現在可以把數碼管檢測示數但不懂如何觸發報警和按鍵儲存溫度上下限,多天無解,還望解惑。
#include<reg52.h>
#include<intrins.h>
typedef unsigned char uchar;
typedef unsigned int uint;
#define MAIN_Fosc 11059200UL
sbit DS = P3^7;
sbit we1=P2^0;
sbit we2=P2^1;
sbit we3=P2^2;
sbit we4=P2^3;
sbit deep=P3^6;
sbit key=P3^5;
sbit key2=P3^4;
sbit key3=P3^3;
sbit key4=P3^2;
uchar temp;
uchar num;
uchar settemp=35;
uchar settemp2=10;
bit DS18B20;
uchar msec, sec;
unsigned char code leddata[]={
0xC0, //"0"
0xF9, //"1"
0xA4, //"2"
0xB0, //"3"
0x99, //"4"
0x92, //"5"
0x82, //"6"
0xF8, //"7"
0x80, //"8"
0x90, //"9"
0x88, //"A"
0x83, //"B"
0xC6, //"C"
0xA1, //"D"
0x86, //"E"
0x8E, //"F"
0x89, //"H"
0xC7, //"L"
0xC8, //"n"
0xC1, //"u"
0x8C, //"P"
0xA3, //"o"
0xBF, //"-"
0xFF, //???
0xFF //?????
void delay (uint z)
uint x,y;
for(x=z;x>0;x--)
for(y=84;y>0;y--);
void us(uchar us)//us???????
while(us--);
void display( uint value)
we1=1;
we1=0;
P0=0xff;
P0=leddata[value/1000];
delay(1);
we1=1;
we2=0;
P0&=0x7f;
P0=leddata[value%1000/100];
delay(1);
we2=1;
we3=0;
P0=0xff;
P0=leddata[value%100/10];
delay(1);
we3=1;
P0=0xff;
P0=leddata[value%10];
we4=0;
delay(1);
we4=1;
void display3( uint value)
we1=1;
we1=0;
P0=0xff;
delay(1);
we1=1;
we2=0;
P0&=0x7f;
delay(1);
we2=1;
we3=0;
P0=0xff;
delay(1);
we3=1;
P0=0xff;
we4=0;
delay(1);
we4=1;
void beep1()
temp=0xfe;
P1=temp;
delay(100);
temp=_crol_(temp,1);
P1=temp;
deep=~deep;
delay(100);
void display2()
if(key == 0)
delay(5);
if(key == 0)
while(!key);
settemp++;
delay(50);
if(settemp==99)
settemp=0;
delay(50);
if(key2 == 0)
delay(5);
if(key2 == 0)
while(!key2);
if(settemp!=0)
settemp--;
delay(50);
if(key3 == 0)
delay(5);
if(key3 == 0)
while(!key3);
settemp2++;
delay(50);
if(settemp2==99)
settemp2=0;
delay(50);
if(key4 == 0)
delay(5);
if(key4 == 0)
while(!key4);
if(settemp2!=0)
settemp2--;
delay(50);
void duan ()
EA=1;
ET0=1;
TR0=1;
TMOD=0x01;
TH0=0x4b;
TL0=0xfd;
void timer0() interrupt 1
TH0=0x4b;
TL0=0xfd;
msec++;
if(msec==20)
msec=0;
bit init()
bit i;
DS = 1;//??????
_nop_();
DS = 0;
us(75); //????????75*6.5+11.95=499.45us ????????????18B20???????????
DS=1;
us(4);//???
i = DS;
us(20); //141.95us ???????
DS = 1;
_nop_();
return (i);
void write (uchar dat)//д ???
uchar i;
for(i=0;i<8;i++)
DS = 0;
_nop_();//????д???
DS = dat & 0x01;//?????????
us(10);//76.95us
DS = 1; //???????????????????д??
_nop_();
dat >>= 1;//??????
uchar read_byte()
uchar i, j, dat;
for(i=0;i<8;i++)
DS = 0;
_nop_();//?????????
DS = 1;
_nop_();//???????
j = DS;
us(10);//76.95us
DS = 1;
_nop_();
dat = (j<<7)|(dat>>1);//????
return (dat);
uint i;
uchar L, M;
init();//?????DS18B20
write(0xcc);//???????ROM???
write(0x4e);//????д????????
write(0x18);
write(0x10);
write(0x7f);
init();
write(0xcc);
write(0x48);
write(0x44);//?????????????
init(); //?????DS18B20
write(0xbe);//???DS18B20??????
L = read_byte();
M = read_byte();
i = M;
i <<= 8;
i |= L;
i = i * 0.0625 * 100 + 0.05;
display(i);
duan();
if(key==0|key2==0|key3==0|key4==0)
{ if(key==0)
settemp=settemp*100;
while(!key);
display3(settemp);}
if(key2==0)
{ settemp=settemp*100;
while(!key2);
display3(settemp);}
if(key3==0)
{ settemp2=settemp2*100;
while(!key3);
display3(settemp2);}
if(key4==0)
{settemp2=settemp2*100;
while(!key4);
