查看: 8448|回復: 3
ARDUINO UNO無法正常上傳avrdude: stk500_recv(): programmer is not responding
ID:600369 發表于 2019-8-15 11:15 | 顯示全部樓層 |閱讀模式
我使用ARDUINO UNO進行上傳示例代碼一直出現avrdude: stk500_recv(): programmer is not responding
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x73
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x73
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x73
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x73
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x73
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x73
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x73
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x73
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x73
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x73
上傳出錯。查看頁面 http://www.arduino.cc/en/Guide/Troubleshooting#upload 獲取建議。
是否可以通過直接連接USB進行燒錄,還是需要外接別的電路?又或者我的ATmega328沒有bootloader?求解答
ID:600369 發表于 2019-8-15 14:55 | 顯示全部樓層
WARNING: Category 'Uncategorized' in library Rest is not valid. Setting to 'Uncategorized'
為什么會出現這種情況?
ID:600369 發表于 2019-8-16 09:22 | 顯示全部樓層
我好像把原板上的ATmega328p里的東西燒沒了,請問我現在應該怎么做?
ID:600369 發表于 2019-8-20 11:48 | 顯示全部樓層
直接重新買了一塊板所有問題都解決了
