查看: 5120|回復: 4
基于STM32單片機遠程澆花花盆GSM短信澆水補光設計
ID:602704 發表于 2019-8-22 14:58 | 顯示全部樓層 |閱讀模式
大家好:
             今天我制作了基于STM32單片機遠程澆花花盆GSM短信澆水補光設計
實物照片:
電路圖及PCB板:
部分源程序:
  * @file    misc.h
  * @author  MCD Application Team
  * @version V3.5.0
  * @date    11-March-2011
  * @brief   This file contains all the functions prototypes for the miscellaneous
  *          firmware library functions (add-on to CMSIS functions).
  * @attention
  * THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
  * WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE
  * TIME. AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY
  * DIRECT, INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING
  * FROM THE CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE
  * CODING INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
  * <h2><center>&copy; COPYRIGHT 2011 STMicroelectronics</center></h2>
/* Define to prevent recursive inclusion -------------------------------------*/
#ifndef __MISC_H
#define __MISC_H
#ifdef __cplusplus
extern "C" {
#endif
/* Includes ------------------------------------------------------------------*/
#include "stm32f10x.h"
/** @addtogroup STM32F10x_StdPeriph_Driver
/** @addtogroup MISC
/** @defgroup MISC_Exported_Types
  * @brief  NVIC Init Structure definition
typedef struct
  uint8_t NVIC_IRQChannel;                    /*!< Specifies the IRQ channel to be enabled or disabled.
                                                   This parameter can be a value of @ref IRQn_Type
                                                   (For the complete STM32 Devices IRQ Channels list, please
                                                    refer to stm32f10x.h file) */
  uint8_t NVIC_IRQChannelPreemptionPriority;  /*!< Specifies the pre-emption priority for the IRQ channel
                                                   specified in NVIC_IRQChannel. This parameter can be a value
                                                   between 0 and 15 as described in the table @ref NVIC_Priority_Table */
  uint8_t NVIC_IRQChannelSubPriority;         /*!< Specifies the subpriority level for the IRQ channel specified
  FunctionalState NVIC_IRQChannelCmd;         /*!< Specifies whether the IRQ channel defined in NVIC_IRQChannel
                                                   will be enabled or disabled.
                                                   This parameter can be set either to ENABLE or DISABLE */
} NVIC_InitTypeDef;
/** @defgroup NVIC_Priority_Table
@code
The table below gives the allowed values of the pre-emption priority and subpriority according
to the Priority Grouping configuration performed by NVIC_PriorityGroupConfig function
    NVIC_PriorityGroup   | NVIC_IRQChannelPreemptionPriority | NVIC_IRQChannelSubPriority  | Description
   NVIC_PriorityGroup_0  |                0                  |            0-15             |   0 bits for pre-emption priority
                         |                                   |                             |   4 bits for subpriority
   NVIC_PriorityGroup_1  |                0-1                |            0-7              |   1 bits for pre-emption priority
                         |                                   |                             |   3 bits for subpriority
   NVIC_PriorityGroup_2  |                0-3                |            0-3              |   2 bits for pre-emption priority
                         |                                   |                             |   2 bits for subpriority
   NVIC_PriorityGroup_3  |                0-7                |            0-1              |   3 bits for pre-emption priority
                         |                                   |                             |   1 bits for subpriority
   NVIC_PriorityGroup_4  |                0-15               |            0                |   4 bits for pre-emption priority
                         |                                   |                             |   0 bits for subpriority
@endcode
/** @defgroup MISC_Exported_Constants
/** @defgroup Vector_Table_Base
#define NVIC_VectTab_RAM             ((uint32_t)0x20000000)
#define NVIC_VectTab_FLASH           ((uint32_t)0x08000000)
#define IS_NVIC_VECTTAB(VECTTAB) (((VECTTAB) == NVIC_VectTab_RAM) || \
                                  ((VECTTAB) == NVIC_VectTab_FLASH))
/** @defgroup System_Low_Power
#define NVIC_LP_SEVONPEND            ((uint8_t)0x10)
#define NVIC_LP_SLEEPDEEP            ((uint8_t)0x04)
#define NVIC_LP_SLEEPONEXIT          ((uint8_t)0x02)
#define IS_NVIC_LP(LP) (((LP) == NVIC_LP_SEVONPEND) || \
                        ((LP) == NVIC_LP_SLEEPDEEP) || \
                        ((LP) == NVIC_LP_SLEEPONEXIT))
/** @defgroup Preemption_Priority_Group
#define NVIC_PriorityGroup_0         ((uint32_t)0x700) /*!< 0 bits for pre-emption priority
                                                            4 bits for subpriority */
#define NVIC_PriorityGroup_1         ((uint32_t)0x600) /*!< 1 bits for pre-emption priority
                                                            3 bits for subpriority */
#define NVIC_PriorityGroup_2         ((uint32_t)0x500) /*!< 2 bits for pre-emption priority
                                                            2 bits for subpriority */
#define NVIC_PriorityGroup_3         ((uint32_t)0x400) /*!< 3 bits for pre-emption priority
                                                            1 bits for subpriority */
#define NVIC_PriorityGroup_4         ((uint32_t)0x300) /*!< 4 bits for pre-emption priority
                                                            0 bits for subpriority */
#define IS_NVIC_PRIORITY_GROUP(GROUP) (((GROUP) == NVIC_PriorityGroup_0) || \
                                       ((GROUP) == NVIC_PriorityGroup_1) || \
                                       ((GROUP) == NVIC_PriorityGroup_2) || \
                                       ((GROUP) == NVIC_PriorityGroup_3) || \
                                       ((GROUP) == NVIC_PriorityGroup_4))
#define IS_NVIC_PREEMPTION_PRIORITY(PRIORITY)  ((PRIORITY) < 0x10)
#define IS_NVIC_SUB_PRIORITY(PRIORITY)  ((PRIORITY) < 0x10)
#define IS_NVIC_OFFSET(OFFSET)  ((OFFSET) < 0x000FFFFF)
/** @defgroup SysTick_clock_source
#define SysTick_CLKSource_HCLK_Div8    ((uint32_t)0xFFFFFFFB)
#define SysTick_CLKSource_HCLK         ((uint32_t)0x00000004)
#define IS_SYSTICK_CLK_SOURCE(SOURCE) (((SOURCE) == SysTick_CLKSource_HCLK) || \
                                       ((SOURCE) == SysTick_CLKSource_HCLK_Div8))
/** @defgroup MISC_Exported_Macros
/** @defgroup MISC_Exported_Functions
void NVIC_PriorityGroupConfig(uint32_t NVIC_PriorityGroup);
void NVIC_Init(NVIC_InitTypeDef* NVIC_InitStruct);
void NVIC_SetVectorTable(uint32_t NVIC_VectTab, uint32_t Offset);
void NVIC_SystemLPConfig(uint8_t LowPowerMode, FunctionalState NewState);
void SysTick_CLKSourceConfig(uint32_t SysTick_CLKSource);
#ifdef __cplusplus
#endif
#endif /* __MISC_H */
/******************* (C) COPYRIGHT 2011 STMicroelectronics *****END OF FILE****/
第一次發帖子 如有錯誤之處請多多指教   、、
借鑒完了請給個贊和評論
參與人數 1黑幣 +12 收起 理由
hyr001 + 12
ID:603289 發表于 2019-8-24 10:58 | 顯示全部樓層
多謝分享
ID:559804 發表于 2019-9-11 16:33 | 顯示全部樓層
能把全部程序發一下嘛?
ID:110875 發表于 2019-9-17 22:02 | 顯示全部樓層
看不了
ID:613783 發表于 2019-9-19 21:51 | 顯示全部樓層
多謝分享
