查看: 5575|回復: 3
基于STC15W408AS單片機內部EEPROM讀寫接口函數
ID:562627 發表于 2019-8-30 10:04 | 顯示全部樓層 |閱讀模式
#include "reg51.h"
#include "intrins.h"
#define ulong unsigned long
typedef uchar BYTE;
typedef uint WORD;
sfr P1M1 = 0x91;    //PxM1.n,PxM0.n     =00--->Standard,    01--->push-pull
sfr P1M0 = 0x92;    //                  =10--->pure input,  11--->open drain
sfr P0M1 = 0x93;
sfr P0M0 = 0x94;
sfr P2M1 = 0x95;
sfr P2M0 = 0x96;
sfr P3M1 = 0xB1;
sfr P3M0 = 0xB2;
sfr P4M1 = 0xB3;
sfr P4M0 = 0xB4;
sfr P5M1 = 0xC9;
sfr P5M0 = 0xCA;
sfr P6M1 = 0xCB;
sfr P6M0 = 0xCC;
sfr P7M1 = 0xE1;
sfr P7M0 = 0xE2;
sfr IAP_DATA    =   0xC2;           //IAP數據寄存器
sfr IAP_ADDRH   =   0xC3;           //IAP地址寄存器高字節
sfr IAP_ADDRL   =   0xC4;           //IAP地址寄存器低字節
sfr IAP_CMD     =   0xC5;           //IAP命令寄存器
sfr IAP_TRIG    =   0xC6;           //IAP命令觸發寄存器
sfr IAP_CONTR   =   0xC7;           //IAP控制寄存器
#define CMD_IDLE    0               //空閑模式
#define CMD_READ    1               //IAP字節讀命令
#define CMD_PROGRAM 2               //IAP字節編程命令
#define CMD_ERASE   3               //IAP扇區擦除命令
#define ENABLE_IAP  0x82            //if SYSCLK<20MHz
#define IAP_ADDRESS 0x0400
uint c,d,h,k,j;
/***************************輸出宏定義***********************/
#define OUT0 OUT_1=1;OUT_2=1;OUT_3=1;OUT_4=1;OUT_5=1;OUT_6=1;//定義0檔
#define OUT1 OUT_1=0;OUT_2=1;OUT_3=1;OUT_4=1;OUT_5=1;OUT_6=1;//定義1檔
#define OUT2 OUT_1=0;OUT_2=0;OUT_3=1;OUT_4=1;OUT_5=1;OUT_6=1;//定義2檔
#define OUT3 OUT_1=0;OUT_2=0;OUT_3=0;OUT_4=1;OUT_5=1;OUT_6=1;//定義3檔
#define OUT4 OUT_1=0;OUT_2=0;OUT_3=0;OUT_4=0;OUT_5=1;OUT_6=1;//定義4檔
#define OUT5 OUT_1=0;OUT_2=0;OUT_3=0;OUT_4=0;OUT_5=0;OUT_6=1;//定義5檔
#define OUT6 OUT_1=0;OUT_2=0;OUT_3=0;OUT_4=0;OUT_5=0;OUT_6=0;//定義6檔
sbit key1=P3^6; //1號鍵:火力加
sbit key2=P3^5; //2號鍵:火力減
sbit key3=P3^4; //3號鍵:啟動開關
sbit WORK_LED=P1^1;     //顯示板工作指示燈
sbit SPK=P1^2; //蜂鳴器的驅動IO口
sbit COM_LED=P1^0;      //顯示板COM控制
sbit SCK=P2^7;          //顯示板74HC164,SCK
sbit SDA=P2^6;          //顯示板74HC164,SDA
sbit OUT_1=P2^0;        //輸出1
sbit OUT_2=P2^1;        //輸出2
sbit OUT_3=P2^2;        //輸出3
sbit OUT_4=P2^3;        //輸出4
sbit OUT_5=P2^4;        //輸出5
sbit OUT_6=P2^5;        //輸出6
sbit FIRE=P1^3;         //火焰檢測
sbit AD0=P1^4;          //開關AD輸入
sbit LGNITION_SW=P1^5;  //點火開關
sbit TEMP=P1^6;         //溫度控制
sbit LGNITION=P3^7;     //點火控制
uchar SEG_tab[11]={0xf7,0xc1,0xbb,0xdb,
             0xcd,0xde,0xfe,0xc3,0xff,0xdf,0x00};//0-9,關閉;
/***************************延時函數*************************/
void Delay(BYTE n)
    WORD  x;
    while (n--)
       x = 5000;
       while (x--);
/***************************74HC164驅動程序*************************/
void Send_164(uchar dd)    //發送一個字節
     uchar a;
     SCK=0;
     for(a=0;a<8;a++)
         SCK=0; SDA=dd&0x80;
         SCK=1; dd=dd<<1;
     SDA=0;
/***************************蜂鳴*************************/
void key_beep()
  uchar b;
  for(b=2;b>0;b--)
       for(c=2;c>0;c--)
         SPK=0;
         Delay(5);
         SPK=1;
關閉IAP
void IapIdle()
    IAP_CONTR = 0;                  //關閉IAP功能
    IAP_CMD = 0;                    //清除命令寄存器
    IAP_TRIG = 0;                   //清除觸發寄存器
    IAP_ADDRH = 0x80;               //將地址設置到非IAP區域
    IAP_ADDRL = 0;
從ISP/IAP/EEPROM區域讀取一字節
BYTE IapReadByte(WORD addr)
    BYTE dat;                       //數據緩沖區
    IAP_CONTR = ENABLE_IAP;         //使能IAP
    IAP_CMD = CMD_READ;             //設置IAP命令
    IAP_ADDRL = addr;               //設置IAP低地址
    IAP_ADDRH = addr >> 8;          //設置IAP高地址
    IAP_TRIG = 0x5a;                //寫觸發命令(0x5a)
    IAP_TRIG = 0xa5;                //寫觸發命令(0xa5)
    _nop_();                        //等待ISP/IAP/EEPROM操作完成
    dat = IAP_DATA;                 //讀ISP/IAP/EEPROM數據
    IapIdle();                      //關閉IAP功能
    return dat;                     //返回
寫一字節數據到ISP/IAP/EEPROM區域
void IapProgramByte(WORD addr, BYTE dat)
    IAP_CMD = CMD_PROGRAM;          //設置IAP命令
    IAP_DATA = dat;                 //寫ISP/IAP/EEPROM數據
    IapIdle();
扇區擦除
void IapEraseSector(WORD addr)
    IAP_CMD = CMD_ERASE;            //設置IAP命令
    IapIdle();
按鍵0-9顯示,內部EEPROM讀寫接口函數.rar
2.38 KB, 下載次數: 87, 下載積分: 黑幣 -5
ID:643066 發表于 2019-11-16 11:24 | 顯示全部樓層
這個單片機我用官網的例子讀取 EEPROM和寫入的不一致,你遇到過嗎?
ID:508718 發表于 2019-11-16 16:38 | 顯示全部樓層
zhangjinan 發表于 2019-11-16 11:24
寫之前要先擦除扇區,然后再寫。
ID:562627 發表于 2020-4-8 14:58 | 顯示全部樓層
有遇到過,最后延長了寫入的時間就OK了
