查看: 2532|回復: 0
VL53X0調試源代碼
ID:531506 發表于 2019-8-22 10:50 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include "ioCC2530.h"
#include "VL53L0X.h"
typedef union
    uint16 u16;               // element specifier for accessing whole u16
    int16 i16;               // element specifier for accessing whole i16
    struct
        uint8 u8L;              // element specifier for accessing low u8
        uint8 u8H;              // element specifier for accessing high u8
    } s16;                  // element spec. for acc. struct with low or high u8
} nt16;
void Delay_5us()
    uint8 i;
    for (i=0; i<8; i++)
        asm("NOP");
void Delay_ms(uint16 sec)
    uint16 i;
    while (sec --)
        for (i = 0; i < 1500; i ++)
            asm("NOP");
    return;
void initUARTSEND(void)
    //時鐘配置
    CLKCONCMD &= ~0x40;        //設置系統時鐘源為32MHZ晶振
    while(CLKCONSTA & 0x40);   //等待晶振穩定
    CLKCONCMD &= ~0x47;        //設置系統主時鐘頻率為32MHZ
    //端口配置
    PERCFG = 0x00;               //位置1 P0口
    P0SEL = 0x0c;                                //P0_2,P0_3用作串口
    P2DIR &= ~0XC0;                             //P0優先作為UART0
   //串口配置
    U0CSR |= 0x80;                                //UART方式
    U0GCR |= 11;                                 //U0GCR.BAUD_E
    U0BAUD |= 216;                                //波特率設為115200 UxBAUD.BAUD_M
    UTX0IF = 0;                                 //UART0 TX中斷標志初始置位0
void UartSendString(char *Data, uint16 len)
  uint16 j;
  for (j = 0; j < len; j++)
    U0DBUF = *Data++;
    for (; 0 == UTX0IF ;);
    UTX0IF = 0;
void uart0PutChar(char c)
  uint16 i;
  for(i=0; i<10000; i++)
    if(!(U0CSR & 0x01))
    break;
  U0DBUF = c;
    if(!(U0CSR & 0x01))
    break;
uint16 makeuint16(int lsb, int msb)
  return ((msb & 0xFF) << 8) | (lsb & 0xFF);
void uartPutInt16(uint16 c)
  uart0PutChar((c & 0xFF00) >> 8);
  uart0PutChar(c & 0xFF);
void GPIO_Init(void)
    P0SEL &= ~0x12;          //將P0_1、P0_4設置為通用I/O端口功能
    P0DIR |= 0x02;           //將P0_1的端口傳輸方式設置為輸出
    P0DIR &= ~0x10;          //將P0_4的端口傳輸方式設置為輸入
    P1SEL &= ~0x08;          //將P1_3設置為通用I/O端口功能
    P1DIR |= 0x08;           //將P1_3的端口傳輸方式設置為輸出
    P0INP &= ~0xef;
    P2INP &= ~0x20;
    KK_wakeup = 1;
    KK_Xshut = 0;
void I2C1_Init(void)
    SCL_1_W();
    SDA_1_W();
    I2C1_SCL_HIGH;
    I2C1_SDA_HIGH;
void I2C1_Start(void)
    SCL_1_W();SDA_1_W();
    I2C1_SDA_HIGH;
    I2C1_SCL_HIGH;
    Delay_5us();
    I2C1_SDA_LOW;
    Delay_5us();
    Delay_5us();
    I2C1_SCL_LOW;
void I2C1_Stop(void)
    I2C1_SDA_LOW;
    I2C1_SCL_LOW;
    Delay_5us();
    I2C1_SCL_HIGH;
    Delay_5us();
    Delay_5us();
    I2C1_SDA_HIGH;
uint8 I2C1_WaitAck(void)
    uint8 ErrTime = 0;
    // 將 SCL 引腳和 SDA 引腳設置為輸出模式
    I2C1_SDA_HIGH;       // SDA 置高
    I2C1_SCL_HIGH;       // SCL 置高
    Delay_5us();
    SDA_1_R();            // SDA 設置為輸入模式
    while(I2C1_SDA_STATE)// 當 SDA 為低電平時退出循環
        ErrTime++;
        if(ErrTime>250)
            I2C1_Stop();
            return true;
    I2C1_SCL_LOW;
    Delay_5us();
    return false;
void I2C1_SendAck(void)
    I2C1_SDA_LOW;
    I2C1_SCL_LOW;
    Delay_5us();
    I2C1_SCL_HIGH;
    Delay_5us();
    I2C1_SCL_LOW;
void I2C1_SendNoAck(void)
    I2C1_SCL_LOW;
    I2C1_SDA_HIGH;
    Delay_5us();
    I2C1_SDA_HIGH;
    Delay_5us();
    I2C1_SCL_LOW;
void I2C1_Send_Byte(uint8 txd)
    uint8 t = 0;
    for (t = 0; t < 8; t ++)
        if ((txd & 0x80) >> 7)
            I2C1_SDA_HIGH;
            I2C1_SDA_LOW;
        txd <<= 1;
        Delay_5us();
        I2C1_SCL_HIGH;
        Delay_5us();
        I2C1_SCL_LOW;
        Delay_5us();
uint8 I2C1_Read_Byte(uint8 ack)
    uint8 i = 0;
    uint8 receive = 0;
    SDA_1_R();
    for (i = 0; i < 8; i ++)
        I2C1_SCL_LOW;
        Delay_5us();
        I2C1_SCL_HIGH;
        receive <<= 1;
        if (I2C1_SDA_STATE)
            receive ++;
        Delay_5us();
    if (ack)
        I2C1_SendAck();
        I2C1_SendNoAck();
    return receive;
函數功能:IIC連續寫
主要參數:
addr-->器件地址
reg-->寄存器地址
len-->寫入長度
buf-->數據區
返回值:0,正常
uint8 VL53L0X_Write_Len(uint8 reg,uint8 len,uint8 const *buf)
    uint8 i;
    I2C1_Start();
    I2C1_Send_Byte(0x52);       //發送器件地址+寫命令
    if(I2C1_WaitAck())        //等待應答
       I2C1_Stop();
       return true;
    I2C1_Send_Byte(reg);        //寫寄存器地址
    I2C1_WaitAck();            //等待應答
    for(i=0;i<len;i++)
       I2C1_Send_Byte(buf[i]);        //發送數據
       if(I2C1_WaitAck())            //等待ACK
          I2C1_Stop();
          return true;
    I2C1_Stop();
    return false;
函數功能:IIC連續讀
主要參數:
addr-->器件地址
reg-->寄存器地址
len-->讀取長度
buf-->數據區
返回值:0,正常
uint8 VL53L0X_Read_Len(uint8 reg,uint8 len,uint8 *buf)
    I2C1_Start();
    I2C1_Send_Byte(0x52);//發送器件地址+寫命令
       I2C1_Stop();
       return true;
    I2C1_Start();
    I2C1_Send_Byte(0x53);//發送器件地址+讀命令
    while(len)
       if(len==1)*buf=I2C1_Read_Byte(0);//讀數據,發送nACK
       else *buf=I2C1_Read_Byte(1);     //讀數據,發送ACK
       len--;
       buf++;
    I2C1_Stop();        //產生一個停止條件
    return false;
uint8 VL53L0X_Write_Byte(uint8 reg,uint8 data)
    I2C1_Start();
       I2C1_Stop();
       return true;
    I2C1_Send_Byte(data);         //寫入數據
       I2C1_Stop();
       return true;
    I2C1_Stop();
    return false;
uint8 VL53L0X_Read_Byte(uint8 reg)
    uint8 VL53L0X_data;
    I2C1_Start();
    I2C1_Start();
    I2C1_Send_Byte(0x53);         //發送器件地址+讀命令
    VL53L0X_data=I2C1_Read_Byte(0);//讀取數據,發送ACK
    return VL53L0X_data;
  uint8 gbuf[16];
  uint8 val = 0;
  uint32 cnt = 0;
  uint16 Distance = 0;
  GPIO_Init();
  Delay_ms(100);
  KK_Xshut = 1;
  initUARTSEND();
  I2C1_Init();
      if(KK_lcdctl)
          KK_wakeup = 1;
          //uartPutInt16(0xff);
          VL53L0X_Write_Byte(VL53L0X_REG_SYSRANGE_START, 0x01);//啟動檢測
          while(cnt < 65535)//當檢測完成,即讀取距離值
             Delay_ms(1);
             val = VL53L0X_Read_Byte(VL53L0X_REG_RESULT_RANGE_STATUS);
             if( val & 0x01) break;
             cnt++;
          if( val & 0x01)
              VL53L0X_Read_Len(0x1E , 2, gbuf);//讀取數據
//              VL53L0X_Write_Byte(0x0b, 0x01);//啟動檢測
              Distance = gbuf[0]<<8;
              Distance |= gbuf[1];
          if((Distance > 20)&&(Distance < 1500))
             uartPutInt16(Distance);
             if((Distance>=450)&&(Distance<=550))
                KK_wakeup = 0;
          Delay_ms(200);
Source.zip
3.19 KB, 下載次數: 17, 下載積分: 黑幣 -5
