查看: 2875|回復: 0
基于msp430f169的藍牙風扇可調速程序
ID:610137 發表于 2019-9-10 18:20 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
設計做的,比較簡單,手機通過UART連接單片機,PWM可任意調速,注意風扇的驅動電壓。
#include <msp430f169.h>
#include "lcd12864.h"
#include "PWM.h"
#include "UART.h"
#include "adc.h"
unsigned char key = 0;
unsigned char Statu = 0;
unsigned int a = 0;
#pragma vector=USART0RX_VECTOR
__interrupt void USART0_RX_ISR(void)
  unsigned char data=0;
  data=U0RXBUF;                       //接收到的數據存起來
  key = data;
  Uart0Send_Byte(data);               //將接收到的數據再發送出去
void main(void)
    WDTCTL = WDTPW | WDTHOLD;   // stop watchdog timer
    Clock_Init(1);              // 0 就是 1M, 1 就是 8M
    PWM_init();                 // Init the PWM
    Port_init();                // Init the LCD1602
    LCD_init();
    UART0_Init();
    LCD_Desk();
    ADC_Init();
    _BIS_SR(GIE);                                      //開啟系統中斷
    while(1){
        LCD_Desk();
        ADC();
        LCD_DisplayTemp((uchar)TemperC);
        delay_ms(500);
        _NOP();
        switch(key){
        case 49:start(); LCD_write_str(4,2,"1"); LCD_write_str(4,1,"ON ");break;
        case 50:speed(1);LCD_Display_num(4,2,2);LCD_write_str(4,1,"ON ");break;
        case 51:speed(2);LCD_Display_num(4,2,3);LCD_write_str(4,1,"ON ");break;
        case 52:speed(3);LCD_Display_num(4,2,4);LCD_write_str(4,1,"ON ");break;
        case 48:stop();  LCD_write_str(4,2,"0");LCD_write_str(4,1,"OFF");break;
        default:break;
        key=0;
lan_ya_fan.7z
43.55 KB, 下載次數: 30, 下載積分: 黑幣 -5
