查看: 1525|回復: 1
STM32 ADC雙通道
ID:302293 發表于 2019-9-30 08:45 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
ADC_RegularChannelConfig(ADC1,ADC_Channel_1 , 1, ADC_SampleTime_239Cycles5 );
ADC_RegularChannelConfig(ADC1,ADC_Channel_2 , 2, ADC_SampleTime_239Cycles5 );
void DMA1_Channel1_IRQHandler(void)
if( DMA_GetITStatus(DMA1_IT_TC1) !=  RESET)
voltage[0] = (float)ADC_Soure[0] * (3.3/4096.0);
voltage[1] = (float)ADC_Soure[1] * (3.3/4096.0);
DMA_ClearITPendingBit(DMA1_IT_TC1);
#ifndef _ADC_H
#define _ADC_H
* 文件名  :main.c
* 描述    :串口1(USART1)向電腦的超級終端以1s為間隔打印當前ADC1的轉換電壓值
* 實驗平臺:MINI STM32開發板 基于STM32F103C8T6
* 庫版本  :ST3.0.0
#include "stm32f10x.h"
#include "stdio.h"
extern __IO u16 ADC_ConvertedValue[2];//ADC1轉換的電壓值通過DMA方式傳到SRAM
float ADC_ConvertedValueLoacl[2];//用于保存轉換計算后的電壓值
// 軟件延時
#define ADC1_DR_Address ((u32)0x4001244C)
/*配置采樣通道端口 使能GPIO時鐘          設置ADC采樣PA0端口信號*/
#define        Res1        4700        //4.7K
#define        BValue        3435  //10K
float Rt,Temperature,Voltage;
void ADC1_GPIO_Config(void)
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;                    //GPIO設置為模擬輸入
  GPIO_Init(GPIOA, &GPIO_InitStructure);
/*配置ADC1的工作模式為MDA模式  */
void ADC1_Mode_Config(void)
  DMA_InitTypeDef DMA_InitStructure;
  ADC_InitTypeDef ADC_InitStructure;
  RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE); //使能MDA1時鐘
         RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1, ENABLE);        //使能ADC1時鐘
        /* DMA channel1 configuration */
  DMA_DeInit(DMA1_Channel1);  //指定DMA通道
  DMA_InitStructure.DMA_PeripheralBaseAddr = ADC1_DR_Address;//設置DMA外設地址
  DMA_InitStructure.DMA_MemoryBaseAddr = (u32)&ADC_ConvertedValue;        //設置DMA內存地址,ADC轉換結果直接放入該地址
  DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC; //外設為設置為數據傳輸的來源
  DMA_InitStructure.DMA_BufferSize = 2;        //DMA緩沖區設置為1;
  DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
  DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_ENABLE;
  DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
  DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
  DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
  DMA_InitStructure.DMA_Priority = DMA_Priority_High;
  DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
  DMA_Init(DMA1_Channel1, &DMA_InitStructure);
  /* Enable DMA channel1 */
  DMA_Cmd(DMA1_Channel1, ENABLE);  //使能DMA通道
/* ADC1 configuration */
  ADC_InitStructure.ADC_Mode = ADC_Mode_Independent; //使用獨立模式,掃描模式
  ADC_InitStructure.ADC_ScanConvMode = ENABLE;
  ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;
  ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None; //無需外接觸發器
  ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;//使用數據右對齊
  ADC_InitStructure.ADC_NbrOfChannel = 2;  // 只有1個轉換通道
  ADC_Init(ADC1, &ADC_InitStructure);
/* ADC1 regular channel11 configuration */
  ADC_RegularChannelConfig(ADC1, ADC_Channel_0, 1, ADC_SampleTime_55Cycles5); //通道0采樣周期55.5個時鐘周期
  ADC_RegularChannelConfig(ADC1, ADC_Channel_1, 2, ADC_SampleTime_55Cycles5); //通道0采樣周期55.5個時鐘周期
ADC_TempSensorVrefintCmd(ENABLE);//開啟溫度控制寄存器
/* Enable ADC1 DMA */
  ADC_DMACmd(ADC1, ENABLE);         //使能ADC的DMA
  /* Enable ADC1 */
  ADC_Cmd(ADC1, ENABLE); //使能ADC1
/* Enable ADC1 reset calibaration register */
  ADC_ResetCalibration(ADC1);        //使能復位校準
  /* Check the end of ADC1 reset calibration register */
  while(ADC_GetResetCalibrationStatus(ADC1));//等待復位校準結束
  /* Start ADC1 calibaration */
  ADC_StartCalibration(ADC1);//開啟AD校準
  /* Check the end of ADC1 calibration */
  while(ADC_GetCalibrationStatus(ADC1));
  /* Start ADC1 Software Conversion */
ADC_SoftwareStartConvCmd(ADC1, ENABLE);  //開始轉換
/*初始化ADC1 */
void ADC1_Init(void)
        ADC1_GPIO_Config();
        ADC1_Mode_Config();
void Delay(unsigned long time)
        unsigned long i,j;
        for(j=0; j<time; j++)
           for(i=0;i<12000;i++);
void USART1_Config(void)
        USART_InitTypeDef USART_InitStructure;
        /* 使能 USART1 時鐘*/
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1 | RCC_APB2Periph_GPIOA, ENABLE);
        /* USART1 使用IO端口配置 */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; //復用推挽輸出
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;        //浮空輸入
  GPIO_Init(GPIOA, &GPIO_InitStructure);   //初始化GPIOA
        /* USART1 工作模式配置 */
        USART_InitStructure.USART_BaudRate =115200;        //波特率設置:115200
        USART_InitStructure.USART_WordLength = USART_WordLength_8b;        //數據位數設置:8位
        USART_InitStructure.USART_StopBits = USART_StopBits_1;         //停止位設置:1位
        USART_InitStructure.USART_Parity = USART_Parity_No ;  //是否奇偶校驗:無
        USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;        //硬件流控制模式設置:沒有使能
        USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;//接收與發送都使能
        USART_Init(USART1, &USART_InitStructure);  //初始化USART1
        USART_Cmd(USART1, ENABLE);// USART1使能
/* 描述  :重定向c庫函數printf到USART1*/
int fputc(int ch, FILE *f)
/* 將Printf內容發往串口 */
  USART_SendData(USART1, (unsigned char) ch);
  while (!(USART1->SR & USART_FLAG_TXE));
  return (ch);
int main(void)
//  u32 AD_value;
  u32 i,ADC;
        /* 配置系統時鐘為72M */
// SystemInit();
  /* 配置串口 */
  ADC1_Init();
  USART1_Config();
  /* 初始化ADC1 */
//  printf("");//打印電壓值初始化不能關閉
  while (1)
     ADC_ConvertedValueLoacl[0]=(float)ADC_ConvertedValue[0]/4096*3.3;
     ADC_ConvertedValueLoacl[1]=(float)ADC_ConvertedValue[1]/4096*3.3;
     printf("ADC0 = %fv\r\n", ADC_ConvertedValueLoacl[0]);
//         AD_value  = 3300000/4096*ADC_ConvertedValue/1000;
           ADC=0;
         for(i=0;i<50;i++)
                  while(!ADC_GetFlagStatus(ADC1, ADC_FLAG_EOC));//等待轉換結束標志位
                  ADC=ADC+ADC_GetConversionValue(ADC1);//返回最近一次 ADCx 規則組的轉換結果
                 ADC=ADC/50;
                printf("溫度 = %f℃\r\n",(1.43-3.3/4095*ADC)/0.0043+25);
// printf("ADC = %fv\r\n", ADC*3.3/4095);
   Delay(3000);//延時不低于1s
#endif
ID:1 發表于 2019-9-30 16:29 | 只看該作者
本帖需要重新編輯補全電路原理圖,源碼,詳細說明與圖片即可獲得100+黑幣(帖子下方有編輯按鈕)
