查看: 1340|回復(fù): 1
壁障小車的單片機(jī)程序哪里出問題了?求幫助
ID:508300 發(fā)表于 2019-8-22 20:43 | 只看該作者 回帖獎勵 |倒序?yàn)g覽 |閱讀模式
就是自己暑假自學(xué)單片機(jī),做了一個壁障小車用了兩個紅外壁障模塊和一個超聲波模塊做的一個壁障小車,可是小車的壁障卻很不理想,不知道哪里出問題所以感覺可能程序有問題,請大佬幫忙看看。
#include"reg51.h"
#include"xiaoche.h"
#include"intrins.h"
typedef unsigned char u8;
typedef unsigned int u16;
char push_val_left=5;
char push_val_right=5;
u8 pwm_val_right=0;
u8 pwm_val_left=0;
u8 pwm_count=0;
char time=0;
unsigned char S=0;//???????????
void delay(unsigned int xms)
    unsigned int i,j;
for(i=xms;i>0;i--)        //i=xms??????xms????
    for(j=112;j>0;j--);
void Delay10us(unsigned int i)     //10us??????? ????????????????
    unsigned int j;
do
    j = 10;
    do
      _nop_();
  while(--j);
while(--i);
void startModle()
TX=1;
Delay10us(2);
TX=0;
void count()//?????????????
S=0;
time=TH1*256+TL1;
TH1=0;
TL1=0;
S=time*0.17+10;
void forward()
IN1=0;//????????
IN2=1;
IN3=1;
IN4=0;
void stop()//???
IN1=0;
IN2=0;
IN3=0;
IN4=0;
void back()
IN1=1;//????????
IN2=0;
IN3=0;
IN4=1;
void left()
IN1=1;
IN2=0;
IN3=1;
IN4=0;
void right()
IN1=0;
IN2=1;
IN3=0;
IN4=1;
void pwm_out_right_moto(void)
    if(Right_PWM_ON)
        if(pwm_val_right<=push_val_right) //20ms??????? 111 111 0000 0000 0000 00
         EN2=1;        //????6:20
         EN2=0;
     if(pwm_val_right>=20)
     pwm_val_right=0;
        EN2=0;   //??δ????PWM??EN2=0 ???? ??
void pwm_out_left_moto(void)
     if(Left_PWM_ON)
          if(pwm_val_left<=push_val_left)
            EN1=1;
            EN1=0;
          if(pwm_val_left>=20)
       pwm_val_left=0;
          EN1=0;   //??δ????PWM??EN1=0 ???? ??
void Timer0() interrupt 1
TH0 = 0xff;   //??????0.1ms
    TL0 = 0xa3;
pwm_count++;
if(pwm_count>=10)
  pwm_val_right++;
  pwm_val_left++;
  pwm_out_right_moto();
  pwm_out_left_moto();
  pwm_count=0;
TMOD|=0X11;
EA=1;
ET0=1;
ET1=0;
TR0=1;
TR1=1;
TH1=0;
TL1=0;
count();
  if((hongwai_left==0)&&(S<=300))
   stop();
   delay(50);
   right();
   delay(50);
  if((hongwai_right==0)&&(S<=300))
   stop();
   delay(50);
   left();
   delay(50);
    forward();
ID:235200 發(fā)表于 2019-8-25 23:11 | 只看該作者
   stop();
   delay(50);
   right();
   delay(50);
   stop();
   delay(50);
   left();
   delay(50);
    forward();
循環(huán)程序采取順序結(jié)構(gòu),先判斷左紅外,然后判斷右紅外,且中間還有延時,當(dāng)程序運(yùn)行在左紅外判斷時,此時右邊紅外無法判斷,當(dāng)程序運(yùn)行在右紅外判斷時,此時左邊紅外無法判斷,這就是不理想的原因,程序應(yīng)該兩個條件同時判斷,然后根據(jù)判斷結(jié)果作出相應(yīng)的避障措施
無效樓層,該帖已經(jīng)被刪除
