STC15F2K60S2芯片控制的可變調的蜂鳴器
- #include "STC15F2K60S2.H"
- #define uchar unsigned char
- #define uint unsigned int
- #define X 1.05946
- sbit beep=P3^4;
- sbit P3_3=P3^3;
- sbit P3_2=P3^2;
- uint y=956;
- uint i=1;
- uchar duanxuan[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71}; //段選 0-f
- void delay(uint t) //延時函數 延時tms
- uint j;
- for(;t>0;t--)
- for(j=800;j>0;j--)
- void int0() interrupt 0
- EX0=0; //關閉外部中斷0
- delay(10); //消抖
- if(P3_2==0)
- { //當按下k1時,改變段選與定時器0的初始值從而改變輸入到蜂鳴器的方波頻率
- if(i==7) //循環輸出音調1-7
- {y=956;
- P0=duanxuan[1];
- i=1;
- else if(i==3)
- {y=y/X;i++;P0=duanxuan[i];}
- else
- {y=y/X/X;i++;P0=duanxuan[i];}
- while(!P3_2); //中斷檢測掃描鍵盤
- EX0=1; //開啟外部中斷0
- void int1() interrupt 2
- EX1=0; //關閉外部中斷1
- delay(10); //消抖
- if(P3_3==0)
- if(TR0)
- {TR0=0;beep=0;} //若定時器0開啟則關閉
- else
- {TR0=1;} //若定時器0關閉則開啟
- while(!P3_3); //中斷檢測掃描鍵盤
- EX1=1; //開啟外部中斷1
- void timer0() interrupt 1
- beep=~beep;
- TH0=(65536-y)/256; //音調不同,定時器初始值不同
- TL0=(65536-y)%256;
- main()
- P3M0=0x10; //推挽輸出
- P3M1=0x00;
- P2M0=0x0f;
- P2M1=0x00;
- P1M0=0xff;
- P1M1=0x00;
- TMOD=0x01; //定時器0位1方式工作
- EA=1; //中斷總開關
- ET0=1; //定時器0開啟
- TR0=1;
- EX1=1;
- IT1=1; //外部中斷開啟
- EX0=1;
- IT0=1;
- IP=0x05;
- beep=0;
- P2=0x07; //位選設為最右邊一位
- P0=duanxuan[1];
- while(1)
可變調的蜂鳴器工程.rar
(144.96 KB, 下載次數: 12)
2019-8-28 10:59 上傳
