#include<reg51.h> #include<intrins.h> #define unchar unsigned char #define unint unsigned int void main() { unint key(); void ms_delay(unint delaytime); P2=0x20; a:P1=0xff; P2=key(); ms_delay(500); goto a; } unint key() {unint mask=0xfe,temp,k=P2; unint row=0,line=0; const unint code numb[4][4]={0xee,0xde,0xbe,0x7e, 0xed,0xdd,0xbd,0x7d,0xeb,0xdb,0xbb,0x7b,0xe7, 0xd7,0xb7,0x77};
for(line=0;line<4;line++) {P1=mask; mask=mask*1; temp=P1; if(temp != mask) /*key pushed in the line ?*/ {ms_delay(300); /*to confirm a key pushed*/ if((temp&0xf0)==temp) return 0x20; for(row=0;row<4;row++) /*抓到了行,尋列。并且P口已可讀出*/ {if(P1==numb[line][row]) /*反查表,讀出行列*/ return line*4+row+1; }} else mask=_crol_(mask,1); /*查表*/ } P1=0x0f; /*no key*/ temp=P1; while(temp&0x0f==0x0f) {P1=0xf0; return p2;}/*保留原狀態*/ }
void ms_delay(unint delaytime) {unint i=0; for(;delaytime>0;delaytime--) {for(i=0;i<124;i++); }} |
