求教高手,PIC16F917,沒加定時器時主函數里的按鍵和監測函數運行都是正常的,然后增加一個定時器做個蜂鳴器報警功能!結果主函數就運行了,后面再屏蔽掉定時器,主函數照樣不運行。〔恢朗窃趺椿厥!求高手幫忙看看!
#include<pic.h>
#define low RD0
#define lbt RD3
#define high RD2
#define flt RD4
#define spk RD5
#define mot RD6
#define ctr RD7
#define keyin RB0
const uint data[2]={64722,64436}; //蜂鳴器頻率
uint mode=0,lednum;
uint count=0;
uint vba,isp,k,t,flagb,flagf,jcout,i,p,j,s;
__CONFIG(0x30F5);
void delay(uint x);
void init();
uint get_ad(uchar y);
void monitor();
void key_scan();
void sentchar(uchar data1);
void printcom(const uchar *dat);
void printdata(uint dat);
uint filter();
void speakf();
void speakb();
//void interrupt time1();
init();
RD1=!RD1;
k++;
// s++;
if(k==1000)
k=0;
monitor();
if(s>=1000)
s=0;
RD4=!RD4;
TMR1ON=!TMR1ON;
key_scan();
void delay(uint x){--------}
void init() //初始化:4MHZ,AD, PWM,uart,定時器012
OSCCON=0x67;
TRISA=0x0f;
TRISB=0x01;
TRISC=0xc0;
TRISD=0;
PORTA=0;
PORTB=0;
PORTC=0;
PORTD=0xE1;
TXSTA=0x24;
RCSTA=0x90;
SPBRG=25;
RCIE=1;
ANSEL=0x28;
ADIE=1;
ADCON0=0x05;
ADCON1=0x9e;
OPTION=0X07;
TMR0=61;
T0IE=1;
INTCON=0xa0;
GIE=1;
PEIE=1;
PIE1=0X03;
T2CON=0X1C;
TMR2IE=0;
CCPR1L=0x5b; //C8
CCP1CON=0x0C;
TMR2=0;
PR2=0x7C;
T1CON=0x01;
TMR1L=(65536-200)%256;
TMR1H=(65536-200)/256;
delay(10);
T1CON=0X01;
PORTD=0x81;
uint get_ad(uchar y){----------}
void monitor(){----監測電池電壓和總電流--}
void key_scan(){---一鍵開關機+功能切換----}
void sentchar(uchar data1){---串口----}
void printcom(const uchar *dat){ ---串口------}
void printdata(uint dat){---串口----}
if(TMR1IE&&TMR1IF)
p=data[jcout];
TMR1IF=0;
TMR1L=p%256;
TMR1H=p/256;
spk=!spk;
s++;
// printdata(s);
uint filter(){----ADC平均值-----}
void speakf() {-------}
void speakb(){------}
