//01111111 11111111 11111111
  44.                 if(i==1 || i==45) {In_Data(0xBF,0xFF,0xFF);}//10111111 11111111 11111111
  45.                 if(i==2 || i==44) {In_Data(0xDF,0xFF,0xFF);}//11011111 11111111 11111111
  46.                 if(i==3 || i==43) {In_Data(0xEF,0xFF,0xFF);}//11101111 11111111 11111111
  47.                 if(i==4 || i==42) {In_Data(0xF7,0xFF,0xFF);}//11110111 11111111 11111111
  48.                 if(i==5 || i==41) {In_Data(0xFB,0xFF,0xFF);}//11111011 11111111 11111111
  49.                 if(i==6 || i==40) {In_Data(0xFD,0xFF,0xFF);}//11111101 11111111 11111111
  50.                 if(i==7 || i==39) {In_Data(0xFE,0xFF,0xFF);}//11111110 11111111 11111111
  51.                 if(i==8 || i==38) {In_Data(0xFF,0x7F,0xFF);}//11111111 01111111 11111111
  52.                 if(i==9 || i==37) {In_Data(0xFF,0xBF,0xFF);}//11111111 10111111 11111111
  53.                 if(i==10 || i==36){In_Data(0xFF,0xDF,0xFF);}//11111111 11011111 11111111
  54.                 if(i==11 || i==35){In_Data(0xFF,0xEF,0xFF);}//11111111 11101111 11111111
  55.                 if(i==12 || i==34){In_Data(0xFF,0xF7,0xFF);}//11111111 11110111 11111111
  56.                 if(i==13 || i==33){In_Data(0xFF,0xFB,0xFF);}//11111111 11111011 11111111
  57.                 if(i==14 || i==32){In_Data(0xFF,0xFD,0xFF);}//11111111 11111101 11111111
  58.                 if(i==15 || i==31){In_Data(0xFF,0xFE,0xFF);}//11111111 11111110 11111111
  59.                 if(i==16 || i==30){In_Data(0xFF,0xFF,0x7F);}//11111111 11111111 01111111
  60.                 if(i==17 || i==29){In_Data(0xFF,0xFF,0xBF);}//11111111 11111111 10111111
  61.                 if(i==18 || i==28){In_Data(0xFF,0xFF,0xDF);}//11111111 11111111 11011111
  62.                 if(i==19 || i==27){In_Data(0xFF,0xFF,0xEF);}//11111111 11111111 11101111
  63.                 if(i==20 || i==26){In_Data(0xFF,0xFF,0xF7);}//11111111 11111111 11110111
  64.                 if(i==21 || i==25){In_Data(0xFF,0xFF,0xFB);}//11111111 11111111 11111011
  65.                 if(i==22 || i==24){In_Data(0xFF,0xFF,0xFD);}//11111111 11111111 11111101
  66.                 if(i==23)         {In_Data(0xFF,0xFF,0xFE);}//11111111 11111111 11111110
  67.                 DelayMS(1200);
  68.                 i++;
  69.                 if(i==46){i=0;}
  70.         }
  71. }
ID:123289 發(fā)表于 2019-10-9 16:19 | 顯示全部樓層
用示波器看,走單步。
ID:590194 發(fā)表于 2019-10-9 20:18 來(lái)自觸屏版 | 顯示全部樓層
wulin 發(fā)表于 2019-10-9 11:04
樓主描述的奇怪現(xiàn)象不存在,有圖為證。
用的是我貼出來(lái)的代碼?硬件接線不會(huì)有問(wèn)題,我有視頻為證
ID:213173 發(fā)表于 2019-10-10 10:24 | 顯示全部樓層
sq8422779 發(fā)表于 2019-10-9 20:18
把你的完整程序和硬件接線圖發(fā)出來(lái)分析才能知道問(wèn)題所在
ID:590194 發(fā)表于 2019-10-12 09:03 來(lái)自觸屏版 | 顯示全部樓層
wulin 發(fā)表于 2019-10-10 10:24
按照?qǐng)D片順序跳線的
ID:590194 發(fā)表于 2019-10-12 13:25 | 顯示全部樓層
74HC595流水燈 - 48燈.rar (68.64 KB, 下載次數(shù): 15)
這個(gè)是代碼  麻煩看下,....很奇怪的問(wèn)題
ID:590194 發(fā)表于 2019-10-12 13:26 | 顯示全部樓層
595的引腳 只接了11 12 14
ID:213173 發(fā)表于 2019-10-12 15:08 | 顯示全部樓層
sq8422779 發(fā)表于 2019-10-12 13:26
595的引腳 只接了11 12 14
軟件都是基于硬件條件編寫的。你的仿真電路圖與程序風(fēng)馬牛不相及。
ID:590194 發(fā)表于 2019-10-13 10:01 來(lái)自觸屏版 | 顯示全部樓層
wulin 發(fā)表于 2019-10-12 15:08
仿真文件不是的,我直接下載到硬件上測(cè)試的,還有我問(wèn)下,595的11 12 14 中間最長(zhǎng)多遠(yuǎn),我放在2個(gè)地方,中間差不多有3米,會(huì)不會(huì)行為這個(gè)原因
ID:213173 發(fā)表于 2019-10-15 11:20 | 顯示全部樓層
本帖最后由 wulin 于 2019-10-15 13:58 編輯
sq8422779 發(fā)表于 2019-10-13 10:01
仿真文件不是的,我直接下載到硬件上測(cè)試的,還有我問(wèn)下,595的11 12 14 中間最長(zhǎng)多遠(yuǎn),我放在2個(gè)地方, ...
單片機(jī)與595之間3根線就可以了,但兩塊板子必須共地,所有595的10、16腳接VCC,8、13腳接GND。先用短線調(diào)試,成功后再改長(zhǎng)線試。從你的程序看單片機(jī)用的是STC15系列芯片,流水燈已改成對(duì)稱方式,已設(shè)置3個(gè)輸出口為推挽模式,端口有足夠的帶負(fù)載能力和抗干擾能力。如果還不行把單片機(jī)的3個(gè)輸出口接510歐上拉電阻,連線換成屏蔽線。 595驅(qū)動(dòng)LED仿真.zip (110.42 KB, 下載次數(shù): 19)
