查看: 3161|回復: 3
STM32F103C8T6最小系統配置測試程序
ID:596000 發表于 2019-9-29 09:59 | 顯示全部樓層 |閱讀模式
關于STM32F103C8T6最小系統配置測試
  1. /#include "stm32f10x.h"
  2. unsigned char *P_RXD;//接收數據指針
  3. unsigned int Num_RXD=0;//要打印字節區位碼的字節數
  4. unsigned char TxBuffer[64]={0,2,3,};//串口發送緩沖區
  5. unsigned char RxBuffer[64]; //串口接收緩沖區
  6. unsigned char Key0=0;
  7. unsigned char Key0_Value=0;
  8. unsigned char Key0_State=0;
  9. unsigned char LED0_State=0;
  10. unsigned char t;
  11. unsigned char JG;//數據比較結果
  12. void Key_Delay (void)
  13. {
  14.         unsigned int i;
  15.
  16.         for(i=0;i<0xfff;i++);
  17.
  18.
  19. }
  20. void Time_Delay (void)
  21. {
  22.         unsigned int i;
  23.                 unsigned int j;
  24.
  25.         for(i=0;i<0xfff;i++)
  26.         {
  27.
  28.                 for(j=0;j<0xFFFF;j++);
  29.   };
  30.
  31.
  32. }
  33. /** @addtogroup Template_Project
  34.   * @{
  35.   */
  36. /* Private typedef -----------------------------------------------------------*/
  37. /* Private define ------------------------------------------------------------*/
  38. /* Private macro -------------------------------------------------------------*/
  39. /* Private variables ---------------------------------------------------------*/
  40. /* Private function prototypes -----------------------------------------------*/
  41. /* Private functions ---------------------------------------------------------*/
  42. /* Private function prototypes -----------------------------------------------*/
  43. //void Delay(int nCount);
  44. /**
  45.   * @brief  Main program.
  46.   * @param  None
  47.   * @retval : None
  48.   */
  49. int main(void)
  50. {
  51.   /* Setup STM32 system (clock, PLL and Flash configuration) */
  52.   SystemInit();
  53.   RCC_Configuration();
  54.   NVIC_Configuration();
  55.   GPIO_Configuration();
  56.   SysTick_init();                     //延時初始化
  57.   SPI2_Init();                              //初始化SPI硬件口
  58.         P_RXD=RxBuffer;//接收指針指向接收緩沖區
  59.
  60.   USART_Configuration();  //USART1配置
  61.   TIM2_Config();                        //定時器初始化
  62.
  63.     OLED_Init();                         //初始化OLED
  64.           OLED_ShowString(1,0, "0.96' OLED TEST");
  65.           OLED_ShowString(1,16,"mcudev.taobao  ");
  66.            OLED_ShowString(1,32,"2014-06-16");
  67.           OLED_ShowString(1,48,"ASCII: ");
  68.           OLED_ShowString(63,48,"CODE: ");
  69.                 {
  70.                         unsigned char i;
  71.
  72.                         for(i=0;i<32;i++)TxBuffer[i]=i;
  73.
  74.     }
  75.
  76.                 I2CWriteByte(0,TxBuffer,32); //寫入長度
  77.
  78.                 I2CReadByte(0,RxBuffer,32);
  79.
  80.                 JG=Compare_Mem (TxBuffer,RxBuffer,32);
  81.
  82.                 if(JG==0)//對Eeprom進行讀寫判斷;
  83.                 {
  84.                         OLED_ShowString(1,32,"Eeprom--OK  ");
  85.                         }
  86.                 else
  87.                         {
  88.                                 OLED_ShowString(1,32,"Eeprom--Error  ");
  89.       }
  90.   /* Infinite loop */
  91.   while (1)
  92.   {
  93.
  94.                 OLED_ShowChar(48,48,t,16,1);// OLED_Refresh_Gram();
  95.
  96.                 t++;
  97.                 if(t>'~')t=' ';
  98.
  99.                 OLED_ShowNum(103,48,t,3,16);//
  100.
  101.
  102.                 if(Key0_State==0xff)
  103.                 {
  104.       LED0_State=!LED0_State;
  105.                          delay_ms(300);
  106.                         Key0_State=0;
  107.
  108.       }
  109.
  110.                 if(LED0_State==0)
  111.                                  {
  112.                                          LED0_ON();//LED亮
  113.                                          delay_ms(200);
  114.                                          LED0_OFF();//LED滅
  115.                                          delay_ms(200);
  116.                          }
  117.
  118.   }
  119. }
  120. #ifdef  USE_FULL_ASSERT
  121. /**
  122.   * @brief  Reports the name of the source file and the source line number
  123.   *   where the assert_param error has occurred.
  124.   * @param file: pointer to the source file name
  125.   * @param line: assert_param error line source number
  126.   * @retval : None
  127.   */
  128. void assert_failed(uint8_t* file, uint32_t line)
  129. {
  130.   /* User can add his own implementation to report the file name and line number,
  131.      ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  132.   /* Infinite loop */
  133.   while (1)
  134.   {
  135.
  136.   }
  137. }
  138. #endif
  139. /**
  140.   * @}
  141.   */
  142. /******************* (C) COPYRIGHT 2009 STMicroelectronics *****END OF FILE****/
STM32_OLED(C8T6).7z (177.42 KB, 下載次數: 26)
ID:638930 發表于 2019-11-9 23:09 | 顯示全部樓層
正需要這個,謝謝
ID:638930 發表于 2019-11-9 23:10 | 顯示全部樓層
謝謝分享
ID:638930 發表于 2019-11-18 17:37 | 顯示全部樓層
學習一下
